Technical 1 More 32 Ford P/U ? (Stock Front Seat)
Discussion in 'The Hokey Ass Message Board' started by Johnny Gee, Feb 15, 2026.
  1. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I’m looking for totally all stock seat pictures (internet is of no help) and how one access’s the fuel tank per 1932 factory design. Thanks
  2. krylon32
    krylon32
    from Nebraska
    Bottom cushion is split in the middle, 2 separate cushions.
    Johnny Gee likes this.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    The gas tank is the riser for the base cushions correct?
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. krylon32
    krylon32
    from Nebraska
    Right or wrong I've had one 32 pickup that had split lower cushions.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not saying right or wrong either per the pic I posted. Just wanting to know how Henry pushed them out the door.
  7. alchemy
    alchemy
    Johnny, that pic ain’t right. As you can see, the cushions are messed up, and not stock. I have seen stock Henry wood bases for the two piece cushions of a 32.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    @alchemy is the the gas tank the riser or is there a surround/riser that finish’s it off?
  9. alchemy
    alchemy
    The tank is all there is. There are bumps up under each **** that each cushion fits over, so they don’t slide off.
  10. Taboo56Chevy
    Taboo56Chevy
    Yes the 32 tank is the riser for the seat bottom. The bottom is split with the cap being under the drive side. I have seen 33 big trucks use the same setup, I am guessing its carried over for a bit before being changed. The driver cushion is pretty much just sitting on the tank, you just yank it out to get to the cap.
    The seat riser for a 33/34 pickup is the harder thing to find, so I know of guys using a 32 tank in its place of a riser in a 33/34 cab.
  11. Taboo56Chevy
    Taboo56Chevy
    from the p***enger side, but a correct stock 32 pickup split seat. 634901998_2150218605723661_1866484536943570569_n.jpg
    uncle buck, Johnny Gee and dwollam like this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Thanks to all that replied. Now I have a game plan.
  13. wheeltramp brian
    wheeltramp brian
  14. alchemy
    alchemy
    I sat in Hot Rod Pro’s 32 pickup a couple years ago, and fit just fine. I’m six foot and two hundred. His seat is stock on the bottom, but he thinned the backrest so you sit a little bit back from Henry’s design. Didn’t take much to make it as comfortable as possible.
  15. krylon32
    krylon32
    from Nebraska
    My deuce pickup runs a stock style 14 gallon tank under the rear of the box. The top of the stock 32 tank is cut out and houses the Odyssey battery lying on it's side. The seat cushions are some kind of late model seat with springs shortened and thinned to fit. Very comfortable.
