Projects 32 5W Build - The $4K Swapmeet Body / The Old Chrome Coupe
Discussion in 'Traditional Hot Rods' started by NealinCA, Feb 2, 2023.
  1. NealinCA
    NealinCA
    Yeah...for sure. I am planning out the upholstery and just got a quote on that. Yee haw!
  2. NealinCA
    NealinCA
    Here's some reference pics for your viewing pleasure. You can get an idea where I'm headed...
    CCC-larry-watson-50-chevy-p1-08.jpg cusintart.6_large.jpg 400px-Jack-mcneil-1936-ford-7.jpg IMG_9904.JPG FF2.png Sein16.jpg 9BC1B3D6-F918-41AE-AAAA-93464869EAC7.jpeg 314966527_495764969238656_7054501324793112065_n.jpg IMG_9565.jpeg 437065171_7361046070656011_1555719209839680765_n.jpg 468328496_10162697489756967_7451185627582702425_n.jpg Page27-th.jpg Screenshot_20251211_090906_Instagram.jpg
    Rolleiflex, Tim, Okie Pete and 13 others like this.
  3. pprather
    pprather
    Chrome instrument panel on painted dash will look great.
    I agree chroming the dash is over the top and will not allow the chrome instrument cluster to pop off the dash.
  4. NealinCA
    NealinCA
    That's exactly my thought.
  5. Outback
    Outback
    from NE Vic, Oz
    can't wait for the the trim
  6. Speedy Canuck
    Speedy Canuck
    I hope you plan on getting the appropriate 'zebra' shirt to go with your interior when you debut this car!
  7. NealinCA
    NealinCA
    You may remember I made some simple jack stand points out of 1" square tube that bolt under the back of the running board, picking up the last 2 frame mounting holes.
    If you've ever worked on a full fendered 32 Ford, you know it's difficult to get jack stands under the rear frame if you need to pull the rear end.
    I wanted to make something fancier for the 5W, so I could have them plated. I figured out the center section of a Model T front axle had just enough straight I beam to make 2. I sawed, milled and drilled then did some grinding and think I now have something worthy of sending to the chrome shop...and they are made from old Ford parts!
    20260222_111518.jpg 20260222_111637.jpg 20260222_111956.jpg 20260222_112142.jpg 20260222_120957.jpg 20260222_122726.jpg 20260222_162417.jpg 20260222_163455.jpg
    And my frame is back from powder coat.
    The plan is to dry sand it, fill any imperfections, spot prime, sand, seal then paint both the lavender and dark purple outside portions and then clear the whole shebang. My friend doing the body and paint felt that the powder coat would get in around the K-member legs and other tight spots better than he could do with paint.
  8. AHotRod
    AHotRod
  9. Love the jack points you made. On my coupe, I did the exact same treatment to the frame. Way easier to keep clean, and it holds up to rock chips.
    Moondog13, 31chevymike and porkshop like this.
  10. dirt car
    dirt car
    from nebraska
    I'm sure the show circuit vehicles can benefit from the powder coat treatment but have heard from several owners that drive to various events have found it chips & creates a starting point for corrosion & peeling much like any painted surface, there may be various quality levels of coatings most are unfamiliar with, however looking at farm implement & lawn furniture that utilize similar coating systems it appears they are far from ideal in the real world.
    31chevymike and hotcoupe like this.
  11. NealinCA
    NealinCA
    Not all powder coat jobs are the same. Just like with any coating, paint, chrome or powder coat, proper surface prep and the correct product for the application make a difference. There are corrosion inhibitive powder coat primers and UV resistant top coats. I have some vintage steel lawn chairs that I had powder coated 10 years ago. They still look great.
  12. dirt car
    dirt car
    from nebraska
    Thanks Neal, I had often wondered about the level of quality powder coatings available, it would seem the newly manufactured goods are in the best world for getting good clean surface prep & procedures but then we have little clue as to the finish provided.
    31chevymike likes this.
  13. patman
    patman
    You could continue with the axle parentage and put some lightening holes in those too…
    31chevymike, rod1 and Tim like this.
  14. NealinCA
    NealinCA
    Gathering up components to rewire the 5w. I did kind of a quickie job to get the car to the Roc and GNRS 18 months ago.
    I am practicing cable lacing, as I want to go that route up under the dash and some of the engine compartment wiring.
  15. TERPU
    TERPU
    One Half Hitch over and over and over...... But man it looks great. Worth every hour.
  16. RMcCulley
    RMcCulley
    The wiring is going to look so nice with that extra touch.
    NealinCA, porkshop and 31chevymike like this.
  17. wheeltramp brian
    wheeltramp brian
    Did IMG_20190306_140858.jpg IMG_20190306_140945.jpg 20190911_141018.jpg 20191022_160108.jpg that on a 29 I built awhile back i built.came out nice.nevermind the temp zip ties
    warhorseracing, NealinCA, Tim and 6 others like this.
  18. Turns
    Turns
    This build is just killer................so good
  19. It's the obvious AND subtle details that will set Neal's 5 window apart from most hot rods...
  20. Troublemaker427
    Troublemaker427
    Any chance you will make the Roc this year?
  21. @NealinCA, I think we need a tech thread on how to string-tie like that. love it.
  22. NealinCA
    NealinCA
    I sure hope so. That is the plan, but there are a lot of factors out of my control (paint, striping, upholstery, gl***, chrome) from here on out.
    porkshop, 31chevymike and Deutscher like this.
  23. dirt car
    dirt car
    from nebraska
    I recall seeing the cable tie method on video here on the Hamb or elsewhere, hopefully someone will know
  24. NealinCA
    NealinCA
    dwollam, Hot Rod Ron, Tim and 2 others like this.
  25. hotcoupe
    hotcoupe
    If you really want to lace the wiring harness in accordance with government standards, several publications are available including SAE AS50881 - Standard for military aircraft wiring design and installation. I have a copy, but unable to locate it presently. It is just a pamphlet but it gives you very detailed information. With all the QUALITY work that has gone into this car it deserves the best.
    Tom
  26. alchemy
    alchemy
    With all the chrome work on this car, a fella would think Neal actually has a military grade budget. Adding another layer to the wiring shouldn’t break the bank. ;)
  27. RodStRace
    RodStRace
    Makes you wonder if there is non-conductive chrome thread! :D
    Bugguts, porkshop, Deutscher and 2 others like this.
  28. tim troutman
    tim troutman
  29. tim troutman
    tim troutman
    I found this 40 dash at a swap meet is was perfect for the car .it was just another back 40 but I would say its the black 40 with the chrome dash . the guy I got my 32 5 window had some extra parts for sale but also had a chrome dash which was the only thing he would not sell
  30. NealinCA
    NealinCA
    Wait a minute...Neal definitely does not have a military grade budget! I am building this car on as tight of a budget as I can...and still build a legit looking late 50's show car with all the bells and whistles. Part of the reason I'm 8 years in on it so far.
