Technical What Franklin element should I use?
Discussion in 'Traditional Hot Rods' started by tankcmdr, Mar 21, 2026.
  1. tankcmdr
    tankcmdr
    What Franklin rear end “element” do I need for this rear end? This was a spare truck rear end I purchased that I think came from a NASCAR team selling their old junk. It was never run. It is going into a 1929 Model A roadster build. The frame is newly build and will be part of a drivetrain including a Navarro supercharged 59AB flathead through a T-5 xmission. Let me know and thanks. IMG_0083.jpeg
    Deutscher likes this.
  2. Dave G in Gansevoort
    from Upstate NY
    What elements are you referring to? It looks fine just as it is to me. IMG_0027.jpeg Here’s my almost identical Winters rear. I like yours the way it is. I am ***uming it has a differential and not a spool…
    Robert J. Palmer likes this.
  3. gene-koning
    gene-koning
    Gears inside of the rear cover? A differential instead of a spool?
    The only other stuff I see missing in the picture are brakes, shocks, and a driveshaft. None of which need to be from Franklin.
  4. 19Eddy30
    19Eddy30
    from VA
    Element as in
    Oiler / pump & filter ?
  5. tankcmdr
    tankcmdr
    There are no gears that couple the driveshaft to the axles.
  6. Jmountainjr
    Jmountainjr
    I am ***uming that you are referring to the change gears behind the rear cover? If so, first find out the ring and pinion ratio. One set of change gears can provide two ratios depending on how you install the gears. Typically the sets are numbered. But the overall gear ratio you end up with depends on with what ring & pinion ratio you match them with. Typical r&p ratios are between 4.11 and 4.86. The numbered change gear sets typically have a chart showing the overall ratio with a given r&p ratio saving you doing the math. If you are talking about having no ring & pinion set installed that's a different conversation but the above will still apply at some point.
  7. alchemy
    alchemy
    A big ol huh? What is an “element”? I’m not understanding your term.
    RICH B likes this.
  8. studebakerjoe
    studebakerjoe
    I think he means there is no differential and ring and pinion. It looks like the lower shaft is in place since the driveshaft yoke is attached.
  9. tankcmdr
    tankcmdr
    What number splines are used for the quick change gears?
  10. 69fury
    69fury
    from Topeka
    They would be 10 spline.
    You just need to look up an online gear calculator that will either give you numbers in the quarter or eighth mile based on hp, weight, and tire diameter, etc and go from there.
    Or if it's just a street car, then pick an RPM/MPH calculator for the revs you want to run at the highway speed you want to go with the tire diameter you have. Then pick the spur gears from one of many online charts available to pick the ratio you need.
  11. What are the axles, double spline with drive flanges or 9” Ford style flanged?
    Also what is the bolt pattern?
    The most common oval track patterns are Wide 5 , 5 on 5 1/2, and 5 on 5
    Some do run the “new” 5 on 4.5” Ford and a few run the Chevrolet 5 on 4.75”
