Technical Rebuildable ?
Discussion in 'The Hokey Ass Message Board' started by 19Eddy30, Apr 2, 2026.
  1. 19Eddy30
    19Eddy30
    from VA
    Just need's to be Freshen o_O
    Only a few hundred Hp
    jet996, vtx1800, 69fury and 3 others like this.
  2. sixty3
    sixty3
    from Erie, Pa.
    Looks like someone snorted a bit too much laughing gas!
    lostn51, firstinsteele and VANDENPLAS like this.
  3. AHotRod
    AHotRod
    seen that happen on a video today
    19Eddy30 likes this.
  4. 19Eddy30
    19Eddy30
    from VA
    @ Fla, Freedom Factory ,
    Chevy II
    Curious and hope they comment on What the data log said,
    Never seen a block break this way
  5. theHIGHLANDER
    theHIGHLANDER
    That motor was "cranky"...:eek:
    lostn51 likes this.
  6. hotrodjack33
    hotrodjack33
    That's a view of a cam that I've never seen before.
    26Troadster likes this.
  7. tomcat11
    tomcat11
    Boat anchors usually don't need freshening up:eek:
    vtx1800 likes this.
  8. GasserTodd
    GasserTodd
    I reckon with some judicious use of Chem-Weld, that can be rebuilt, and then sold on FaceBook, where all the great deals live :D
    Bonus selling line "Was working when last used"
    lostn51, 19Eddy30 and tomcat11 like this.
  9. gene-koning
    gene-koning
    By golly, you sure wrecked that one! That motor is differently dead! Good job!
    When I owned the dirt track car, I told the drivers that I wasn't pulling a running motor out of the car (we ran used motors, not enough money to fix one). If you want a different motor, blow up the one that is in there! That was when you found out how hard the motor would actually run, or you found out it was nearly dead.
  10. deucemac
    deucemac
    .looks like you are the semi-proud owner of a very large door stop!
  11. Happydaze
    Happydaze
    Long block to short block conversion.
    Chris
  12. oldiron 440
    oldiron 440
    I saw a 400 big block Mopar blow apart like that thirty years ago except it was worse. One side had only the deck surface holding the head on it, it broke across the block through the cam with the other side having more of the top of the cylinders and outside of the block but not much.
    Back in the early nineties Mopar was trying to promote there low deck big blocks in circle track racing and a buddy of mine was given boxes of Hemi cranks, rods and bearings to see what he could do with them. After that engine blew up he went back to his sbc combos and sold me some parts.
  13. partsdawg
    partsdawg
    from Minnesota
    Somebody found a old container of Hydrazine.
  14. cfmvw
    cfmvw
    I'll bet that made a really big noise!
  15. Clydesdale
    Clydesdale
    Is it wrong that I've always wanted to proper grenade an engine like that?
    Call it a bucket list item as you'd need a bucket to clear it all up. :p
  16. willys36
    willys36
    That'll buff right out!
    Reminds me of a VW buss we bought to haul our young family around in back in the 70s. Ran ok for a month or two when the engine stopped dead. We were dirt poor and I figured out, 'how hard can it be to rebuild a VW engine?" When I split the case I found a previous owner had blown the engine and had rebuilt the cam towers using Plastic Steel epoxy. Amazing the engine lasted as long as it did with that fix!!
  17. cfmvw
    cfmvw
    I saw one once where someone was short a lifter and made one out of hardwood. Surprisingly enough, it lasted quite awhile, although the rocker arm eventually galled from oil starvation.
    willys36 likes this.
  18. lostn51
    lostn51
    from Tennessee
    I’ve split late model 5.0’s in half spraying the house down but they were bored and stroked out to the limits. Even ****tered one that had the girdles in, but never shot the entire crank/bottom end out of one:eek:
  19. Some JB Weld should fix it....
    Dave G in Gansevoort likes this.
  20. flatheadpete
    flatheadpete
    from Burton, MI
    Set of rings, cam bearings. Good to go.
  21. HOTRODPRIMER
    HOTRODPRIMER
    How deep is your wallet? HRP
  22. 427 sleeper
    427 sleeper
    They just don't make 'em like they used to :rolleyes:
    hotrodjack33 likes this.
  23. willys36
    willys36
    Speed costs, how fast do you want to spend?
  24. Looks like boring the snot out of it then sleeving all eight cylinders may have reduced the block's structural integrity just a bit...
  25. anothercarguy
    anothercarguy
  26. Doublepumper
    Doublepumper
    from OR-WA, USA
    The extreme method of sonic testing.
  27. ididntdoit1960
    ididntdoit1960
    from Western MA
    anothercarguy likes this.
  28. DDDenny
    You haven't lived until you've witnessed your first dyno pull on your own engine!
    The raised hair on your back is proportionate to the money you have invested.
    Been there!
    427 sleeper likes this.
  29. Paladin1962
    Paladin1962
    Caught the flu... flutabitskaboom
  30. 19Eddy30
    19Eddy30
    from VA
    Not mine ,
    These racer's have DEEP pockets of $$$$$,
    These's are just there Pi$$ away $$$
    Engines , I am sure it was a
    Brodix or Dart ,not production & 2,400 -2,800
    Dry block but not Billet , not even dry sump ,
    43k 1/8 race , 660 to 1320 on virgin asphalt water burn out
    No glue ,
    AWD vs. RWD
    Shootout Testing!
    Craziest Engine
    Failure
    ________________________________
    The Race
    Cleetus' AWD vs RWD
    Shootout - $43,000
    No Prep Race, Crazy Ending
    Both on YouTu
