Technical What are you working on?
Discussion in 'The Hokey Ass Message Board' started by Lloyd's paint & glass, Jul 18, 2022.
  1. Took advantage of another nice day to re-***emble the hotrod and started it up to see if the trans still leaks.
    It does. Damn!
    Oh, and also the engine drain plug continues to leak even after I bought a new drain plug. The black plastic washer that was supposed to seal and prevent the new plug from leaking broke when I tightened it. I'll solve that by finding a nylon or hard rubber washer. I did replace the O-rings on the Holley's transfer tube. That no longer leaks but the accelerator pump does leak now.
    I'm most of the way through dis***embly again and should have it out by later this week. I'll check the torque on the pump bolts one more time, inspect the new seal, the torque converter and the transmission case itself looking for cracks that I may have overlooked. If I can't find the obvious, I'll take it to a transmission shop I trust and let them have at it. I was thinking there should be some way of pressurizing the transmission to see where the leaking is coming from but I don't know how to do that. I might try to cobble up something to pressurize the torque converter as I saw an example of that sometime in the last few months on the HAMB. That will help determine if there's a crack or leak in the converter.
    Okie Pete, porkshop and Sharpone like this.
  2. Find an Aluminum one, it won't split. JW
  3. Black_Sheep
    Black_Sheep
    Working on door panel inserts this evening. In the morning I can wrap the inner panels and set them aside until I attach them to the “engine turned” insert panels. IMG_0207.jpeg IMG_0212.jpeg
  4. Black_Sheep
    Black_Sheep
    I got the inserts wrapped and the door cards foamed. Once the door cards are covered with white vinyl the molding and inserts will be installed for the last time…
    IMG_0213.jpeg IMG_0215.jpeg IMG_0217.jpeg Done for today…
  5. Black_Sheep
    Black_Sheep
    Door panels done, I’m starting to rethink the green inserts…
  6. rattlecanrods
    rattlecanrods
    Agreed. Looks good as-is. You can always add the pleated panels in later. Good looking work.
    What chtome/stainless edging did you use for the turned panels?
  7. Black_Sheep
    Black_Sheep
    The molding is from an early Mustang “Pony” interior, although they go the opposite direction on a Mustang.
  8. atch
    atch
    One more vote for leaving the green panels off. Looks good as is and I believe that the green will detract from it.
  9. Outback
    Outback
    from NE Vic, Oz
    nothing exciting here, just chasing some free play in the steering IMG_20260221_162104.jpg
  10. HOTRODPRIMER
    HOTRODPRIMER
    Finally got started work on the Damaged front end on the Ranch Wagon, I have managed to find and replace most of the damaged parts, my pal Dave is once again involved in the reserection of the Wagon, the damaged sheet metal; has been taken off a long with the splash apron, the bumper and ***orted pieces.
    The radiator was removed last year and a new core installed, the sheet metal is at the sandblasters and just a few pieces remain to be removed. HRP
    The damage.
  11. tomcat11
    tomcat11
  12. WZ JUNK
    WZ JUNK
    from Neosho, MO
    Making progress on the Harleyford. A track T powered by a Harley Davidson tempImageVBxSiN.png tempImageXcc8GI.png tempImagel3kHNl.png
  13. swade41
    swade41
    from Buffalo,NY
    I got the little Willys done for now, still needs "Sleep at Violet Springs" on the deck lid and brakes.
    I went from neglected
    To running polished street roddy
    To g***er "Hot Rod"
    The satin clear over the gloss gray worked out great, easy to clean but looks like primer
    enloe, 300racr, 61Cruiser and 14 others like this.
  14. AldeanFan
    AldeanFan
    Starting on the vintage air install in my wagon.
  15. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Final prep to drop the cab this week. Unfortunately there is issues with how the rear end was placed showing up after removing the bed (not centered, pinion pointing down). :mad: More rework. Go figure. IMG_5363.jpeg IMG_5364.jpeg
  16. lostn51
    lostn51
    from Tennessee
    Not a car but definitely auto related. Since I have a climate controlled garage I don’t like raising the door to run a vehicle in it, plus the fumes always come back into the thing and g***es me out so I installed a port for a hose to vent the fumes out. Honestly I think everyone should have one of these just because and it’s not all that pricey. The hose, adapter for the tailpipe, and the port were around $400. They do have the adapters for dual exhaust and they come in different sizes to accommodate whatever size exhaust you’re running.
