Projects 4BANGER mild HotRod
Discussion in 'Traditional Hot Rods' started by Deutscher, Nov 12, 2024.
  1. Deutscher
    Deutscher
    from Germany
    The right fender was bolted to the rocker panel and Floorboard.
    The fenders came from another car; the holes were all slightly offset, which was a bit fiddly.
    The clamp for the original distributor was drilled out with a hole saw so that the clamp would fit the new distributor.
    Oil is now on the engine. The other fender will be touched up a bit; it suffered some damage during transport, and then it will be installed.
    Cheers, Harald
  2. Jeff34
    Jeff34
    Ahh, Leipzig. I've spent a LOT of time in Leipzig back around 1998-2000.
    Great progress! Things looking awesome!
    winduptoy and Deutscher like this.
  3. Deutscher
    Deutscher
    from Germany
    The front fenders are mounted; they were battered, so I sanded and polished them with 1000-grit wet sandpaper. They look quite presentable again.
    Greetings Harald
    Jeff34, winduptoy, Jimmy and 7 others like this.
  4. Smallfordsuk
    Smallfordsuk
    from Belfast
    Harald - Is this the original seat with slimmer base and back - Thanks James
  5. Deutscher
    Deutscher
    from Germany
    This is the standard coupé bench seat, only newly upholstered in leather.
    Cheers Harald
    marioD, winduptoy, RMR&C and 5 others like this.
  6. rwrj
    rwrj
    from SW Ga
    Wow. That’s pretty spectacular.
    winduptoy, Smallfordsuk and Deutscher like this.
  7. Deutscher
    Deutscher
    from Germany
    You're absolutely right, the upholsterer really did a fantastic job with the interior.
    Greetings Harald
  8. atch
    atch
    Spectacular...
  9. Smallfordsuk
    Smallfordsuk
    from Belfast
    Deutscher likes this.
  10. Deutscher
    Deutscher
    from Germany
    Today I installed the front fenders, spent several hours aligning them, there was almost a 1-inch difference between left and right, so I kept removing and reinstalling one of the support brackets to adjust the fit, now it fits and could be screwed on without any tension,
    I like it with the lowered headlight bar.
    Cheers Harald
    marioD, Jeff34, winduptoy and 7 others like this.
  11. Fabber McGee
    Fabber McGee
  12. rwrj
    rwrj
    from SW Ga
    It's not just the headlights, though. The whole front of that thing is perfect, the size of the tires and wheels, and the way they are tucked up in the fenders, perfectly complimented by the level of the lights. Good eye, Harald.
    winduptoy, RMR&C and Deutscher like this.
  13. noboD
    noboD
    I agree.
  14. Deutscher
    Deutscher
    from Germany
    I appreciate your comments, thank you.
    It'll be exciting when it's on its wheels.
    Today I cleaned and polished the radiator splash apron, just like I did with all the other parts.
    The hood will be the last one; I'm trying to do as little repainting as possible.
    It's always amazing how much shine is underneath.
    Cheers, Harald
    marioD, Jeff34, winduptoy and 6 others like this.
  15. Perhaps selfishly, but I hope to see it in real life! :D Going for Rømø again this year, @Deutscher?
    It is - my tudor was painted during winter in the cold with possibly to little hardener, so it has some "interesting" orange peel like texture. But far away, or in pictures, no one notices! ;)
    winduptoy, Deutscher and hotrodfil like this.
  16. Deutscher
    Deutscher
    from Germany
    We'll give it a try; it should work.
    Regards, Harald
    winduptoy and Dannerr like this.
  17. oxenenergyy
    oxenenergyy
    Congratulations and welcome . You have come to the right place
  18. Deutscher
    Deutscher
    from Germany
    Yesterday we took a trip to Leipzig in the Ford Mustang and picked up the radiator.
    Installed it today,
    welded a small crack in the lower half of the radiator shroud, cleaned everything, and installed it
    - it looks great.
    Regards, Harald
  19. RMR&C
    RMR&C
    from NW Montana
    The car is looking great! You have done some amazing work so far. Carry on!
