V8 S-10 pickups
Discussion in 'Off Topic Hot Rods & Customs' started by 283john, Mar 30, 2026.
  1. 283john
    283john
    I know I cannot be the only one here who loves a good V8 swapped S-10. I think they are in-league with the fox body Mustang when it comes to being a good, plentiful, and light platform to easily drop a hopped up engine in and go fast for little cash. I built my truck in 2000 with a 283, Drove it a few years and swapped a vortec-headed 355 in it. It could run an 8.7 second 1/8 mile p*** at the strip one day and haul a thousand pounds of gravel the next. Drove it for 25 years and a branch fell on it and squashed the roof and windshield. Found a much more solid truck of the same year with no engine and bought it to swap drivetrain over. 355s-10.jpg
    hotrodjack33, TFoch, porkshop and 3 others like this.
  2. 38Chevy454
    38Chevy454
    I had a 97 Sonoma with a Vortec 350/NV3500. Fun truck even with the stock Vortec with all the fuel inj, P/S, P/B and A/C. Not so fun replacing the engine with another same Vortec when the first one had a rod decide to break. Spark plugs and headers were major PITA until I pulled the headers and welded up cracks and replaced the old collector flange. Hate exhaust leaks like those. I lowered mine about 4/5 total, but it was a ZQ8 which was about 2 inches lower stock. ZQ8 had the extra big sway bars, factory anti-hop third rear shock, and quicker ratio steering box along with the wider wheels as seen on mine. It would be a lot easier to work on without all the accessories under the hood that mine had. I built a V8 Vega when I was a kid and that was easier to work on than the Sonoma.
  3. 210superair
    210superair
    from Michigan
    I had multiple of those when I was a kid and always thought those were some of the best cheap little trucks ever built. I never put a 8 in one, but I knew a guy who put one in a fiero.... Lol
    Deutscher and 283john like this.
  4. fastcar1953
    fastcar1953
    Yep. Had one of them also. 514226213_24375177042079919_3962412666416282287_n.jpg 516373077_24424897540441202_4824463372020164091_n.jpg
  5. 283john
    283john
    my setup is much simpler with one v belt for the water pump and alternator. Manual brakes, manual steering. Plugs pretty easy to get to. Taking the hei cap off is pretty tight.
    Deutscher likes this.
  6. 38Chevy454
    38Chevy454
    There is an engine hidden in there:
    hotrodjack33, porkshop and 283john like this.
  7. 57 Fargo
    57 Fargo
    We have an ‘87 at work with a 6 liter LS and a 4L80 in it, it has 200km. Yes 200km. Still has the tires it left the factory with on it.
    hook00pad and 283john like this.
  8. buds56
    buds56
    built one about ten years ago,5.3/4l60, it was quick.
    hotrodjack33 likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    do all of these have a cowl hood scoop because there isn't enough room?
    porkshop likes this.
  10. 38Chevy454
    38Chevy454
    On my truck the cowl hood was actually needed for the A/C compressor clearance at the front of the hood, the inner structure was even notched to make it fit. Not because of intake clearance problems. It was original 4.3 V6 truck, and used the same front accessory drive as the 4.3, but being a V8, everything was forward by the extra cylinder (approx 4.4 inches). Without the A/C I believe a stock hood could have been used.
    The first gen with a more square front may have better clearance. My 97 being second gen had the more sloping down rounded front. I don't have the truck anymore.
    porkshop and Moriarity like this.
  11. 283john
    283john
    I only got the cowl hood for more engine compartment ventilation. Nice fibergl*** unit some guy was turning out in his barn near Lingenfelters shop in eastern indiana. Bolted to factory hinges and latch.
  12. hotrodjack33
    hotrodjack33
    Early 2000's I had this '86 S-10...got bored with it and I stuck a 350/350 in it.
    Over the course of the next 3 or so years, I kept throwing more and more time and $ at it for no apparent reason...I tubbed it and somehow it morphed into this. I eventually sold it on Ebay...and lost my *** on it:(.
    [​IMG] [​IMG] [​IMG]
    283john likes this.
  13. 19Eddy30
    19Eddy30
    from VA
    Just depends on builder & how much thought used , we had done a few back before 1990 same with a love ,Ford Carrier & ranger .
    S-10 , Ranger , Toyota
    Junkyard 5.3 Ls Mild cam swap carb or Efi easy high 6 1/8 15 ish mpg . DD
    There are nicer cowl hoods that are not as square , also some with a smooth
    Bulge from fender to fender with out cowl , I believe SunCo makes a nice like tear drop like used on Pro stock &
    P.O.L .
    I have a original 90 C1500 s.b. with 4.3, 80k . Stock Computer TBI , injectors and fuel pump adding just turbo from Subaru & using typhoon exhaust manifold
    to make Constant 3 psi from
    1,800 rpms threw 2,200 cruise , just to make 30-40 more hp constantly dumping over 90% boost out exhaust
    Looking Oem under hood Oem air intake off ps fender & much simpler than oem typhoon set up.
    283john likes this.
  14. 350, 700R4. Factory AC. Lumpy cam, headers, etc. I've owned it forever.
    porkshop, caseywheels and 283john like this.
  15. AldeanFan
    AldeanFan
    I always wanted one of those,
    My dad bought an ‘86 S15 Jimmy brand new with the 2.8 v6. It was a real dog but as a kid I loved that little truck.
    A small block would really have made it a great car and I had hoped for it for my first car but it got sold and I ended up with a Foxbody.
