Projects 1st AV8 build project
Discussion in 'Traditional Hot Rods' started by sknz, Feb 2, 2026.
  1. sknz
    sknz
    from NW OH
    I thought it would be a good project to convert my 1929 A roadster to V8 with a newer synchro trans and having never done this before I purchased the Old Yankee AV8 conversion kit from Millworks. The kit is top quality and very complete. As I progressed following the included instructions it became apparent that there might be some differences from car to car on some dimensions. The center trans mount bracket on my car needed to be farther forward because the supplied trans bracket blocked installation of the speedo cable on the torque tube. I solved this by making a 1/2" aluminum bar spacer to move the bracket forward which now allows clearance to connect the speedo cable.
    I had installed the front motor mounts per the instructions using the existing holes in the frame intended for the factory shock mounting. I was unable to get the trans fully connected to the torque tube and the clamshell would not fully come together. I ended up unbolting the the motor mounts from the frame and making the trans/torque tube connection and re-drilling the motor mount holes. As far as vertical placement of the motor mounts I decided to just center the crankshaft to the crank lever bracket on the front spring mount. The carb mounting flange on the intake manifold is level so I ***ume the engine angle is correct. Everything seems now to have clearance and should work OK. I did remove the factory electrical box bump out on the firewall and I have the cast offset breather from Gear Drive Speed & Custom which works well.
    This is all new to me and the next one I do will go a little better after this experience. Next is modification and installation of the Ford F1 steering box. H.A.M.B. has been extremely helpful so far and I will continue to read all that I can from you folks that know a whole lot more about this hobby than I do. Thanks!
  2. Outback
    Outback
    from NE Vic, Oz
    nice work. very little 'bolts straight up' but it looks like the kit is a good thing.
    more photos of the whole car would be good, what are your broader plans?
    RMONTY and sknz like this.
  3. sknz
    sknz
    from NW OH
    Car had juice brakes when I bought it and they are still brand new. I'll install an 18 gallon fuel tank and pump in the trunk as well as the battery. I'll most likely leave the rear deck lid hinged as it is for rumble seat. Couple of gauges and a choke cable in the stock instrument panel. Wiring all under the seat. F1 steering and I'll weld up a front to back stainless exhaust which will give me a project to use my new laser welder on. Just need to get this finished up so I can get back on my A speedster project. Thanks for asking.
    upload_2026-2-6_16-35-27.jpeg upload_2026-2-6_16-36-10.jpeg upload_2026-2-6_16-41-58.jpeg upload_2026-2-6_16-43-25.jpeg
  4. Outback
    Outback
    from NE Vic, Oz
    looks like a cherry roadster, the laser welding will be interesting
    sknz likes this.
  5. CSPIDY
    CSPIDY
    Very nice build, I like the direction you are going
    what are the plans for the banger?
    Does it run?
    They are one of the best engines ever built.
    sknz likes this.
  6. sknz
    sknz
    from NW OH
    Well I mounted the banger engine/trans plus radiator, 1 gallon fuel tank, new battery, throttle linkage, complete exhaust, etc. on a pallet and sold it in running condition to a fellow in Michigan that had a cracked block on his banger motor. All around good deal for both of us. Thanks for asking.
  7. sknz
    sknz
    from NW OH
    I finally got around to trying out the laser welder on some s****s of 6061 0.063 aluminum. This is the first weld, about 5-6 seconds for the 3" bead. 100% weld penetration. Been welding for 50+ years and I've never seen anything like it. Probably will not use my TIG machine as much now.
  8. Outback
    Outback
    from NE Vic, Oz
    I've only seen reel's never really sure if they work like it shows.
    Ziggster and sknz like this.
  9. Nice project. We have a laser welder at work and just started tinkering with it, it's pretty impressive.
    Ziggster, sknz and Deutscher like this.
  10. patsurf
    patsurf
    wow!!what kind of price range for that kind of results?--prob worth it!!
    sknz likes this.
  11. 1935ply
    1935ply
    from peyton,co
    Good looking project, I think to suit the build you should switch the gauges for older stewart warners. I like your finger for holding the pieces to weld. The laser weld looks real good.
    Just Gary, FORDY 6 and sknz like this.
  12. sknz
    sknz
    from NW OH
    $4K
    panhead_pete likes this.
  13. sknz
    sknz
    from NW OH
    I agree on the gauges. I couldn’t find any 1.5” SW gauges that would fit in the stock bezel.
  14. patsurf
    patsurf
    very cool!-thanks!
  15. sknz
    sknz
    from NW OH
    Fitting a Tanks 18 gallon fuel tank so we have a little more range with the V8. Can't say enough good things about the Tanks folks. Great customer service and very well made products.
  16. Ziggster
    Ziggster
    Nice to see someone tackle this from the get go as most threads are about modding something that already has a V8 installed. I’m still curious to know all the bits that need modding to make an AV8. Looking good!
