Features Coolvairs Lets See Them
Discussion in 'The Hokey Ass Message Board' started by dons t, Jun 19, 2007.
  1. hrm2k
    hrm2k
    I finally got both axles in. What a pain in the ***. I need 2 new controller arm brackets and it will be ready to terrorize East Baltimore
  2. hrm2k
    hrm2k
    My old control arm bracket was, to say the least, a real piece of ****. So, with the new 4:10 gears, I decided to build a completely different control arm bracket. Once the final drive was in place, I got to work with some thick wall tubing and some 1”x 2” rectangle tubing. The first picture shows our original idea. The second picture shows the finished brackets today. IMG_3264.jpeg IMG_3272.jpeg
  3. pvfjr
    pvfjr
    With the 10-bolt diff cover instead of 8, I think that'd make it a 68-78? Just my guess.
  4. hrm2k
    hrm2k
    78 was the last year for the TH425
    chryslerfan55 and patsurf like this.
  5. hrm2k
    hrm2k
    After some finish welding and powder coating, it came out exactly as planned. For those of you thinking this is ********, let me explain. While functioning as a control arm bracket, it is really just the camber adjustment. There is no lateral movement in this setup. Unlike the Corvair and Corvette setup where everything has a twist factor built in. This is trailing arm up and down only movement. Anyway, here is how it looked after installation IMG_6907.jpeg IMG_6906.jpeg
    Can’t wait to get it on the street to see how the 4:10 Posi feels :D
  6. hrm2k
    hrm2k
    Finished !!!
    Beat the hell out of the rear suspension this afternoon. I need to buy stock in a tire company…seems they might be short lived :rolleyes:
    It is super quick. Scared the hell out me in a short few minutes. I put it back on the lift for one more round of tightening everything. I was super pleased with how everything worked and the fact that nothing had changed. Might be early but so far, so good !!!
  7. Acres
    Acres
    from Sweden
  8. 409 Bob
    409 Bob
  9. 29Sleeper
    29Sleeper
    from SoCal
    chryslerfan55 and SAM3 Customs like this.
  10. 29Sleeper
    29Sleeper
    from SoCal
    That guy started out up on Foothill in Upland - when they kicked him out he moved south. It came to an end in 1991:
    The majority of the 120 Corvairs in Jim Phillips' collection that were seized by San Bernardino County authorities in late 1991 were likely crushed or sold for s****.
    Phillips was unable to afford the escalating towing and storage fees of over $10 per car per day. Although the county initially considered an auction because the cars might have special value, a county representative indicated the sale would only be open to dismantlers, and the vehicles would have to be sold for s**** metal.
    Phillips managed to save at least one Corvair pickup truck by moving it before the county's operation began, and hoped to save several others, but it is implied most of the collection was lost to the s**** yard. The cars, which had fallen into disrepair and been vandalized while sitting on a vacant lot in Montclair, were towed to an impound lot in Fontana. Phillips had a 30-day period to reclaim them, which he could not afford
  11. Jalopy Joker
    Jalopy Joker
  12. chevy57dude
    chevy57dude
    @hrm2k - Glad you're making progress, John!
  13. hrm2k
    hrm2k
    Thanks Steve
    NO longer hidden in the Maryland HAMBers , how's the 55 coming ?
  14. chevy57dude
    chevy57dude
    Picking at it! But progress, none the less.
  15. hrm2k
    hrm2k
    Making modifications.
    All that carpeting….DOA. glue just ate the back away.
    Should do a shout out to the chimney wrap foil backed asphalt pressure sensitive makers. Had to use my Brenzo matic and a few putty knives.
    Now visible on both sides of the car, frame connectors.
    Tomorrow, the roll cage gets installed.
  16. hrm2k
    hrm2k
    IMG_3332.jpeg Had a bunch of fun today. The holes for the roll bar have been drilled into the frame connectors. While thinking about our next step, it dawned on me that I had bought a 300 piece header modeling kits….sort of like yellow legos . What a dream to work with. We wanted to hide the back down bars and the pieces allowed us to actually build the back down bars with the yellow stuff. It turned out beautiful
    [​IMG] [
  17. hrm2k
    hrm2k
    Time to do some welding in my 65 Coupe
  18. hrm2k
    hrm2k
    Still more progress on the roll bars. Next will be the swing out bars by the doors
  19. HOTRODPRIMER
    HOTRODPRIMER
  20. HOTRODPRIMER
    HOTRODPRIMER
    How about the John Finch Phonix corvair. HRP
  21. hrm2k
    hrm2k
    Got the cross bar in place. I made it so I could remove it to get to the engine
  22. I don't know why but your pictures in your last two posts don't show up for me. This is what I see. [​IMG] Your previous pictures show up.
  23. banjeaux bob
    banjeaux bob
    from alaska
  24. hrm2k
    hrm2k
    NEXT GIANT STEP !!!!!!
    Insulation, interior installation, terrorize East Baltimore …in that order
  25. Smokeshow
    Smokeshow
  26. hrm2k
    hrm2k
    Big tires for a twin turbo set up
    Moriarity likes this.
  27. SAM3 Customs
    SAM3 Customs
    from Michigan
    I'd like to see this Corvair. Unfortunately the photos don't show up for me either.
  28. jnaki
    jnaki
    Hello,
    Your photos may have changed the ***le or moved from the photo file on your computer to another file. If the original folder on your computer or slight "space" just happens to be on description of the new position photo, then this:
    upload_2026-5-12_10-10-36.png will show up.
    Also, sometimes your phone camera will take the photo and it is on your pictures folder. but, it will not transfer due to the photo being too large for the computer to acknowledge. you will have to save the photo to your computer and resize it smaller and save with the name you want. Try not to keep the long numerical label the camera/phone gives the photo taken.
    Jnaki
    Most of the time, folks like posting photos from the phones as they are quick and handy. But, they also don't allow a person to judge the size of the photo for posting and also, sometimes the phone has moved slightly and the photo is blurry. so, take the photo any way you can. then allow your laptop or home desktop computer to use their built in photo program to show you what you need to do to make the color nice and not blurry. and to make sure your photos are in focus.
    One last thing is that with your computer or laptop programs, you can edit out the unnecessary "looky loos" or other cars in the photos. YRMV
  29. mr.chevrolet
    mr.chevrolet
    found my stinger pics, built & owned by one of Yenko's race mechanics, Warren Denoshak. 20190609_112821.jpg 20190609_112834.jpg
    Jalopy Joker and anthony myrick like this.
