Featured Hot Rods 354 Hemi vs SBC
Discussion in 'The Hokey Ass Message Board' started by j0ebeer, Mar 2, 2026.
  1. j0ebeer
    j0ebeer
    Current 34 Ford 3w has a 350 SBC but I have a 354 Hemi in the shop. The Hemi is not complete but I do believe I have most of the major parts. The question is, is it worth it to build the 354 and swap out the SBC. Thoughts?
  2. SEAAIRE354
    SEAAIRE354
    Is that even a question? Sorry I’m a little biased.
  3. DDDenny
    That's between your accountant and yourself!
  4. TCTND
    TCTND
    Well, the hemi is a cl***ic, but that's a hefty lump of Detroit wonder metal in the front of a light car. I pulled the Olds 394 out of mine and inserted an aluminum headed 383 dressed like an FI 327. I know opinions will differ but after having had a Chrysler in my '39 a long time ago I just don't care for all that m***.
  5. ididntdoit1960
    ididntdoit1960
    from Western MA
    Nope - Build an FED or altered for the Hemi - keep well enough alone with the coupe
  6. dwollam
    dwollam
  7. Just Gary
    Just Gary
    If you're driving in a straight line or going hoodless or if you wanna impress the Cars & Coffee crowd, then definitely choose the Hemi.
    But if you're keeping the hood, or if you plan to drive the car agressively on twisty backroads, then the SBC is the better choice.
    I love my 354, but it adds 100 lbs to the front end compared to an SBC, and as a result, noticeably understeers.
  8. 57Fury440
    57Fury440
    Old Hemi would be my choice. It's a Hot Rod, not a road race car.
  9. Fitty Toomuch
    Fitty Toomuch
    from WVa
    You`d might have to run without the hood sides or modify with blisters, but your car looks perfect as is.
  10. LOU WELLS
    LOU WELLS
    from IDAHO
  11. Hemi for fenderless cars in my opinion
  12. warbird1
    warbird1
    Hemi... but, I'm a little prejudiced.
    Tow Truck Tom, Sharpone and Just Gary like this.
  13. partsdawg
    partsdawg
    from Minnesota
    I may get roasted for this but what the heck.
    I equate old Hemi's to old Ford flatheads.
    Everybody thinks they look cool.
    Everybody loves the sound
    Both are bucket list engines for hot rodders.
    Both take a whole bunch of money to get half the HP of a mild SBC
    Your car...your money...your decision.
  14. lostone
    lostone
    from kansas
    Hemi, speaks for itself....
  15. Doublepumper
    Doublepumper
    from OR-WA, USA
    It's your money. Spend it how you see fit.
    Tow Truck Tom and Sharpone like this.
  16. Roothawg
    Roothawg
    It's a loaded question. It's sort of like "How deep is a hole?" I guess you need to decide what you are after. What is the goal of changing it out?
  17. Bandit Billy
    Bandit Billy
    If you are a regular at Barret Jackson, you would already know the answer. The Hemi will provide a nice on the investment when and if that day comes. Until then you will have to keep some wet wipes handy if you build it to any level at all. Damn the hoods! Full speed ahead!
  18. RmK57
    RmK57
    Small block Ford gets my vote. 289 with Webers would look fantastic.
  19. Roothawg
    Roothawg
    Well, since we are doing hypotheticals, you could go the 390 route, either Caddy or FE.
    RmK57 likes this.
  20. willys36
    willys36
  21. RodStRace
    RodStRace
    What is your "worth it" as far as this is not primary transportation?
    The others have covered the fit, weight, cost and resale.
    Is it time to refresh the rest of the car? (BTW, it looks great)
    What trans?
    Same use or different too?
  22. Sharpone
    Sharpone
    Cool car tough choice but since we’re spending your money I say Hemi.
    Dan
  23. rockable
    rockable
    It's easy for us to say HEMI! but we dont have to pay for it or drive it. It's your car, build it your way.
  24. 19Eddy30
    19Eddy30
    from VA
    Depends if 354 for looks or Performance
    For Looks 354 ,
    If for performance and NA it needs MFI
    on Nitro or 13:1 on Alky plus :cool:
    Tow Truck Tom, Just Gary and Sharpone like this.
  25. 1935ply
    1935ply
    from peyton,co
    Hemi's are cool in the right car. I have a couple of them, but I would take your car in a heartbeat with a sbc and sure wouldn't want to remove the hood sides or blister them. If you need a new engine, rebuild the small block and keep the hood closed. Most won't know the difference. Although there are a few like me that look thru the louvers to see what's in there.
  26. RICH B
    RICH B
    Build a roadster around the hemi!
  27. Mr48chev
    Agreed 100% your car your way but in this case you way includes what is going to be and extra 4000 dollar investment over a 3fiddy.
    I've got a 56 Desoto 330 in the shed in pieces that has a lot of cool factor But the cost of buiding it to be up to it's potential of cool is high.
    dual 4 intake 1879.99 1956 1957 Desoto Hemi Dual Quad Intake 341 or 330 Mopar 4 Barrel 2x4 Manifold | eBay
    Just a complete gasket set 423.70 For 1952-1957 DeSoto S-15 276 291 330 341 Hemi Front Complete Engine Gasket Set | eBay
    I couldn't even find the complete rebuild kit that i had watched for years.
    Simply put, if you have the coin to do it right the cool factor is there and it has reasonable power but for half the money you can get a lot more power out of a 350. Bubba factor vs dollar per HP.
  28. 1946caddy
    1946caddy
    from washington
    The Chrysler 300B engine was rated at 340 HP, while the New Yorker and Imperial 354 engine configuration produced 280 HP. Dual 4-barrel carburetors and a more aggressive mechanical camshaft resulted in the increased power.
    Please tell me where I can get one of these mild SBC that produce 560-680 HP.
  29. 1946caddy
    1946caddy
    from washington
    https://www.hothemiheads.com/desoto/engine_block/gaskets.html
    Sharpone likes this.
  30. Hollywood-East
    Hollywood-East
    As mentioned, Build another around the Hemi... The car is Perfection as it sit$