    Okie Pete and sknz like this.
  17. sknz
    sknz
    from NW OH
    Actually not a lot needs altered. The A steering box will interfere with the cylinder head on the drivers side so I am using a F1 box. There will be some minor t******* of the firewall to clear the fuel pump stand. You can use an offset breather as pictured or if you choose to go with an electric fuel pump you can eliminate the mechanical fuel pump and use an angled breather as in the photo. Motor and trans mounts are straight forward and exhaust and cooling fan are about the only other items to address. Old Yankee kit from Millworks makes everything easier for a price. Thanks for asking.
    Ziggster, Okie Pete, Pinewood and 5 others like this.
  18. NoSurf
    NoSurf
    Everything looks great. Nice job.
    Now chop that windshield.....
  19. Jeff34
    Jeff34
    And lay it back some.
    Pinewood, sknz, NoSurf and 1 other person like this.
  20. sknz
    sknz
    from NW OH
    Got the fuel filler, pickup, and sender in the tank and the tank mounted so time to work on the F1 steering box. Seems like everyone has a different way to remove the F1 box flange. I decided to make a fixture for my mag drill. I bolted the box to a plate and then a couple of stands to raise the drill to the working height.
    I made a plug from Delrin and drilled a 1/4" hole through to help guide the hole saw. I used a 2.125" x 2" Morse Bi-Metal hole saw.
    I used Tap Heavy for a lubricant during the cut which works very well.
    I'm not sure how far the new flange needs to go onto the box so everything clears the head and exhaust manifold but mocking everything up should answer that question.
  21. sknz
    sknz
    from NW OH
    Well the F1 steering box mods went well so today was drill the frame for the plates and cut the larger hole required for the F1 box which was no problem.
    The steering box went right in and next the engine/trans will go in so make sure everything clears.
    I'm not sure how to handle the column drop. The 2 tooth column I removed is 1 3/4" OD and the F1 column is 1 1/2" OD. It looks like the drop should be 2" lower than stock. I won't be using the stock fuel tank so could replace the stock column drop with something different.
    I would entertain any suggestions on how to handle this column drop issue.
  22. sknz
    sknz
    from NW OH
    While waiting for the column drop parts to arrive next week I thought I would install the engine/trans to check for clearance to the F1 steering box and sure enough the exhaust manifold contacts the steering box because the exhaust manifold (1937) bumps out to allow clearance for the dipstick tube. Is there any cast iron V8 exhaust manifolds that would work or will I need to switch to fabricated header exhaust? Thanks.
  23. sknz
    sknz
    from NW OH
    Back on the project after a trip to south FL. Talked to Victor at Red's Headers and he is making me a set that will work with the V8 and F1 steering. Also have some exhaust tubing and flanges coming. I decided to do something with the windshield so I received a set of 2" chopped folding windshield stanchions from John Williamson that are top quality.
    I had some difficulty removing the original stanchions which were probably never off the car. Once off the posts were very rusty.
    I decided to try the cleaning function on the laser welder and gave it a try. It took a minute or less to evaporate the rust. Laser cleaning is not for everything but worked fine for this.
    A little primer and paint and the stanchions should be ready to mount.
  24. sknz
    sknz
    from NW OH
    Well I did something rather stupid when I decided to use the laser welder cleaning function for the rust on the stachion posts. I thought to use masking tape to prevent the laser from burning the surrounding paint but thought gorilla tape would work better. Big mistake! Worked great until removing the gorilla tape also removed the paint!
    So I just brushed a little paint that came with the car and I think it will be fine. Just need to fix the pinstripe.
  25. sknz
    sknz
    from NW OH
  26. Jeff34
    Jeff34
    I built a custom drop. I cut mine in half, and added a piece in the middle to drop the column to the right place. I'll find a couple of pictures and post them...
  27. Jeff34
    Jeff34
    Here’s some pics of what I did
  28. sknz
    sknz
    from NW OH
    Jeff34 likes this.
  29. sknz
    sknz
    from NW OH
    So I had not planned to chop or lay back the windshield but a couple of H.A.M.B. fellows made the suggestion and the more I thought about it the better I liked the idea. This is not intended to be a lowered, fat tired hot rod but more of a how would you do it in 1937 when you had a $25 obsolete model A and could go to the junk yard and get a V8 out of a wreck for a few bucks and soup up your A 4-banger. So a 2" chopped windshield frame with lay back stanchions and now just need to get some gl*** installed and I think the look is much improved. Thanks for the suggestions!
  30. banjorear
    banjorear
    I have a muffler shop bend a piece of tubing to clear the firewall on my '28. I then used a muffler bell flowering drive to make the flange after I heated the end cherry red. Came out nice and looks stock. Just an idea.
    sknz likes this.
