Technical LT1 camshaft in 90 OE roller block
Discussion in 'The Hokey Ass Message Board' started by grdra1, Mar 29, 2026 at 6:35 AM.
  1. grdra1
    grdra1
    I have a 1990 sbc 4 bolt roller block, Can I use a LT1 camshaft in this block, google states I can with little mods, can you chev guys please tell me what is needed, is it worth the trouble, thanks in advance Glen
  2. carolina chevrolet
    carolina chevrolet
    You'll probably have to use a fuel pump block off plate and use an electric fuel pump.
  3. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Not saying that you have a 880 block, just take in info.
  4. DDDenny
    First gen. LT-1 camshaft or second generation.
  5. gimpyshotrods
    gimpyshotrods
    LT-1 is the original.
    LT1 is the modern.
    rod1 likes this.
  6. DDDenny
    Who knows what the OP knows.
    ronzmtrwrx likes this.
  7. ronzmtrwrx
    ronzmtrwrx
    I wondered the same as you. I didn’t know of the hyphen designation. Now I do…….if I can just remember which is which later. :D
    Scarebird likes this.
  8. Budget36
    Budget36
    This may or may not help, but the 3rd gen crowd used to use the LT4 hot cam.
    Any relation, no idea.
  9. Johnny Gee
    Johnny Gee
    from Downey, Ca
    • 1970–1972 LT-1 – Chevrolet Generation I Small-Block
    • 1992–1997 LT1 – GM Generation II Small-Block
    • 2013–(current) LT1 - GM Generation V Small-Block.
    rod1 likes this.
  10. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    One wishes GM would use different engine codes...
    Tim_with_a_T, mkubacak and rod1 like this.
  11. grdra1
    grdra1
    The reason Im asking is I chasing a hydraulic roller camshaft for my blown sbc and I need a reduced base circle unit as engine is a stroker, ( a local company cannot supply due to no billets at present ). Ive been searching the internet and emailing some company's with limited results, Ive seen some 92-97 LT1 units that I could use if they would fit this block. Glen
    Tim_with_a_T likes this.
  12. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    Delta Camshaft, Tacoma WA may help here.
  13. 19Eddy30
    19Eddy30
    from VA
    I am thinking when you say LT1 cam
    Its 91 -97 correct , Not a LT1 cam 70?
    The cam you have Now the OEM
    Will cam take a " regrind " to your spec
    & cut on small Base circle ?
    I looked up the cam bearings they are same ID & OD sum tho are narrow ,
    The one thing would need to check to make sure lifter does not drop below
    Lifter bore & pi$$ out the oil when on heal of lobe circle !
    About 10 yeas ago I had engine set up by a shop & engine builder did not know the cam was a custom 30 yr Small Base Circle & blew it up in 10 mints on stand
    & if block is non roller , its no big deal to make a cam retainer or just use cam ****on ,
    & you will need to check push rod rocker arm geometry if you are not aware of this .
    Just asking did you mock up rod's
    are they hitting cam if so how much ?
  14. Tim_with_a_T
    Tim_with_a_T
    ***uming you have an OE roller cam block, you can use a 90s LT1 cam. Understand that cam has no fuel pump lobe, so you are stuck with electric fuel pump, and understand the dowel pin is longer on an LT1 cam, so you just cut off the extra length with a hacksaw and you’re ready to rock. It takes a few minutes is all. I did this putting an LT4 hot cam into an 880 roller block. Same principle. Use late model cam retainer plate, with loc***e.
    flatheadpete likes this.
  15. grdra1
    grdra1
    This is the reply I needed, Ive read something similar to this on google, my block is an OE roller, now I may have more options, thanks
  16. Tim_with_a_T
    Tim_with_a_T
    also need a melonized distributor gear, don’t forget about that
    flatheadpete and guthriesmith like this.
  17. Tim_with_a_T
    Tim_with_a_T
    One more response, sorry. I have a stock lt1 cam, pretty sure it has some lobes going flat, but if you wanted to pay shipping and have it reground, it’s yours. Let me know.
    19Eddy30 likes this.
  18. Was planning on stock lt1 cams in my vortec 350s as a budget cam myself
  19. Tim_with_a_T
    Tim_with_a_T
    Keep in mind the LT1 had like another full point of compression, so intake valve close point isn’t ideal for a lower compression engine.
  20. grdra1
    grdra1
    Thanks for reply's, I ended up going with a Comp OE hydraulic roller from Skip White performance. Glen
