Projects In need of help, Jenkins OHV B motor parts
Discussion in 'Traditional Hot Rods' started by douglasb, Feb 21, 2023.
  1. nrgwizard
    nrgwizard
    from Minn. uSA
    Hey, Doug;
    I must have missed what your builder found to be the issue on the #4 piston +.060 high.
    Too long C-C rod length, or piston pin .060 too low?
    Just curious... I'd guess the #4 was previously replaced???
    Marcus...
  2. douglasb
    douglasb
    So an update.
    Pat has been working his magic on the jenkins and giving her the needed attention. 1st off there was an 1/8 space between the head and motor originally. As the clearances were right. Pat had the head fully welded and milled down to remove the gasket.
    Next he discovered thst it didn't have hardened valve seats so he installed those and went a little bigger with the new stainless intake valves.
    Also while working the rocker arm situation he moved the whole rocker arm ***embly forward and built custom billet aluminum 4" roller rockers so now we have the correct ratio/clearance with the pushrods and block. The jenkins is have is one of the later California ones and the valve covers aren't flat and curve up to clear the intake runners, so in a effort to seal better and not leak oil. Pat cut the bottoms off the valve cover and will weld the bottoms down thus creating a dam to keep the oil in and then the valve covers ca. Seal better being a flat surface. The next thing he is tackling is the oiling system as before they had 1/16 copper line running thru the head/water area and coming out at the rocker stands. To prevent oil line failures he is talking about moving it externally and going thru the bottom damn part of the valve covers now. Pat is doing an amazing job and has so much knowledge when it come to the jenkins and 4 bangers. I just mailed him the vital parts with the plan of him putting it on his test stand to get it dialed in. Pat had been fixing alot of issues from when the motor was first built and dealing with things that we not square or right. Doug
    P1180047.JPG P1190049.JPG P1190050.JPG P1190051.JPG P1190052.JPG P2250065.JPG P2250066.JPG P3080075.JPG P3080076.JPG P3080077.JPG P3080078.JPG P3300087.JPG P4040089.JPG
  3. continentaljohn
    continentaljohn
    Cool thread and great to see the head being put back in service
  4. douglasb
    douglasb
    Slow with updates but reaching the finish line with the rebuild. Alot more has happened with the motor. Flew out this week to check it out in person before she gets shipped from Pat to me in biloxli. Pats attention to detail and craftsmanship is top notch. Also Dave wheeler helped a bunch with his amazing aluminum welding skills. Every part had been touch modified improved and re worked. Super close to firing. Just a couple fuel fittings and should be there.
    Jeff34 and Carter like this.
  5. douglasb
    douglasb
  6. douglasb
    douglasb
  7. douglasb
    douglasb
  8. douglasb
    douglasb
  9. douglasb
    douglasb
  10. douglasb
    douglasb
    P4030405.JPG P4030407.JPG P4020404.JPG P4020401.JPG P4030406.JPG P4030408.JPG Pat had created the file for this intake the intake 20 years ago for the original one he made for Max and his Jenkins. He kept it the same as an tribute to the original.
    Outback, Fordors and GuyW like this.
  11. douglasb
    douglasb
  12. Fordors
    Fordors
    The combination of a rare head, the knowledge and expertise of the engine builder, welder, other machinists and all the suppliers involved was quite a spectacular undertaking, let alone your tenacity to follow through to completion.
    Well done!
  13. hotrodA
    hotrodA
    Well done! That is nothing short of mechanical art.
    warhorseracing likes this.
  14. 1952henry
    1952henry
    This proves the HAMB is the place to see the work of talented craftsman. Wishing you the best when it is ready to fire.
    Outback and jimmy six like this.
  15. Stovebolt
    Stovebolt
    That’s amazing
    Outback likes this.
  16. I'll 2nd stovebolts comment............amazing & a credit to all those involved.
    4BangerDean, Stovebolt and Outback like this.
