Folks Of Interest Preparing for a archaeologist fossil dig
Discussion in 'The Hokey Ass Message Board' started by 19Eddy30, Mar 26, 2026.
  1. studebakerjoe
    studebakerjoe
    @Fordors you can see the ball end of the shock arm just under that fan belt.
    Fordors, Stogy and 49ratfink like this.
  2. 19Eddy30
    19Eddy30
    from VA
  3. Stogy
    Stogy
    Time to do some walking around but protect yourself...who knows what else is buried...it's the best time of year to find it...before the winged monsters set in...
  4. chevy57dude
    chevy57dude
    Hopefully this will pay off for you. I also hope the buried part of the frame still exists.
    Stogy and Just Gary like this.
  5. As it's off the beaten track wonder if it's the remains of a doodlebug
    SR100, Okie Pete, Stogy and 3 others like this.
  6. Ziggster
    Ziggster
    That’s crazy! When I first moved to where I’m now, walking my dog along one of the private roads around the lake, I came across an old car half buried. Never paid much attention to it, but now wished I did back then. Years later went looking for it and it was gone. In another area next to a pond, I came across an old dump. Old washing machines, junk, then an entire bus? frame half buried. Back in the day folks living in the country just dumped their stuff either on their property or close by at a “communal” dump.
    Okie Pete, Stogy and duecesteve like this.
  7. dirt car
    dirt car
    from nebraska
    Years ago retrieved a 38 ford sedan from a wind-swept field in an Arapahoe Ne. horse farm, several 35-40 complete rolling ch***is littered the hill side showing evidence that someone labored with a chisel to keep the floor pans intact, I presume to use as hay wagons we scouted the tree sp**** perimeter for any remaining body parts to no avail.
    duecesteve, Okie Pete and Stogy like this.
  8. RodStRace
    RodStRace
    Along with shovels and hoes, I'd want a chainsaw, a few straps, a come-along and if you can haul them fairly close, a sheet of plywood and a break down A frame that could pull/lift it up. Only needs to be a foot or two above grade. Get it up out of the dirt, slide the ply under it and use straps to pull/drag it out while it's strapped to the ply. If it's rough going and a fair distance, I might consider a cheap winch and a generator if you have them or access.
    I've watched a few of this guy's videos of rescues and he sure does it with grit and basic stuff. Seems to do things the hard way often.
    https://www.youtube.com/@5150mxVW
  9. Hot Rods Ta Hell
    Hot Rods Ta Hell
    ^^^^ Add snake boots! Can you get a tractor or skid steer back there? If so, you could use it to push/pull away logs, plow away some soil around the ch***is, then pick up the ch***is.
    I'm wondering what happened to the body? Did the engine quit and they sold off the body then dumped the ch***is in the back 40? Or was a whole car abandoned back there and hoodlum hot rodders helped themselves?
    It'll be interesting to see if the ch***is has collision damage. If so, that could explain the missing body.
    Question; how much land do you have? It blows my mind that you've been there 50 years and never knew a 34 Ford ch***is was there, lol !!!
    I'm wondering what else might be out there?...
    Stogy, duecesteve and RodStRace like this.
  10. nrgwizard
    nrgwizard
    from Minn. uSA
    If that ch***is has been there for ~50 yrs, all those trees weren't bigger than a small raspberry cane. If that. Still looks like it'd be worth it to save what could be saved. Neat backstory anyways. If not you, hopefully someone else. Too far for me, & I'm way too damn old. :) .
    Marcus...
  11. dirt car
    dirt car
    from nebraska
    Prior to the Atlantic Ia. swap meet being relocated to Greenfield Ia. back in the 80's there was a ravine to the far end of the fairgrounds with several ch***is & body parts buried beneath years of refuse & tree limbs, never heard of anyone pursuing what all might lie below as it was nearly impossible to enter only walk the perimeter.
    Stogy likes this.
