Technical Damn Moon Spun Discs / Time for a change
Discussion in 'The Hokey Ass Message Board' started by corncobcoupe, Apr 23, 2026.
  1. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Really liked my Moon Spun Discs on my “ Ember Glow” 39 Convertible but the darn things just won’t stay tight / come loose and fall off. :eek:.
    Even after lock tight, larger diameter screws / lock washers/ as deep as I can go without blowing through the inside of the wheel. Just couldn’t feel comfortable any more worry about that tinga tinga tinga sound of it flying off going down the road.
    Soooo, worked up a hybrid custom cap with 2 bar spinner that should stay on ( fingers crossed ) as it took some umpf to bang them on.
    I like the change but this certainly is personal preference for sure. I like the Moon Spun Disc for sure but also an Old Time Cap with 2 Bar Spinner on a roadster as well.
    First pic is with the Moon Spun Disc.
    The remaining is with the Custom Cap with 2 Bar Spinner.
    It’s personal preference.
    If you don’t like it, that’s ok.
    If you like it, that’s ok too.
    Stogy, marioD, Barn Hunter and 39 others like this.
  2. 325w
    325w
    Looks good on the fendered car. My opinion
  3. tim troutman
    tim troutman
    really like that car
    Tow Truck Tom and Sharpone like this.
  4. Bandit Billy
    Bandit Billy
    They look better IMHO.
    marioD, 40FORDPU, SS327 and 6 others like this.
  5. Clydesdale
    Clydesdale
    Gotta say I prefer the new look, the rest of the car screams custom and Moon discs say race car.
    good work sir!!
  6. J. A. Miller
    J. A. Miller
    from Central NY
    Much better choice! Easier to check your tire pressure too.
  7. hrm2k
    hrm2k
    Either way is good. I happen to love those moon discs
  8. BJR
    BJR
    I think the new caps look way better than the plane moon discs.
  9. 49ratfink
    49ratfink
    what did you use for screws? had an OT daily driver with moons for a few years and never had an issue. I drilled and tapped the rims and used ****on head allens.
    I like the now hubcaps better. hope they stay on.
    wicarnut, hrm2k, Rolleiflex and 2 others like this.
  10. 49ratfink
    49ratfink
    ""as deep as I can go without blowing through the inside of the wheel."" ... this was 30 years ago but I'm sure I drilled through the wheel
  11. Sharpone
    Sharpone
    Looking good
    Dan
  12. Dooley
    Dooley
    from Buffalo NY
    Damn good looking car....
  13. Bugguts
    Bugguts
    New covers fit the custom look better for sure....in my opinion.
    Paul B, lurker mick, hrm2k and 3 others like this.
  14. Dave G in Gansevoort
    from Upstate NY
    Tomayto, tomaahto I like both. But my opinion doesn’t matter. Only your own…
    hrm2k, chryslerfan55 and Sharpone like this.
  15. 5window
    5window
    I like the new ones better. Nice car
    chryslerfan55 and Tow Truck Tom like this.
  16. Petejoe
    Petejoe
    I agree those new ones look much better on that cool old ford.
  17. HSF
    HSF
    from Lodi CA
    New caps look better but if you want to keep your Moons on, use Dzus fasteners.
    51 mercules and chryslerfan55 like this.
  18. swade41
    swade41
    from Buffalo,NY
    I like the new look, when I did mine I used a fine thread ****on head from the backside of the rim. I tapped the wheel, ran the ****on head in with lock-***e, used a flat nut to lock ****on head in place, put on Moon disc then used a little stainless washer and a nylock nut.
    wicarnut, hrm2k, Rolleiflex and 3 others like this.
  19. Lone Star Mopar
    Lone Star Mopar
    Looks great from here !
    hrm2k, Tow Truck Tom and Sharpone like this.
  20. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Ok, I’m guilty of F’ing up with self tapping screws and because the thread is so short, didn’t hold tight enough. When I decide to switch back ( which I like to back and forth for change of looks ) I’ll re-drill the hole a tad larger and TAP the hole / use ****on heads with the Loc***e and lock washer / my lock nut as described.
    Thanks for the reminder.
    Should have done it right the first time. Doh !
  21. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Thanks fellas.
    hrm2k, 5window, 49ratfink and 3 others like this.
  22. swade41
    swade41
    from Buffalo,NY
    I ran a set in the early 90's the traditional way, the screws kept loosening up, then the disc holes got wallered out, then ting ting ting.
    So you could say I learned the hard way and needed a new plan. Since my cars are more racey than custom I'd do the dzus fasteners if I did them again.
    Sharpone likes this.
  23. drtrcrV-8
    drtrcrV-8
    Ditto on the dzus fasteners : being spring loaded, they tend to work well...
    51 mercules likes this.
  24. Rolleiflex
    Rolleiflex
    I'll be the one to go against the grain here.
    While I don't dislike the looks of your new hubcaps, I feel they make the car look too busy with the flames.
    The Moons look a lot cleaner. Great looking car regardless and one man's opinion is just that, so take it with a grain of salt.
  25. Sky Six
    Sky Six
    from Arizona
    That car would look good with any wheel cover combination.
  26. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    No man it’s all good, I get it, that thought hit me first thing too with the flames….busy.
    Then I thought I’ll run these for a while until I get things set up to break it all down again, dismount, re-drill, TAP the wheels, project. There isn’t a lot of flange to work with, so I’ve got to figure out what will work either way, the Dzus / ****on heads.
    I ran the Moon Spun Discs because I like clean look. BUT, I like the Caps with 2 Bar Spinners on a convertible as well to give that roadster look.
    A quick cheaters way to un-busy the Caps is take lacquer thinner to remove the black rings.
    ( A lot of work- maybe soak a Q- Tip or finger foam stick)
    I may still due that which will reduce the busy.
    My attention right now is my 38 Huudlum coupe steering box, getting that sorted out / fixed.
    Plus waiting to get my power steering pump back from Lare’s rebuilding it for my 67 Barracuda Fastback.
    Then I’ve got to DA it with 600 and Wet sand with 800 to get ready to respray it.
    Projects, projects, this retirement is work. :)
  27. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Thanks fellas.
  28. Bearing Burner
    Bearing Burner
    from W. MA
    I held the Moon Disk on with Dzus fittings never had a problem. Made a jig for welding tabs to wheel
    that wat any disk fit any wheel
  29. flatheadpete
    flatheadpete
    from Burton, MI
    Looks great! I really like the knock offs.
  30. Moriarity
    Moriarity
    SUPER MODERATOR
    Got it made
