Technical The upholstery thread to end all threads
Discussion in 'The Hokey Ass Message Board' started by Roothawg, Jan 5, 2021.
  1. chryslerfan55 likes this.
  2. jakesbackyard
    jakesbackyard
    from ND
    Finished up another patina’d Chevvy box side chair. There’s now a pair out there…
  3. meteorpete
    meteorpete
    Love this thread. Hoping someone can give me some technical ***istance. I picked up a Singer 211. I had it serviced and the guy told me it was ready to go. I am having a problem with the upper thread (black in photo, bobbin thread is gold) getting stuck in the bobbin area and becoming a 3rd thread! Another way to say this is when I lift the foot and pull the material away from the machine there is resistance and there is a piece of the top thread now underneath the fabric that is stuck in the bobbin area and it breaks as I pull the material away. I then have to clean this extra piece out of the bobbin area before starting again. Does this make sense? I hope the photos help explain. Kinda at my wits end here as I just want to get sewing! Thanks! IMG_7857 1.JPG IMG_7858.JPG
  4. K13
    K13
    Are you turning the feed wheel towards you to make sure the s***ch is complete and the needle is at its highest point before you pull out the material? If you don't the s***ch isn't complete and will catch. Your picture looks like the needle is still partially down.
    Black_Sheep and chryslerfan55 like this.
  5. G-son
    G-son
    from Sweden
    Try rotating the machine to different positions before pulling the item out. The top thread is pulled down around the bobbin once per s***ch, trying to remove it during that process may cause the problem you are experiencing.
    Sporty45, Roothawg and chryslerfan55 like this.
  6. meteorpete
    meteorpete
    Yes, I am doing that. Thanks for the reply K13.
  7. meteorpete
    meteorpete
    Okay, I will try this tomorrow with more patience! Thanks
  8. K13
    K13
    If you turn the wheel while you are gently pulling the material you will feel when the s***ch lets go. You are in the middle of a s***ch that's why it is pulling up three threads
  9. meteorpete
    meteorpete
    I want to thank you guys (G-Son and K13) for the great help. Such a small thing but it was driving me nuts. I just put some tension on the piece and turn the wheel slightly and it slides out every time! Can't wait to get started on my Model A seats!
  10. RICH B
    RICH B
    @meteorpete
    You are probably aware; but just in case, a slight downward pressure on the treadle will release the brake and make the handwheel easier to turn.
    meteorpete likes this.
  11. Roothawg
    Roothawg
    It's hard to believe it's been 5 years since I started this thread.
    A lot has happened since then. I need to get the new upholstery shop lined out. We are still unpacking etc. I will be nice to be back to normal.
    Im still a hack,when it comes to sewing, but regardless thanks to all who offer up their experience on this thread. ( no pun intended)
    echo ed, 6inarow, Sporty45 and 4 others like this.
  12. whateverit takes
    whateverit takes
    from Florida
    Just wanted to echo meteorpete's thanks. I have the same machine and repeatedly experienced that same problem. I will give that solution a try in the near future.
    Roothawg likes this.
  13. F-head
    F-head
    Here’s the first piece for my 39 ford
    Squablow, 6inarow, drdave and 10 others like this.
  14. I’ve never sewn anything before. Just finished this practice seat bottom. I started sewing November 30th 2025. No schooling or mentoring Just wasted a few videos and asked a couple questions from a couple guys who are upholsters. It’s not perfect but came out decent.
    Squablow, 6inarow, 3quarter32 and 5 others like this.
  15. You always putting out amazing work. Been following you for a while on instagram.
    F-head likes this.
  16. F-head
    F-head
    Cool thanks
    Looks like you’re doing great yourself
    Kustom love 101 likes this.
  17. One night I couldn’t sleep cause I was trying to figure out who those upholstery guys got those deep *** tuck and roll. Then I think I figured it out and gave it a try. Took me about two different styles to get what I feel was that stuffed look and yes it is stuffed.
    mad mikey, drdave and F-head like this.
  18. Black_Sheep
    Black_Sheep
    I did a small test piece to determine shrinkage for 1.5” pleats on 1/2” sew foam and to see if white or light green top s***ching would look better. I also played with s***ch lengths. Online videos recommend 1/4” s***ch length on vinyl, but I like the look of 3/16” s***ch length. What would be the downside to using the shorter s***ch length? Does it even matter? FWIW I think the green s***ches look marginally better, it’s the closest match I could find to the vinyl color…
    Squablow, 3quarter32 and drdave like this.
  19. 1946caddy
    1946caddy
    from washington
    Bing Videos
  20. F-head
    F-head
  21. Taco Bob
    Taco Bob
    Here's the interior I did on my pickup. No sewing on the door panels. Just some leather, 3/8 volara foam, a v cutter and landau top and trim glue IMG_20220731_133036693_HDR.jpg IMG_20220704_230342905_HDR.jpg IMG_20220526_202537192_HDR.jpg
  22. Black_Sheep
    Black_Sheep
  23. K13
    K13
    Been slowly working on my Riv.
  24. chiro
    chiro
  25. jakesbackyard
    jakesbackyard
    from ND
    Finished up some seats out IMG_7714.jpeg IMG_7715.jpeg IMG_7764.jpeg IMG_7765.jpeg of a 1962 Dodge Polara. Was a big job. Had new foam buns for buckets that didn’t fit worth a darn. Had to reshape them to work. No foam available for rear which used molded and shaped foam to simulate a bucket appearance. All made from scratch from the springs up. Had to walk away more than once. lol. Good thing I’m retired and can do that. Made to duplicate the original design and color.
    lucky, drdave, Shadow Creek and 10 others like this.
  26. nrgwizard
    nrgwizard
    from Minn. uSA
    Looks pretty nice from here... :) .
    Marcus...
  27. Roothawg
    Roothawg
    Just keep at it and maybe they'll put you on full time....;)
    RAK likes this.
