Projects 39 Ford Conv build (update 2/24/26)
Discussion in 'Traditional Hot Rods' started by ronzmtrwrx, Jan 10, 2021.
  1. ronzmtrwrx
    ronzmtrwrx
    Wow. Nice. Looks like we are thinking along the same lines.
    Stogy likes this.
  2. ronzmtrwrx
    ronzmtrwrx
    I ***ume so, but the original floor had only those stiffeners that ran parallel with the rockers and nothing going across the floor toward the tunnel. I just left those that went across and added what I could of the originals.
    Stogy likes this.
  3. ronzmtrwrx
    ronzmtrwrx
    I’ve been trying to grab an hour or two here and there in an attempt to get the floor pan work finished. I had to make the rear portion of the driveshaft tunnel wider to clear the extra arms I put on the rear end to support the open drive conversion. The floor pan just to the rear of the main floor is not reproduced for a convertible as far as I know, so I had to make it. First off was to make the rear section of the tunnel which needed to be tapered to mate back up to the front floor tunnel. IMG_2450.jpeg I made it in a slip roll but it was only 24” wide and the tunnel needed to be about 27” long. No problem, I’ll just add the extra 3” to the front of it so it will overlay onto the front tunnel and plug weld together. After getting it fitted and cleco’d in, some quick posterboard patterns were trimmed to fit. IMG_2501.jpeg
    Cut the pair of panels out of 18 gauge and a quick run through the bead roller, and test them for fit. IMG_2502.jpeg
    Close enough, so I tig’d them to the tunnel this evening and after some quick metal finishing, I’m satisfied with them. IMG_2519.jpeg Next up will be the transition from rear tunnel to front portion. ……..Stay tuned.
  4. hotcoupe
    hotcoupe
    Very nice work as always, looks like a factory installation!
    Tom
    Algoma56, Stogy and ronzmtrwrx like this.
  5. hotrodA
    hotrodA
    Nice work! Keep the updates coming, they’re a must read
    ronzmtrwrx likes this.
  6. ronzmtrwrx
    ronzmtrwrx
    Thanks !
