Projects Model A roadster pickup (Help/Advice needed)
Discussion in 'Traditional Hot Rods' started by Brendan1959, Feb 6, 2026.
  1. Brendan1959
    Brendan1959
    Hi
    I was building a speedster but have had a change of heart and am now building a roadster pickup so I think a new thread is in order.
    I picked up some rusty swap meet bits and have spent many hours cutting and welding patches.
    the collection came with a cowl one very bad door and a repo rear section with 2 repo longer door skins. I am building the door inners from RHS and using original style locks.
    I don't have a set of original hinges, but I do have a set of Tudor? hinges.
    Can anyone see a reason why I can't modify them to fit? Below are some picks of what I have, I do have a roadster that I could measure off buts is about 3 hours away and I won't see it for a few weeks.
    Any advice is gratefully accepted.
    Brendan photo_2026-01-31_15-54-04.jpg photo_2026-02-07_12-31-01.jpg photo_2026-02-07_12-31-04.jpg photo_2026-02-07_12-31-08.jpg photo_2026-02-07_12-46-27.jpg
    Dannerr, chlsnk, Okie Pete and 5 others like this.
  2. Brendan1959
    Brendan1959
    IMG_6940.jpeg IMG_6939.jpeg IMG_6938.jpeg Been welding up the holes in the hinges, this copper backed vice grip thing makes short work of the job.
    Dannerr, Okie Pete, treb11 and 2 others like this.
  3. The37Kid
    The37Kid
    [​IMG]That hinge on the bottom is from an open body A, notice how the closed body hinges above it on the body side are curved or bent backwards placing the pin in different centers. That will have some effect on things, so there may be some heating and bending in the future. Nice project.
    Bob
  4. chev34ute
    chev34ute
    That’s a lot of work, I’m piecing together a roadster pickup can myself to sell off to fund my 34 truck build. I ended up buying a set of open hinges from Early Times Autos, I think I payed around $200 for the set.
    Deutscher and Brendan1959 like this.
  5. Brendan1959
    Brendan1959
  6. Brendan1959
    Brendan1959
    RICH B, Dannerr, Okie Pete and 2 others like this.
  7. Brendan1959
    Brendan1959
  8. '29 Gizmo
    '29 Gizmo
    from UK
    Wrong style of hinge for a rpu. The position of the hinge pin is absolutly critical to get the correct swing of the door. The bottom hinges should be a different length. Get the right hinge.
  9. Brendan1959
    Brendan1959
    I hear you, however I had these hinges so I am giving it a go, I did drill the top hinge at the same place as the one piece of roadster hinge I have. I then used a rod through the top and bottom hinge to line up the pivots. I am trying to buy as little as possible not that I couldn’t find the funds, but I like using what I have and building stuff. If it doesn’t work I will buy some and it keeps me out of the pub. IMG_6989.jpeg
    BlueRon, Okie Pete, pprather and 5 others like this.
  10. '29 Gizmo
    '29 Gizmo
    from UK
    If it helps this is the top and bottom hinge positions on a stock rpu
    Dannerr, Okie Pete, hfh and 4 others like this.
  11. Brendan1959
    Brendan1959
    osage orange and Deutscher like this.
  12. Toms Dogs
    Toms Dogs
    from NJ
  13. anothercarguy
    anothercarguy
    You might try shimming the cowl at A-post...this should bring the back edge of your door up to better meet at the rear quarter panel. It will also even out the door gap at the rear edge of the door.
    Brendan1959 and osage orange like this.
  14. Brendan1959
    Brendan1959
    I don’t use my mill drill often, but I am glad I have it.
    Dannerr, Okie Pete, Moondog13 and 3 others like this.
  15. Grumpy ole A
    Grumpy ole A
    Nice setup to work on those doors
  16. Brendan1959
    Brendan1959
    Door skins on, that’s a lot of tap tap tapping.
    Pretty happy with them but I think I will have to move the hinges in a bit, considering slotting the hinges in the doors and making them adjustable.
    Tim, Okie Pete, dwollam and 1 other person like this.
  17. Brendan1959
    Brendan1959
    Red drilled and taped the door side hinges much better
    Tim, Dannerr, Okie Pete and 5 others like this.
  18. Brendan1959
    Brendan1959
    could someone please provide me with a measurement across where the the red strap is on the outside. I need to build an inner structure for the rear tub section, I would like the measurement at floor level as well but I know that is difficult to measure with a seat.
    Thanks in advance.
    Brendan
  19. Brendan1959
    Brendan1959
    IMG_7075.jpeg IMG_7074.jpeg IMG_7073.jpeg Ok next thought
    I have some tourer b pillars left over from a previous project, my tub rear is repo and somewhat floppy, I am considering grafting the b pillars into my repo tub which would have original holes for the latches and a nice brace at the bottom, what do you think?
    Dannerr, Okie Pete, Moondog13 and 2 others like this.
  20. Brendan1959
    Brendan1959
    Decided to go with the repo rather than the original posts, did some more work on the floor frame, came out pretty good. Next I got hold of the ****yist hood with broken off hinges, going to try and form up some replacements.
    May be awhile before I can get at it as I am going to have my prostate out next week, apparently they use a robot! IMG_7153.jpeg IMG_7152.jpeg IMG_7154.jpeg IMG_7155.jpeg
  21. Brendan1959
    Brendan1959
    Ok robot job done, not as much fun as you would think!
    Been working on the hood hinge, got some 1mm cold rolled cut to width. Made a little jig to bend them up easy to do and turned out ok I think.
    IMG_7205.jpeg IMG_7206.jpeg IMG_7207.jpeg IMG_7208.jpeg IMG_7209.jpeg IMG_7210.jpeg IMG_7211.jpeg IMG_7221.jpeg IMG_7222.jpeg IMG_7223.jpeg
    Dannerr, dwollam, Okie Pete and 4 others like this.
  22. dln1949
    dln1949
    Yep, where there’s a will there’s a way. Bunch of pretty cool fabricatin’
  23. Jeff34
    Jeff34
    Good plan on the RPU, and great progress! I'm following...
    That's my robot they used. I've worked for Intuitive for 30 years. Just retired at the end of February. I was employee number 7 back in the day. Now it's a company of near 17,000!!! Love the tech, and if I ever need surgery, I hope I can get it done with daVinci. Hope you're feeling well.
    RICH B, Moondog13, Outback and 2 others like this.
  24. Brendan1959
    Brendan1959
    Thanks Jeff, good job on the robot, not feeling too bad, they tell me before the da Vinci robot the road to recovery was long and hard. I had a quick peak at the robot before the put me under, reminded me of something from a sci fi movie.
    6 degrees of separation?
    Brendan
    dwollam, Okie Pete, Moondog13 and 2 others like this.
  25. Turns
    Turns
    Your build is progressing nicely
    Moondog13 and Brendan1959 like this.
  26. Outback
    Outback
    from NE Vic, Oz
    Good work Brendan, I'm a couple of hrs north of you. incase you are chasing parts Fred Ruigrok has model A parts, he's in the Eastern suburbs & is a top fella. can put you in touch if needed.
  27. Outback
    Outback
    from NE Vic, Oz
    do you still need the measurement across the back of the cab, there's an RPU cab here I can measure
  28. Brendan1959
    Brendan1959
    Thanks
    I know Fred, bought lots off him when I built my roadster years ago. I recently got the windshield Staunchens from him for this project.
    Brendan
    Outback likes this.
  29. Brendan1959
    Brendan1959
    The measurements would be helpful when you have time thanks
    Brendan
    Outback likes this.
  30. Outback
    Outback
    from NE Vic, Oz
    no worries. will check next time I'm in the shed
