"New" Daily Driver Pickup "Project"
Discussion in 'Off Topic Hot Rods & Customs' started by guthriesmith, Dec 30, 2025.
  1. ***Area-51***
    ***Area-51***
    from Ohio
    Look good!
    What size are the BFG’s ?
  2. guthriesmith
    guthriesmith
    Thanks! They are 275/60/15 in the rear and 255/60/15 in the front which makes the front tires about 3/4” narrower and an inch shorter. Not much difference, but just enough in my mind.
    porkshop, 210superair, SS327 and 4 others like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    The white letters look great!!
  4. guthriesmith
    guthriesmith
    Wheel weight issue solved. Figured I better check lower a-frame to wheel clearance turned to the maximum amount since I expected to have to trim them back a bit. Heck, probably have an 1/8” or so of clearance…. I think I’ll trim them enough to at least double that. Also measured ground clearance under the lower a-arms. It’s right at 3-1/4” static. I’ll have to watch out for dead animals on the highway. Lol
  5. guthriesmith
    guthriesmith
    That whole wheel/tire and stance deal is real. :D
  6. gene-koning
    gene-koning
    The truck looks better then it did when you started. The white letters look OK.
  7. 33Doll
    33Doll
    A little comet and scrub brush every few months, no big whoop! Letters super easy over white walls. I think a 73-79 front is in the future though for that right 70’s look.
  8. 33Doll
    33Doll
    Here is my 78 f-50
    With T/As. 245/60- 235/70 up front I think
    Wish I still had it. Sold it for $1500 in 2006
    cause I was sick of smogging it
    stupid California!
  9. 210superair
    210superair
    from Michigan
    Looks great man. Gonna post a gif of you doing donuts in it when you get it running?!?!
    porkshop, guthriesmith and Sharpone like this.
  10. guthriesmith
    guthriesmith
    Probably not… Have you priced those BFG’s lately?!?! :eek:
  11. guthriesmith
    guthriesmith
    Decided I’m gonna try like heck to make this thing run this week! Tired of it just sitting on the lift and me not driving it. Plus, the radiator in my 51 sprung a leak, so now it’s down too until I get that fixed.
  12. rusty1
    rusty1
    ...I gotta say that looks just right,...good decisions on your part,...sits just rite...
    Sharpone, e1956v and guthriesmith like this.
  13. guthriesmith
    guthriesmith
    Thanks Sam! I wasn’t sure what you would think and appreciate your opinion.
    So, mainly worked on the 51 tonight but got to talking to some buddies about welding and remembered my butchered up PS bracket that has been bothering me. Decided to make it better this evening. Still need to grind it down and paint it tomorrow, but it doesn’t look quite as butchered now.
  14. guthriesmith
    guthriesmith
    I should have never said I was going to get this thing running this week…. I did spend too much time on the silly bracket last night, but that’s all I got done. :eek:
  15. 40FORDPU
    40FORDPU
    I've found I do my best work when I don't have a self imposed time schedule....bracket turned out great.
    Sharpone, porkshop, Okie Pete and 3 others like this.
  16. Ayers Garage
    Ayers Garage
    I ride bicycles. We have an old saying that seems appropriate for this situation.
    "No matter how slow you're going, it's still faster than those people sitting on the couch".
    drdave, Sharpone, RodStRace and 2 others like this.
  17. Okie Pete
    Okie Pete
    Looks good Jeff . It’s a time ****ing black hole when I start making or modifying parts and brackets . You’re making progress.
