Projects The Geelong 1934 BB Ford
Discussion in 'Traditional Hot Rods' started by chev34ute, Aug 17, 2024.
  1. patsurf
    patsurf
    you need a neighbor w/ a loader--or invest in one!!
    chev34ute likes this.
  2. AHotRod
    AHotRod
    Great job, pushing forward.
    Can you enlarge your shed?
  3. chev34ute
    chev34ute
    Yeah it’s not that big a job, the easiest thing to do is raise it another half meter along the top, remove the roof, build new trusses that bolt to the existing trusses and hey presto, jobs done.
    warhorseracing likes this.
  4. chev34ute
    chev34ute
    Hey Guys.
    I got the edge welded into the side of the fender so it’s starting to look like something. Here is the before and after shot.
    Okie Pete and Deutscher like this.
  5. chev34ute
    chev34ute
  6. chev34ute
    chev34ute
    And this was as far as I got, as I realised I could not weld the rear section on until it was fastened to the frame. And I could not access the frame as it was sitting inside of the trailer. So the trailer went back outside again.
  7. chev34ute
    chev34ute
    I needed to get a front end under it and I had one lying behind the truck, this one was from a 37/38 Ford, it was missing the leaf spring which actually worked in my favour. I wanted to fit the Dragways I picked up before Christmas, only to find out the studs were too short. At that point I realised I would have to take the wheels off the rear axle, so once I found another set for the back, I was able roll the front end under the truck.
  8. chev34ute
    chev34ute
    And here is the other side, this is just a temporary fix, it steers and it rolls, but there are no shackles so I took the chain from the trailer and wrapped it around the leaf spring.
    Okie Pete, Outback, Woogeroo and 2 others like this.
  9. chev34ute
    chev34ute
    The cab is not bolted down, I loosely pieced it together because it was taking up space where it was laying. Now that it has a front end under it, I can finally get around to clamping the front fender in place and welding it together. The other thing I want to do is bolt the running board in place.
    Okie Pete, Outback, Deutscher and 2 others like this.
  10. chev34ute
    chev34ute
    Hey Guys.
    I after returning from Easter, I went back to work on the fender. I used the fender on other truck as a jig to make sure the sections, I was welding were squared up. IMG_0434.jpeg
  11. chev34ute
    chev34ute
    I made another cardboard template off the fender on the truck, to make sure the side radius on the fender I’m making up is the same.
  12. chev34ute
    chev34ute
    Once I had the outer edge done, I added the inner edge. IMG_0441.jpeg IMG_0440.jpeg
  13. chev34ute
    chev34ute
    The very last thing I needed to do was finish the inside edge where it transitioned from the horizontal flange that ran along the top of the frame to the vertical flange the ran along the side of the frame. This proved to be quite a challenge.
  14. chev34ute
    chev34ute
    Rather than try and bend down the existing material, I opted to cut it out, then make up a cardboard template of the hole. I then traced the template onto a new section of steel and began welding it in.
  15. chev34ute
    chev34ute
    It’s about 90 percent completed, because it’s a reverse curve, I was forced to put a relief cut into it to bring it down. Once I have made a filler piece, it will be complete. IMG_0447.jpeg
  16. chev34ute
    chev34ute
    The next stage of fabrication will be the rear flange that fastens to the running board and the wheel well that sits inside the housing. I would like to set the fender up on the truck first to see how it sits before I trim the edge for the running board to fasten to. Unfortunately the bolts that held the original running boards in place still need to be cut out.
  17. chev34ute
    chev34ute
    Luckily the running boards I’m using are mint, not a single bit of pitting or rust hole and they also have the brackets with them. These are by far the best items I have for this truck, so it will be imperative to get the fenders fitting perfectly. It makes sense to get the fender fitted before I do any more work on the wheel well, so that it what I will be doing next.
  18. warhorseracing
    warhorseracing
    from cameron wv
    Taking small pieces and creating a "new half of a fender" is no small task. "Necessity is the mother of invention". Incredible work Sir.
    Outback, chev34ute and Deutscher like this.
  19. chev34ute
    chev34ute
    Hey Guys.
    I haven’t had a lot of time to work on the fender, but it’s starting to take shape.
    Okie Pete, Woogeroo, Outback and 2 others like this.
  20. chev34ute
    chev34ute
    I got the sides of the wheel wells welded to the centre section and it’s just sitting loosely inside at the moment.
  21. chev34ute
    chev34ute
    I pulled the running boards out to start finishing the end of the fender, only to find, they are not as mint as I remember. The running boards themselves are fine, it’s the brackets that are damaged.
    Okie Pete, Outback and warhorseracing like this.
  22. GuyW
    GuyW
    Get a cloth or plastic sewing measuring tape, they are cheap.
    Woogeroo, Outback and warhorseracing like this.
  23. chev34ute
    chev34ute
    Mocking up the running board gives me a better idea of the flange that will need to be made up for the end of the fender. Once that’s completed, I can do the final t******* on the wheel well and start fitting it in place.
    Okie Pete, Outback, hook00pad and 2 others like this.
  24. chev34ute
    chev34ute
    Hey Guys.
    I got a bit more done this weekend. Capping off the end of the fender and t******* down the wheel well once it was squared up with the edge.
    Okie Pete, Outback and Deutscher like this.
  25. chev34ute
    chev34ute
    So far I’ve added the flanges along the outer edge and rear edge.
  26. chev34ute
    chev34ute
    Once I’ve welded the remaining flanges I will be drilling out the holes to fasten the running board.
  27. warhorseracing
    warhorseracing
    from cameron wv
    While you are drilling the running board holes do not forget to drill a drain hole in the spare tire well.:D Just a reminder in case you forget.:cool:
  28. chev34ute
    chev34ute
    Hey Guys.
    I’m getting close to finishing all the welding on fender. I didn’t have much time last month to work on it as I was away for one of the weekends and lost a whole Saturday the following week. I still have one end on the flange to weld then I will begin the process of plug welding the wheel well into the fender.
  29. chev34ute
    chev34ute
    Once the welding is done I want to start stripping out the outside ch***is, I need the front fender braces and splash apron, I also want to remove the fenders and running boards. The next task will be to start setting up the fenders and running boards so that I can get the cab lined up.
  30. chev34ute
    chev34ute
    The other thing I want is to is remove the cab mounts off the firewall from the other cab as the ones on good one are not the correct type.
    Outback, Deutscher and warhorseracing like this.
