Technical Multimeters
Discussion in 'The Hokey Ass Message Board' started by Boneyard51, Mar 16, 2026.
  1. Boneyard51
    Boneyard51
    Any one here know where I can get some multimeters recalibrated? I have a Greenlee and a Fluke , both high end meters that are reading incorrectly, like by 50%! Really got me into a jamb, before I figured out they were way off! And what is the cost? I just picked up a real nice Greenlee DM 60 for cheap, but would like to get my others fixed, if it isn’t too expensive! Thanks in advance…
    Bones
    Tow Truck Tom and Sharpone like this.
  2. squirrel
    I just get out the manual, and do it myself. :)
    My dad built this meter in the 1950s, it still works.
  3. 19Eddy30
    19Eddy30
    from VA
    Just asking & curious,
    I have 2 Fluke's upper 500's
    what where you measuring?
    Where both the other two off the same amount ?
  4. Oneball
    Oneball
  5. If they are that far out, it is unlikely to be calibration, but more likely a problem somewhere else in the circuit, maybe the power supply. Some meters have trimpots inside (small variable resistors), which will affect one or more ranges. If you can get a circuit diagram for yours, it will be on there, something like "VR 3- ohms". If you can post a circuit diagram here, I may be able to pinpoint it for you. It is usually done with a couple of low tolerance resistors (0.5-1%) as a reference. You may find that getting them repaired/calibrated may be a very expensive exercise, and sometimes it is cheaper to buy a new meter.
    Tow Truck Tom and Boneyard51 like this.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    Wait till Harbor Freight has a grand opening store giveaway near you.
  7. FrozenMerc
    FrozenMerc
  8. jaracer
    jaracer
    I know that Fluke will recalibrate their meters.
    Tow Truck Tom and jimmy six like this.
  9. 29Sleeper
    29Sleeper
    from SoCal
    I've got several of those still in the package. I probably should take the batteries out of them until my Fluke & Beckman meters die.
  10. Boneyard51
    Boneyard51
  11. Boneyard51
    Boneyard51
    No, I was at a rv camp and the owner , a friend of mine, was having a problem with his electrical system so I whipped out my trusty Fluke meter , that I bought used, and proceeded to to test the voltage. I was getting crazy readings , like 83 volts and 160 something like that that made no sense! So he called an electrician friend of his and he check it out and the voltage was 120/240! So we put my meter back on it and it read way low again. My Greenlee , that read low was a similar situation. I guess that’s why I got a good deal on them both used!
    I’m not concerned if they are off a volt or two, or a couple of ohms, but I would like them in the ball park.
    I scored a Greenlee DM60 , yesterday for $15 that looks like it’s new, it seems to work just fine as I tested it on a battery and my house current.
    But I hate to throw the other two away, if they can be brought back to life , reasonably! That way I could keep one in my truck, one in my motorhome, one in the shop! I would like that, because whenever I need one, it’s always somewhere else! Just happened to me , two days ago…..again! lol
    Bones
  12. Boneyard51
    Boneyard51
    I don’t remember if they were the same, but close, way off! Like I mentioned, we compared my Fluke to an electrician’s newer Fluke and it was way off. Several year later, I ran into the same situation with the Greenlee on my home generator! I bought both, used somewhere, actually don’t remember but a long time ago. I changed batteries in them, didn’t help. But I don’t think the batteries come into play , much on the voltage readings.
    I don’t learn very fast, I bought another Greenlee DM 60 yesterday, so I’m back in business……for a while! But hate to chunk the other two, “ quality “ multimeters!
    Bones
  13. willys36
    willys36
    Wouldn't know. I just use the harbor Freight $4 meters. Always accurate, dirt cheap if ever fails which none have.
  14. Budget36
    Budget36
    Are you using the same leads for both meters?
    It’s odd they kinda mimic each other.
    Boneyard51 and 19Eddy30 like this.
  15. oldsmobum
    oldsmobum
    from SoCal
    Replace the batteries. I have a collection ranging from fluke’s finest to Home Depot’s dirtiest as I use them every day for work. The one thing they all have in common is that they get senile and read erroneously when the batteries are low.
  16. Digital meters will often give you erratic readings when used near ignition systems, especially the solid copper type. If you are testing next to a running motor you may get these readings. It's good to have an old ****ogue (moving coil) type meter handy for this kind of work, they are not affected by this.
  17. 42merc
    42merc
    I grew up in Benton Harbor. Built several Heathkits, including a VOM.
    squirrel likes this.
  18. Boneyard51
    Boneyard51
    Well, that’s what I thought! So, I figured it had to be me! Different leads for each! This happened several years ago, and a year or so apart! But it’s kinda hard to screw up a DC volts reading, or AC even less! Plus I checked it with the electricians meter! Had him use mine, same screwed up reading !
    I had actually bought a cheap ****og meter to use, but the one I bought, I don’t like the scale didn’t have the 1 to 20 DC volts , kinda hard to get an accurate 12 volt reading . Kinda hard to tell 13.7 from 14.2!
    Fast forward to yesterday , I saw a Greenlee DM-60 for sale locally, for $20, me being cheap offered $10, she said ok! I met her and the unit looked brand new and measured a brand new AA battery at 1.65 volts. So I gave her $15! Lol :)
    This purchase got me thinking about my two high dollar units laying around collecting dust! I think I changed batteries, but it has been several years! If I can find them I may change batteries in them, and test them against my new unit!
    Bones
    G-son and Budget36 like this.
