Featured Projects Dirt Cheap Dart
Discussion in 'The Hokey Ass Message Board' started by Sharpone, Jan 18, 2026.
  1. Garage therapy followed by rumble therapy when the Dart fires up!;)
  2. SS327
    SS327
    Wow, sorry to hear that. I guess you really were sick. Take it easy for a few weeks, the car will keep.
  3. chevy57dude
    chevy57dude
    Ya can't keep a good Dan down! Hope you recover quickly.
  4. wicarnut
    wicarnut
  5. oldiron 440
    oldiron 440
    Some guys just got to show everybody up, do everything a little bit better ;)
    Get better soon but don’t push it…
  6. Deutscher
    Deutscher
    from Germany
    Get well soon, listen to the guys.
    Cheers Harald
  7. Rickybop
    Rickybop
    Hoping you're feeling better.
  8. guthriesmith
    guthriesmith
    Man, hadn’t checked in here in a few days and find out you have been in the hospital! Praying you can get back to normal soon and feel like getting back on the car.
  9. Rickybop
    Rickybop
    It's a ******. Prayers.
  10. Sharpone
    Sharpone
    Thank you all!!
    I’m back home recuperating, a little weak the Doc tells me a week or two for full recovery. I had excellent care in the Hospital.
    You guys are the greatest.
    Dan
  11. Good to hear!!
    Deutscher, Sharpone and Tow Truck Tom like this.
  12. Tow Truck Tom
    Tow Truck Tom
    from Clayton DE
    Give it time, but keep hitting ''that wall''.
    Sorry you were in it, While this Saturday makes it official.
    Maybe not quite, ? Time to leave the 'cave'.
    Just drive it first gear, for a spell. And Keep Your 'Tank' filled.
    Here's to You Ya 'Unhinged Maniac':)
    Happened that way to me One time +Mailbox for details, not here
    Deutscher and Sharpone like this.
  13. oldiron 440
    oldiron 440
    Now is a great time to collect on a few of those brownie points you might have with your wife and take it easy, listen to the doctors…
  14. Sharpone
    Sharpone
    Picture stolen from the web.
    Ok back to car stuff.
    Sitting around and thinking (dangerous) about paint and body hopefully this summer.
    I have some medium blue. Was thinking blue and silver.
    Dan
  15. Rickybop
    Rickybop
    Good to hear from you! It's natural we start worrying a little. We're older now and these recent bugs are nasty.
    Definitely be good to yourself and take it easy. Don't be surprised if you start feeling better but then experience a small relapse. Just put your pajamas back on and watch some more cartoons.
  16. Rickybop
    Rickybop
    Blue and silver sounds great.
  17. chevy57dude
    chevy57dude
    The paint scheme looks good on the red/silver car.
  18. duecesteve
    duecesteve
    Just don't clone a Ramchargers paint scheme my buddy did it on a wedge Dodge posted it on his Facebook ,then got a message from a lawyer that the scheme is copyrighted and he was gonna get sued if he didn't change it :eek:
  19. chevy57dude
    chevy57dude
    Well, aren't they fun!
  20. Sharpone
    Sharpone
    Getting sued for a copied paint scheme for personal use?
    WOW a little over the top.
    Dan
  21. Saweeet:cool:!!
    porkshop, Tow Truck Tom and Sharpone like this.
  22. WAY over the top:eek:!!
  23. gene-koning
    gene-koning
    Well, the car in this picture isn't a Dart, but it is blue & silver (its my son's 57 Dodge). thumbnail.jpg
    I think the blue and silver go together pretty good.
  24. Sharpone
    Sharpone
    IMG_3909.jpeg That car rocks. Nice Very Nice.
    Dan
  25. I like it,a lot:cool:!!
  26. Sharpone
    Sharpone
    IMG_3913.jpeg I need replace all the dust boots on the front suspension. The old rubber is bad, however the ball joints, tie rod ends etc. are good, flushed with lots of grease.
    Not sure how the new ones are installed. The old ones appear to have something similar to an internal snap ring for lack of better terminology. I’m thinking a socket, or piece of tubing over the dust cap cap and a sharp blow with a mallet?
    Anyone ever replaced dust boots on suspension parts?
    Dan
    Tow Truck Tom and wicarnut like this.
  27. RodStRace
    RodStRace
    If they can slide over the stud and the stud slid into the joint and the nut installed, it should 'pop' on just fine.
    If they are all off the car and a vise is handy, yes, a socket can be used to coax them on. I try not to hammer rubber parts on if possible. Front end stuff has it's own set of rules, though. Maybe a big C clamp?
  28. gene-koning
    gene-koning
    Ryan, on the old stuff like your Dart, the tie rod end and ball joint boots just fit over the stud and when it was ***embled, and the nut was tightened down, the clamping force just held them in place. On the grease end (the open end), they just pretty much sat over the top of the joint itself and were 'sealed' by the sides of the boots forcing the open end to sit tight.
    The 60s OEM rubber boots had a metal ring at the bottom that sat against a step on the outer housing, but there was no mechanical connection on the open end of the boot other then the fit of the rubber over the housing. I have not seen many recent rubber boots that have the metal ring attached to the rubber, but the ones that do tend to fit against the housing pretty tight, like the metal ring was too small.
    The purpose of the rubber boot is to keep dirt & debris out of the joint, and to help keep the grease in. The open end of the boot is suppose to allow excess grease an escape route if the joint was over greased, other wise, an over greasing event splits the rubber.
  29. 55Belairretrorod
    55Belairretrorod
    from Australia
    If you're using the polyurethane boots as pictured you'll find they're moulded extra thick at the small end so when they're fitted to the car the flat surface there will **** up against the stub axle/spindle and hold them in place. Same scenario with tie rod end boots where they meet the steering arm or centre link.
    Sharpone likes this.
  30. duecesteve
    duecesteve
    That's really nice it's too bad that JD Wheels stop making the
    Halibrand lookalike rims the 10 x15s are really nice, and skinny front runners I had on my '34 were cool
