Hot Rods The car I've been waiting for
Discussion in 'The Hokey Ass Message Board' started by wheeldog57, May 8, 2024.
  1. wheeldog57
    wheeldog57
    Ok I feel better now. The lid fits in the hole and it opens and closes. Still need some tuning but this was a big hurdle for me 20260321_101254.jpg 20260321_105643.jpg 20260321_101320.jpg 20260321_105626.jpg 20260321_153252.jpg 20260321_153305.jpg 20260321_154602.jpg
  2. wheeldog57
    wheeldog57
    The small curved pieces are trunk gutter parts I made. Shrinker /stretcher is your friend. Cut to fit, shape, and weld up the middle
    NoSurf and porkshop like this.
  3. wheeldog57
    wheeldog57
    These Bart Simpson looking pieces will help box in the trunk area 20260323_195553.jpg 20260323_195607.jpg
    SPEC, bchctybob, Johnny Gee and 10 others like this.
  4. patsurf
    patsurf
  5. wheeldog57
    wheeldog57
  6. wheeldog57
    wheeldog57
    I'm leaving the Frankenstein look with these pieces. They've been cut, torched, and patched multiple times. Too much history. Or I'm too lazy to make them mint, they're barely visible anyway
  7. wheeldog57
    wheeldog57
    Trunk done, on to the seat support and firewall
    SPEC, bchctybob, swade41 and 6 others like this.
  8. wheeldog57
    wheeldog57
  9. Making nice progress.
    porkshop likes this.
  10. wheeldog57
    wheeldog57
    Pulled a muscle? (or 3) in my back so working on the interior of the 33 is painful but I want to get it done 20260503_150832.jpg 20260503_152419.jpg 20260503_153926.jpg 20260503_175944.jpg 20260503_182305.jpg 20260503_182318.jpg
    This little package shelf made from a Mike Bowling find will fit perfectly. Seat back support next
    SPEC, bchctybob, drdave and 8 others like this.
  11. wheeldog57
    wheeldog57
    Added the jail bar to 1- act as a seat support and 2- help stiffen up the body, it has tears in it already! 20260504_172818.jpg 20260504_201448.jpg 20260504_201640.jpg
    SPEC, bchctybob, drdave and 6 others like this.
  12. wheeldog57
    wheeldog57
    SPEC, bchctybob, drdave and 14 others like this.
  13. Jacksmith
    Jacksmith
    from Orygun
    Gonna be solid as a tank!
    rod1 and wheeldog57 like this.
  14. oldiron 440
    oldiron 440
    I did a Jaguar sedan late fifties early sixties that you car reminds me of. Overall the car didn’t look too bad before I started but after I started on it everywhere it was bolted together both pieces of metal needed repair, the rockers, door skins and some of the frames needed work and all the fenders needed quite a bit of work and when I was finally done welding shaping and fitting I had well over two hundred hours in just metal work. It was a car I hated before I was done with it.
  15. adam401
    adam401
    Ron your coupe is turning out killer!! Keep on keeping on
  16. Robdski
    Robdski
    Looking good. You’re making great progress.
    Thanks for continuing to share the photos.
    rod1 likes this.
  17. NoSurf
    NoSurf
    Looks great. Plugging away.
    wheeldog57, 4274SPEED and rod1 like this.
  18. wheeldog57
    wheeldog57
    I needed to move (bend) and relocate the transmission dip stick, extend the hold down, 20260511_203401.jpg 20260511_203428.jpg 20260514_192003.jpg 20260514_195212.jpg 20260514_200406.jpg 20260514_201050.jpg and pull out the heater hose in preparation for the toe board.
    SPEC, bchctybob, drdave and 4 others like this.
  19. NoSurf
    NoSurf
    That's a serious lag bolt blocking that heater hose!!!
    wheeldog57 and porkshop like this.
  20. wheeldog57
    wheeldog57
    Went digging in the s**** metal pile and I had a repo inner door repair panel for a square body pick up. . . . 20260515_201306.jpg 20260515_201858.jpg 20260515_201255.jpg
    And I bent up the toe board, getting closer pretty much every night. More tomorrow
    SPEC, bchctybob, drdave and 5 others like this.
  21. My neighbor's son runs an HVAC shop, and loaned me a large diameter tubing bender; I used it to correct the dipstick tube on the 700R4 I installed i my 447.
    wheeldog57 likes this.
  22. ne'erdowell
    ne'erdowell
    Nice steady progress, everything is fitting great. Do you have any photos of the seat bottom before the burlap went on?
  23. wheeldog57
    wheeldog57
    This is the stock bottom, I had to cut it up quite a bit to make it fit. The vinyl is removed leaving the original burlap in the latest pictures 20251102_103001.jpg
    SPEC, bchctybob, porkshop and 2 others like this.
  24. ne'erdowell
    ne'erdowell
    Thanks, I was more interested in how you tied the halves together so they would be stabile when you sit on them.
  25. wheeldog57
    wheeldog57
    @ne'erdowell the seat bottom is currently wired together and the final fitment will be upcoming. I'll post pictures when I figure out how I'm going to do it
    bchctybob likes this.
  26. ne'erdowell
    ne'erdowell
    Thanks. FWIW , I will be performing a similar exercise and was considering using small tubing over the cut ends with a little tack weld at each end. Seems like it would provide the strength and stability necessary.
    wheeldog57 and RodStRace like this.
  27. wheeldog57
    wheeldog57
    The seat bottom was cut, narrowed, and everything is overlapped. I used stainless steel tie wire to hold it together. I decided to just add more wire. 20260525_192256.jpg 20260525_192300.jpg 20260525_192305.jpg 20260525_192311.jpg 20260525_194813.jpg 20260525_201953.jpg
    SPEC, bchctybob, ne'erdowell and 3 others like this.
  28. ne'erdowell
    ne'erdowell
    Thank you for supplying such details shot of the surgery. Great fit for the car!
  29. wheeldog57
    wheeldog57
  30. Nice progress Ron!
