Hot Rods 3 duece manifold for a 302 ford
Discussion in 'The Hokey Ass Message Board' started by samsonized, Mar 23, 2026.
  1. samsonized
    samsonized
    did any company ever make a 3 deuce manifold for a 302 small block ford
    Sharpone likes this.
  2. Flatrod17
    Flatrod17
    Ford did back in the 60's. Used 2300 Holley's. Blue Thunder may have reproduced them, but don't know somebody did. Some people will take a lower 302 EFI manifold, make a pluemn to go on top and add 3x2's. using 94's or 97's.
  3. samsonized
    samsonized
    what car did it go on
  4. Flatrod17
    Flatrod17
    It was an over the counter part from Ford.
    deathrowdave and Sharpone like this.
  5. samsonized
    samsonized
    what carbs did it use
  6. Moriarity
    Moriarity
    SUPER MODERATOR
    @lostn51 just recently found one of them with a wanted ad in the cl***ifieds here
    dana barlow, lostn51 and Sharpone like this.
  7. They pop up every now and then on marketplace
    EDB-5412 is a edelbrock number that’s discontinued
    I’ve seen em drilled for 3 and 4 bolt cards
    2devilles and Sharpone like this.
  8. lostn51
    lostn51
    from Tennessee
    I picked this one up from placing a wanted ad on our site. Dylan60 answered and the rest is history ;) IMG_4303.jpeg
  9. deathrowdave
    deathrowdave
    from NKy
    I had OEM Ford intake , Holley carbs , fuel log , breather and all years ago . About 40 years ago , sold for $700.00 . I built one years ago with Blur Thunder intake and Ford 2100 carbs , it worked out well . My advice nicely 2 plane intake and a single 4 barrel and for get about the h***le .
    Dave Mc, Sharpone and 19Eddy30 like this.
  10. oldiron 440
    oldiron 440
    Edelbrock had one at one time…
    Dave Mc and Sharpone like this.
  11. lostn51
    lostn51
    from Tennessee
  12. Holman-Moody had one not too long ago also. Now out of stock. It was more-or-less a copy of the original Ford intake from the late '60s.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    was there a factory 3x2 for the small block? I had only ever seen the ones for an FE
  14. lostn51
    lostn51
    from Tennessee
    I believe that they were a Ford Performance parts counter order like the SOHC parts and inline Autolite intake and carburetor. I’d have to dig through a few of my early catalogs to see but I’m pretty sure they were available.
    Sharpone, deathrowdave and Moriarity like this.
  15. Ford (branded as Shelby?) sold it as a complete over-the-counter kit for about $400 IIRC. You could buy it at a Ford dealer, that I do know because that's where I saw the only one I did see. This was the mid-'70s at the local dealer, close-out price on the display kit was $150... I should have bought it... But I was thrashing a FE in those days. I did pick up an aluminum FE flywheel for $30 as they were clearing out all the racer stuff...
    Sharpone and lostn51 like this.
  16. Moriarity
    Moriarity
    SUPER MODERATOR
    Oh, ok yeah I was pretty sure it didn't come on a car like the FE ones, thanks
  17. oldiron 440
    oldiron 440
    I’ve seen both the Ford and the Edelbrock and I believe they are both Edelbrock castings, same with the 4V. I believe it’s the Performer RPM, at least the version from the 60s.
    I’ve got the Motorsport version that I bought from the Ford dealer I worked at in 2000 and it’s a the same as the performer RPM.
  18. That may be true now, but wasn't always that way. Edelbrock has a habit of copying other peoples work. The '66-67 428PI intake that's prized by Ford guys, Edelbrock made a virtual copy of it very shortly after Ford started using it, calling it the 'S-427'. Ford noticed and made them pull it off the market. That's also why you can't find a Edelbrock Ford 2-4V intake that accepts Holley carbs, only Carter/Edelbrocks...
  19. Flatrod17
    Flatrod17
    Most of the 60's Ford stuff was cast by Bubby Bar. And yes Edelbrock copied a lot of it.
  20. deathrowdave
    deathrowdave
    from NKy
    289 Cobra / Shelby intake vs Edlebrock F4B dead nuts same
  21. RICH B
    RICH B
    Worked on an A over at my kids; had a sbf with 3x2. Didn't note the intake; but it different kind of carbs, think maybe "Demon". Intake came with the float bowls forward; but soon found they had to be turned backwards to drop the distributor.
    lostn51 likes this.
  22. lostn51
    lostn51
    from Tennessee
    I was wanting that set up for my woodie but it’s no longer in production. I LOVES me some Demon carbs :p
  23. deathrowdave
    deathrowdave
    from NKy
    I think thats Buddy Bar intake or a direct copy
  24. jimmy six
    jimmy six
    Ford never put 3-2’s on any Y or SBF I know about. Over the dealership parts counter is a totally different story.. With the FE in 1962 406 was common and many had them.
    I’ve seen 1 1961 390” 401 HP with 3-2’s and was told it was factory…..Maybe dealer installed ..I don’t know.
  25. Apparently you could order an FE equipped car with3x2 from the factory. The car came to the dealership with a 4 bbl installed and the dealer removed the 4bbl and installed the 3 x2. I was 8 or 9 years old back then so I wasn't really there to see it happen. Also, I'm from Canada so things could have been different south of here.
    lostn51 and jimmy six like this.
  26. RmK57
    RmK57
    I have a 1969 Ford Muscle Parts Catalog and the only intake listed is the tried and true C90Z-9424 duel plane aluminum intake. It would look nice on a open hooded hot rod but ideally I couldn’t see any real performance advantage over the single 4-bbl setup.
  27. Yep, dealer installed, the parts were in the trunk. Same thing on the later-in-the-year 4 speed option. GM's deal for exclusive use of the T10 expired on Dec 31, 1960, so Ford got busy and made the trans available around April of '61. By the '62 model year both the tripower and trans were factory installed. Then Ford learned what GM already knew... the T10 couldn't take the power of the big-inch engines coming out of Detroit, witness GM already had the Muncie and Ford quickly tooled up the toploader...
    lostn51 likes this.
  28. kabinenroller
    kabinenroller
    Here is Ford 3x2 intake with the original Holley two barrels that I installed on my **** Comet back in the ‘80’s. It was a Buddy Bar manifold, as were the Cobra valve covers. I topped the carbs with an original Cobra oval air cleaner. ( removed for the photo)
