Projects Not getting any younger 34 3 window build
Discussion in 'Traditional Hot Rods' started by Roadsir, Feb 14, 2026.
  1. Roadsir
    Roadsir
    I recently sold a chopped 32 Brookville hiboy, really wanting to get into a 33/34 chopped hiboy, not really wanting a full build either. Ryan at Hot Rod Works in Waco listed this and at first it was a little more of a project than I wanted to dive into, and I had my A project still on the back burner. Turns out he like A roadsters and we made a trade, and halfway was RJays in Butler Missouri.
    I’m going have RJays to the ch***is with a Model Style rear crossmember, ladder bars, channel X, a HRW’s quickchange, my old 4” CE forged axle, maybe drop it to 5” for a low low front.
    Plan on a little Small Block Chev or maybe my 392 Hemi, and a 4 or 5 speed.
    Hopefully someone can chime in on the history of the body there’s green metallic under primer, and is a 34 with 33 doors. I’ll be posting some adds for parts, will need a lot.
    Pics coming.
  2. Roadsir
    Roadsir
    Having a hellava time uploading images from my new iphones. Images are to large
    Outback likes this.
  3. Roadsir
    Roadsir
  4. No help, but nice trade.
    RodStRace, mad mikey and Roadsir like this.
  5. Roadsir
    Roadsir
    An overall shot with the parts included.
    Thor1, Rocket88NZ, Stogy and 17 others like this.
  6. rusty valley
    rusty valley
    33 doors is a good thing!
    Stogy, chlsnk, Deutscher and 4 others like this.
  7. Outback
    Outback
    from NE Vic, Oz
    this should be a fun hot rod
  8. Tim
    Tim
    from KCMO
    Very cool! My phone always tells me the photos are to large as well, I end up taking screen shots of the photos and the they are small enough.
    RJays is just down the road, always building a great ch***i!
  9. Roadsir
    Roadsir
    I'll be making another trip, one to pick up the ch***is, and I will be headed to ROC this year with the 32.
    BigJoeArt, Stogy, mad mikey and 3 others like this.
  10. Great project. love the metallic green.
    Al.
    Stogy, mad mikey and Roadsir like this.
  11. Roadsir
    Roadsir
    A driver an hour away from me would have been so much easier :)
  12. flamedabone
    flamedabone
    That ****er is dreamy. Nice trade.
    -Abone.
  13. Roadsir
    Roadsir
    thanks! I was eyeing how you did your rear frame horns on your last 5 window build. Might do something similar!
    Stogy likes this.
  14. pprather
    pprather
    For an outsider, what is the major difference between 33 and 34 doors?
    Thanks.
    Stogy and Roadsir like this.
  15. Roadsir
    Roadsir
    34 cowl has recesses in the cowl for the hood sides to rest on when its up. 34 has the web at the back of the window opening so the gl*** can go back first then down. 34 has stamped ribs in rear wheel inners 33 is smooth....I am sure there is more I am missing.
    Deutscher likes this.
  16. Roadsir
    Roadsir
    I posted a wanted add, but just in case here is a list of part I'll be looking for.
    Check your leftovers of OG and Extra repro parts. Looking for parts to complete a 3W coupe build
    Walker radiator for SBC
    Nice driver quality 34 Grille, radiator cap,
    Complete set of trunk hinges
    Windshield frame or a good windshield frame bottom
    Windshield hinges
    Windshield crank mechanism
    Inside upper visor tin
    Cowl vent mechanism
    Glove box door & hinge
    Dash with ashtray
    Two door sedan inside window frames to cut down
    Back window frame to cut down
    Back window regulator
    Two door bottoms, maybe complete doors with inners
    Outside door and trunk handles
    34 3 window wood kit pieces
    1930 1931 Model A Visor
    Big and little Halibrands
    Stogy and mad mikey like this.
  17. DDDenny
    Smokers window.
  18. 19Eddy30
    19Eddy30
    from VA
    Is that actually a thing/purpose
    When window tilts backward with gap then down , "Smoker Window ""
    If so lean something New !!
    I miss vent windows & rain gutters
    Late models.
    Budget36, Outback and Roadsir like this.
  19. rusty valley
    rusty valley
    34 smoker window has the 1" web at the back of the door, ugly for one, and the weather strip feature from Ford is impossible to stop leaking air for 2, and to get the window to function correct...go up...then another half crank and it goes back to open a 1" slot at the front...is a bunch of ****ing around adjustments inside a door that has hardly any access. It should be all done with the door skin off, if we were thinking ahead. 33 window goes up and down like God intended.
    Thor1, weps, HemiDeuce and 5 others like this.
  20. alchemy
    alchemy
    40 years ago a local hot rodder had a 34 3-window body the same color green. But it had a rolled rear pan and the top was not chopped. But those things could have been changed since then. I wonder if it’s the same car? It was channeled, and my brother now owns the modified 34 grille that was on the car. It has a flattened bottom, but is done very nicely and rechromed.
  21. Roadsir
    Roadsir
    The tail pan is new, the cowl doesn't look like the feet have ever been modified, and the firewall is surprising unmolested. Odd color for sure!
    Stogy, Deutscher and mad mikey like this.
  22. alchemy
    alchemy
    IIRC the odd green local coupe body was traded for a very nice 32 5-window body, which my Dad now owns and is very close to being operational again.
    Thor1, Chief 64, Stogy and 11 others like this.
  23. Roadsir
    Roadsir
    The 32 looks awesome!
  24. What’s the plan with the model A visor- he asks cautiously…
    Stogy likes this.
  25. alchemy
    alchemy
    34’s look great with a visor screwed to the top.
    Stogy likes this.
  26. That’s what I was hoping for.
    Stogy likes this.
  27. Roadsir
    Roadsir
    I found on my 34 5 window project...(that I should have kept) the model visor is the exact width as a 34 tail pan, so I'll plan on doing the same treatment, and still see the quickchange!
    Thor1, NealinCA, Stogy and 11 others like this.
  28. alchemy
    alchemy
    Huh. Who woulda guessed?
  29. 421-6Speed
    421-6Speed
    Looks like a fun project. I may be able to help with some of the parts on your list, will go through and see what I have.
    Stogy likes this.
  30. DDDenny
    Oh hell yes!
    Stogy likes this.
