Hot Rods What engine does this intake fit?
Discussion in 'The Hokey Ass Message Board' started by tlowe, Apr 7, 2026.
  1. tlowe
    tlowe
    Helping a friend identify. Notice the funny angle to meet the head. Also appears to be for a cross flow head. No p***age way for exhaust to go between intake runners. What is it?
    PXL_20260406_150203371.jpg PXL_20260406_150216343.jpg PXL_20260406_150229286.jpg PXL_20260406_150234669.jpg
  2. Tickety Boo
    Tickety Boo
    from Wisconsin
    The mounting angle suggests it's a Dodge, :D slant 6
    VANDENPLAS and tractorguy like this.
  3. BJR
    BJR
    Can't think of another engine with angled ports so I agree Chrysler slant 6.
    VANDENPLAS and Tickety Boo like this.
  4. Black_Sheep
    Black_Sheep
    The port arrangement and bolt pattern in the picture is definitely not for a Slant 6…
  5. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Datsun Z
    49ratfink likes this.
  6. moparboy440
    moparboy440
    from Finland
    AMC straight-6 (199,232,258)
    Johnny Gee likes this.
  7. DDDenny
    I can say unequivocally that it's not for a small block Chevy!
  8. squirrel
    The port arrangement is similar to the 258 AMC straight 6, but the angle and the bolt locations are wrong.
    The fact that there are webs between the ports, and the angle, suggests it's for a cross flow head.
    The fact that it's for 3 one barrels indicates that it's OLD.
    good luck
    Tow Truck Tom and Tickety Boo like this.
  9. jimmy six
    jimmy six
    Not enough angle for a slant 6. Also the exhaust is on the other side of the cylinder head. The manifold in the background looks to be a an old MOPAR product by the flange? Painted like is was on an old truck; I like the freeze plugs under the carb flanges.
    Tickety Boo likes this.
  10. tlowe
    tlowe
    Similar but different bolt pattern
  11. Black_Sheep
    Black_Sheep
    I’m thinking some kind of flathead 6, most “modern” inline 6’s clamp the intake and exhaust to the head using the same hardware for both.
    Just Gary likes this.
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I missed on port shape. Z round, AMC rectangle. Also missed on the webbing Squirrel mentions.
  13. My guess it's for a flathead with some sort of aftermarket head on it, maybe a 'F' head conversion. Or did anyone make a F head six?
  14. squirrel
    flathead inline engines always have the intake and exhaust ports next to each other, so we know it's not for a flathead, since there's no room for the exhaust manifold, or even for exhaust ports.
    jimmy six likes this.
  15. Squablow
    Squablow
    Very interesting mystery manifold. The underside of the center runner looks like it had a casting tag on it, I'd like to see a closeup of the underside of that center runner. I can make it out in the second pic.
    Also, are the round spots directly below (what we are ***uming are) carb flanges open? Like, could you stick your finger through there?
    If they're open, that makes me think they would connect to another mirror image intake with pipes, like some kind of wild V12 or something.
    I have no idea, but I do want to know this one.
    Tickety Boo, squirrel and tlowe like this.
  16. Jeep did but who the heck would go to the trouble of making a manifold for one of those?
    Jagmech likes this.
  17. patsurf
    patsurf
    maybe there was secret hop-up plans in place for jeeps if ww2 lasted longer..
    alanp561 and leon bee like this.
  18. Speed Gems
    Speed Gems
    Didn't Willys make am "F" Head?
  19. They did, but the only versions I've seen were four bangers.
    Speed Gems likes this.
  20. Kerrynzl
    Kerrynzl
    @tlowe
    That port configuration [Ex In In Ex In Ex Ex In Ex In In Ex] Is the same as Ford Falcon 170 / 200 six
    And the angle of the port face is where they milled off the log manifold for a Hotrod triple carb conversion
    compare this
    Moondog13, AHotRod and tlowe like this.
  21. oldiron 440
    oldiron 440
    Ford 250 six, has a bolt on manifold.
  22. d2_willys
    d2_willys
    from Kansas
    Jeep had a six cylinder 161 F head engine. I have one in my Willys AeroEagle.
  23. Kerrynzl
    Kerrynzl
    That is a possibility
    The Aussie 250 2v has a bolt on intake ,the 250 1v has a log intake
    Robert J. Palmer likes this.
  24. squirrel
    it's pretty close, but I doubt that's what the intake was for. Although, if you can find any do***entation for it...I'll easily be convinced.
  25. Oneball
    Oneball
  26. Kerrynzl
    Kerrynzl
    @oldiron 440
    I doubt if it is for the Aussie Falcon 2v head because the bolt pattern is all out of phase and the ports are round . The Aussie head was from an era when triple 1v downdraught carbs wouldn't be used [they'd use Webers]
    Here is the 2V head intake face
    Here's the intake with square ports and the different bolt pattern
    I've seen triple carb conversions on speedway cars [back in my dad's era] where the log was milled off.
    Usually flanges were brazed onto them.
    144 and 170 heads had oval ports with the intake milled off, but some 200's had square ports [below]
    Anything is possible with Racer / Hotrod innovation back when they had to build equipment instead of buying it.
  27. tlowe
    tlowe
    Here is the top side after blasting. 18.5" center of outer bolt to other center of outer bolt
    Second picture is the casting on the bottom.
    AHotRod and Duellym like this.
  28. Fordors
    Fordors
    August 7, 2009 ?
    Duellym likes this.
  29. SR100
    SR100
    This looks like a different manifold. The bottom of the red painted manifold is closed in the third picture:
    The carb mounts look simpler, too.
  30. Yes, but it was at one point a common practice to cut off and mill the intake off.
    Hillborn even made fuel injection for the Falcon 6 and they were raced in midgets.
    302GMC likes this.
