Technical Hurst shift lever replacment questions
Discussion in 'The Hokey Ass Message Board' started by Hotrodjohn71, Mar 18, 2026 at 12:31 PM.
  1. Hotrodjohn71
    Hotrodjohn71
    Hello group,
    I have a Hurst compe***ion plus shifter with a very rusted lever that I'd like to change out.
    Ive watched a couple videos about these but I cant seem to determine if the available levers are going to be correct for the changeout.
  2. DDDenny
    What are you using this on?
    If your (rusty) shifter uses a bolt-on handle then yes as the bolt spacing is the same on all applications, it's the basic dimensions of the handle relating to your requirements that dictates which handle to get, there is even one that has more offset than the one pictured.
    This is hard to see the dimensions but just Google (images) "Hurst replacement shifter handles", there are lots of other photos.
    Here:
    https://www.google.com/imgres?imgurl=https://www.hanlonmotorsports.com/wp-content/uploads/2021/04/5387201_4-300x300.jpg&tbnid=aOul3tT9XhJG2M&vet=1&imgrefurl=https://www.hanlonmotorsports.com/product/hurst-shifters-compe***ion-plus-upper-stick/&docid=wBc6iElc8BVC1M&w=300&h=300&source=sh/x/im/m4/0&kgs=c908c212d6113ce9#ip=1
    chryslerfan55 and Hotrodjohn71 like this.
  3. MCjim
    MCjim
    from soCal
    No, that one on Summit is a later style, you have a bayonet style. I don't know if there are new replacements for those...have fun getting it apart.
  4. MCjim
    MCjim
    from soCal
    Part 2: Best bet is get yours replated, I do not think you will find a new one.
  5. Hotrodjohn71
    Hotrodjohn71
  6. Rickybop
    Rickybop
    You might have some luck finding a complete used shifter that has the type of shifter you need.
    Hotrodjohn71 likes this.
