"New" Daily Driver Pickup "Project"
Discussion in 'Off Topic Hot Rods & Customs' started by guthriesmith, Dec 30, 2025.
  1. ***Area-51***
    ***Area-51***
    from Ohio
    Look good!
    What size are the BFG’s ?
  2. guthriesmith
    guthriesmith
    Thanks! They are 275/60/15 in the rear and 255/60/15 in the front which makes the front tires about 3/4” narrower and an inch shorter. Not much difference, but just enough in my mind.
    porkshop, 210superair, SS327 and 4 others like this.
  3. Moriarity
    Moriarity
    SUPER MODERATOR
    The white letters look great!!
  4. guthriesmith
    guthriesmith
    Wheel weight issue solved. Figured I better check lower a-frame to wheel clearance turned to the maximum amount since I expected to have to trim them back a bit. Heck, probably have an 1/8” or so of clearance…. I think I’ll trim them enough to at least double that. Also measured ground clearance under the lower a-arms. It’s right at 3-1/4” static. I’ll have to watch out for dead animals on the highway. Lol
  5. guthriesmith
    guthriesmith
    That whole wheel/tire and stance deal is real. :D
  6. gene-koning
    gene-koning
    The truck looks better then it did when you started. The white letters look OK.
  7. 33Doll
    33Doll
    A little comet and scrub brush every few months, no big whoop! Letters super easy over white walls. I think a 73-79 front is in the future though for that right 70’s look.
  8. 33Doll
    33Doll
    Here is my 78 f-50
    With T/As. 245/60- 235/70 up front I think
    Wish I still had it. Sold it for $1500 in 2006
    cause I was sick of smogging it
    stupid California!
  9. 210superair
    210superair
    from Michigan
    Looks great man. Gonna post a gif of you doing donuts in it when you get it running?!?!
    porkshop, guthriesmith and Sharpone like this.
  10. guthriesmith
    guthriesmith
    Probably not… Have you priced those BFG’s lately?!?! :eek:
  11. guthriesmith
    guthriesmith
    Decided I’m gonna try like heck to make this thing run this week! Tired of it just sitting on the lift and me not driving it. Plus, the radiator in my 51 sprung a leak, so now it’s down too until I get that fixed.
    33Doll, Deutscher, Okie Pete and 6 others like this.
  12. rusty1
    rusty1
    ...I gotta say that looks just right,...good decisions on your part,...sits just rite...
    Sharpone, e1956v and guthriesmith like this.
  13. guthriesmith
    guthriesmith
    Thanks Sam! I wasn’t sure what you would think and appreciate your opinion.
    So, mainly worked on the 51 tonight but got to talking to some buddies about welding and remembered my butchered up PS bracket that has been bothering me. Decided to make it better this evening. Still need to grind it down and paint it tomorrow, but it doesn’t look quite as butchered now.
    Deutscher, Okie Pete, SS327 and 2 others like this.
  14. guthriesmith
    guthriesmith
    I should have never said I was going to get this thing running this week…. I did spend too much time on the silly bracket last night, but that’s all I got done. :eek:
    e1956v, 33Doll, Deutscher and 9 others like this.
  15. 40FORDPU
    40FORDPU
    I've found I do my best work when I don't have a self imposed time schedule....bracket turned out great.
    Deutscher, Sharpone, porkshop and 4 others like this.
  16. Ayers Garage
    Ayers Garage
    I ride bicycles. We have an old saying that seems appropriate for this situation.
    "No matter how slow you're going, it's still faster than those people sitting on the couch".
    Deutscher, drdave, Sharpone and 3 others like this.
  17. Okie Pete
    Okie Pete
    Looks good Jeff . It’s a time ****ing black hole when I start making or modifying parts and brackets . You’re making progress.
  18. guthriesmith
    guthriesmith
    So, after making that bracket look decent, found out they cut the other PS bracket too and also figured out what they cut off the one I welded on that would make it better. :mad: Pretty sure I just need to make it to a salvage and get some brackets that aren’t butchered. I did figure out the A/C brackets and am making progress there. Just not sure what the heck they were thinking chopping up perfectly good brackets. It must have had something to do with trying to put headers on the truck. But, I’ve about had it for tonight and probably just need to head to a salvage tomorrow and try to start with some non-butchered brackets. No reason that stock brackets can’t work from what I am seeing…
    e1956v, Deutscher, porkshop and 3 others like this.
  19. 51pontiac
    51pontiac
    from Alberta
    I don’t know why but there is something about these trucks that draws me in. Yours reminds me of the 1980 Sierra Cl***ic I owned way back in 1983/84. The stance is great on yours and a vote for white letters! IMG_3866.jpeg
    guthriesmith likes this.
  20. RodStRace
    RodStRace
    I think that it's a good, solid, honest, truck. Simple, easy to work on, very little pretension.
    Good room inside, good proportions. Helps that they made a ton of them and parts are available.