  17. Black_Sheep
    Black_Sheep
    Been down for the count the past few days, I stayed in the house and made a seat bottom for my grandson’s Tot Rod…
    enloe, Okie Pete, Sharpone and 16 others like this.
  18. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Done all I can do by myself. Time to call over a neighbor, someone to help lift and set it down. IMG_5365.jpeg IMG_5366.jpeg
    enloe, Okie Pete, Robdski and 18 others like this.
  19. Johnny Gee
    Johnny Gee
    from Downey, Ca
    No sooner than the neighbor tow truck driver Ray and I place the cab on the frame. Carina goes and pulls a Tim Allen on me. IMG_5374.jpeg Now Carina’s picture withheld for good reason’s, but the crime scene remained. IMG_5373.jpeg IMG_5372.jpeg
    enloe, Okie Pete, JohnLewis and 17 others like this.
  20. Johnny Gee
    Johnny Gee
    from Downey, Ca
    enloe, Okie Pete, Robdski and 12 others like this.
  21. I stopped the AOD from leaking on my '29AA. Saltflats reminded me to check the transmission pump bolts inside the bell housing. Sure enough, two bolts were not torqued down tight enough to keep the high-pressure trans fluid from seeping. He nailed it! Now to adjust the TV cable and take it for a first drive.
    I'm about to turn 77 and getting up and down, up and down, crawling under the truck to re-install the transmission, hook up the driveline, re-attach exhaust pipes and wires, etc. is grueling. Why do I still do this? I think it's because I want to finish what I started nearly 52 years ago. Will it be a showstopper? Hahahahaha, hell no. It will run, stop, steer, change gears and maybe carry a load in a bed I have yet to fabricate.
    What comes next? Seat belts, gl***, finish the exhaust, the roof, upholstery, fabricate a fan shroud, little things like a strong spring to hold the brake pedal in the off position, front turn signal lights and a bumper.
    Okie Pete, Robdski, Sharpone and 11 others like this.
  22. saltflats
    saltflats
    from Missouri
    Good to hear you got the leaks fixed and can move forward. I have a buddy that has some years in his build but not near as long as you. I see his pain and determination many times. Reminds me I need to revisit that project to boost it along.
    Okie Pete, Sharpone, porkshop and 4 others like this.
  23. Black_Sheep
    Black_Sheep
    I spent several hours dismantling the bench seat for my truck. Had I known that GM molded the springs inside of the foam I probably would’ve gone a different route. The seat bottom is twisted 3 - 4 inches so I’ll have to figure that out, but it’s square and the springs are in good shape. After sweeping up the big chunks I had to blow out the shop with a leaf blower, what a mess…
    Okie Pete, Robdski, swade41 and 9 others like this.
  24. mad mikey
    mad mikey
    Working on the upholstery in my trunk area on the coupe, will try and get some pictures tomorrow of some progress. It is supposed to be near 60 degrees, can get something done without freezing and or running heat in the shop. I got one panel built, fitted and upholstered today.
  25. 5w Jen
    5w Jen
    from Sweden
    Got our 354 Valve Covers back from plating, they spent a lot of time straightening out many dents and filling in rust pitting with layers of copper. We are very happy with the result. Not affiliated but it was done here https://galvenchrom.com/en/
  26. buddyamigo
    buddyamigo
    from HoustonTX
    IMG_3027.jpeg Put some 56 Olds Super 88 taillight lenses on the 53. Then a bit of motorvating around town. A good day.
  27. Those look great! They are far better than the stock lenses and look period-correct for an early '50s custom.
  28. mopacltd
    mopacltd
    I did the same thing in 1966 on my Ford
    Okie Pete, Sharpone, porkshop and 2 others like this.
  29. saltflats
    saltflats
    from Missouri
    I smoked some ribs. Delete if need be :oops:
