Technical ***March 2026 Banger Meet Thread - Time Changes***
Discussion in 'Traditional Hot Rods' started by Jiminy, Mar 1, 2026.
  1. Jiminy
    Jiminy
    Link to previous month: Februdreary 2026 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Sunday March 29th Hot Road Blowout at Mere Mere Dragstrip
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    https://eraspeed.com/
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    G Baese likes this.
  2. Outback
    Outback
    from NE Vic, Oz
    winduptoy likes this.
  3. Airborne34
    Airborne34
    from Texas
    Checking in!
  4. 4BangerDean
    4BangerDean
    I thought the same thing.
  5. winduptoy, Outback and hotrodfil like this.
  6. It is.
    winduptoy and Dannerr like this.
  7. I don't blame you - I'd lååååååve a Model 40-C! :-D Hope to see it irl someday. :)
    Better check in properly. :D
    Nothing much going on here, except "12'eren" needs to be upgraded to new Rømø requirements, so on the install-list is;
    - lap belt - got a back seat lap belt out of an old Jeep and just picked up some chains at work, and
    - front brakes.
    I also need to check my MC helmet against raised demands. I know, it's safety first, but I can't help feeling, that it looses abit of it's soul... but hey, better inaccurate racing than no racing!
    But that also stirs attention away from hopping up the G28T - just haven't got enough hours in the day! ;) So, later that'll be (again!). :D
    jet996, winduptoy and Outback like this.
  8. 62pan
    62pan
    Checking in
  9. Checking in, been busy
    This is the Record holder at El Mirage and Bonneville V4F/GMR and V4F/FMR
    Built up on a Model "A" block
  10. Stan Back
    Stan Back
    Congratulations! What are the speeds?
    Vintage 4-Cylinder Flathead / Gas Modified Roadster
    Vintage 4-Cylinder Flathead / Fuel Modified Roadster
    winduptoy, Dannerr and rwrj like this.
  11. What a beefy head, I spot a Kong cover!!!
    Deutscher and Outback like this.
  12. Stan,
    133.8 at ElMo
    131.4 Bville, 137 exit on quali p***, broke a lifter on 2nd run so on 3 cyls.
    J
    jet996, Deutscher, winduptoy and 5 others like this.
  13. burl
    burl
    from Minnesota
    Checking in. Been busy and not much time for hamb. Made up a transfer block to run the chevy 6 cly pump on the model a. Took two tries to get the 16 tpi machined for the cap. Not John Neilson level of engineering but I'm trying
    jet996, Deutscher, brjnelson and 7 others like this.
  14. Burl,
    You make much more practical equipment, Good on Ya!
    Is the head o-ringed between the two parts? It really looks good.
    John
  15. Steves46
    Steves46
    from Florida
    Looks like my pressure plate has seen better days. Now on to ordering parts.
    jet996, Deutscher, winduptoy and 2 others like this.
  16. Dan from Oakland
    Dan from Oakland
    Just looks like someone over greased the throw out bearing. Is the clutch slipping or?
    Dannerr likes this.
  17. Yeah - any details on the head? Purty on the outside; what's the chamber look like?
  18. Stovebolt
    Stovebolt
    Not much news.
    my fellow banger fan has just machined the repop 2x2 intake for my coupe. It was nowhere near flat on the carbie bases, and worse on the block side.
    it’ll be interesting to see how the B runs with 2 81’s.
  19. winduptoy
    winduptoy
    Good to see you banger boys...
    in my mind, the one drivetrain upgrade that makes the A/B more driveable is to a V8 clutch
    I guess this was my check in....I had a Hot Rod shop get me busy on non-banger stuff and I should have said 'NO'
    but I am trying to impart some tribal knowledge to the youngsters....
    My projects....T is back together and the test drive was fun
    Vicky is stalled....
    Little outing in 26 degree F weather to the first Cars and Coffee last Saturday in the Cabriolet....it started and ran fine in its non heated storage.....for the first time in 6 months....win!
    jet996, Deutscher, G Baese and 4 others like this.
  20. Steves46
    Steves46
    from Florida
    Yep but despite the grease, my clutch will not disengage with the pedal down. If you compare the left finger to the other 2, something is wrong and most likely the root cause of the problem.
    Dannerr and Outback like this.
  21. burl
    burl
    from Minnesota
    Nope just good ol red rtv
    I've used on a couple others with success
    Deutscher, Dannerr and Outback like this.
  22. brjnelson
    brjnelson
    The comp chamber is top secret, and can not be shown. I have seen it and it is not like most designs.
    jet996, Deutscher, 5280A2 and 2 others like this.
  23. Anyone using Dan Price’s D4B head? I’d like to fit a head to the ‘34 that allows me to use the stock short water pump and mechanical fan. I ran a Thomas head for a few years and liked that.
  24. brjnelson
    brjnelson
    I believe he had to sign a disclosure agreement just to use the design;)
    Here is a different design if you wanna see a CNC machine head it’s not 80% done
    hotrodfil, jet996, Deutscher and 5 others like this.
  25. jet996
    jet996
    from WY
    Checking in -actually had a little snow this morning. Extremely warm and dry winter for us, but I've driven the wheels off the p/up! IMG_0763.jpeg
    burl, hotrodfil, brjnelson and 6 others like this.
  26. Kevin Pharis
    Kevin Pharis
    from Califunny
    Ran outta February already…?!
    Made some special compensators for the dual S-B Winfield setup on my T speedster, as I need to pull some fuel out of the accelerator charge. Went on a 100 mile drive today, mostly twisty mountain roads at bout 30-35mph. Much better, but not quite there yet. Will lower the float levels and try again soon. Sure runs good when floggin it hard tho!
    burl, Crazydaddyo, Dannerr and 4 others like this.
  27. I was hoping to reach out to Roy Creel, as he has some experience with Gemsa heads. Does anyone know his email by any chance?
