Technical ***May 2026 Banger Meet Thread - Mother's Day***
Discussion in 'Traditional Hot Rods' started by Jiminy, May 3, 2026.
  1. Jiminy
    Jiminy
    Link to previous month: April 2026 Banger Meet
    Coming Events: (PM Jiminy with additions/corrections)
    Stay safe.
    For the HAMB banger newbies, here are some links to a lot of banger info:
    Jim Brierley's book 4-bangers! And me! is a must read book for all banger enthusiasts. US customers send $34.00 all color except for the oldest pictures (includes S/H in the U.S.A.), PayPal welcome, to:
    Jim Brierley, 39480 Colleen Way, Temecula, CA 92592.
    email: jimb4e4@gmail.com
    phone: 951-695-7313.
    A few links to speed equipment companies there may be more
    https://specialtymotorcams.com/index.php#header
    http://www.millerhi-speedheads.com/index.html
    http://www.modelatrader.com/brumfield/brumfield.html
    https://www.hotforhotfours.com/advertisers.htm
    https://www.secretsofspeed.com/speed-parts
    https://eraspeed.com/
    Bert's, Synder's, Mikes affordable also list some speed performance parts.
    Here is a list of most of the prior monthly banger meet links:
    http://www.jalopyjournal.com/forum/s...d.php?t=161498
    Banger basics. another info link list:
    http://www.fordgarage.com/
    http://www.plucks329s.org/index.htm
    http://www.jalopyjournal.com/forum/s...d.php?t=251717
    http://www.jalopyjournal.com/forum/s...ad.php?t=42480
    The link below shows flywheel lightening dimensions
    http://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/page-4#post-5212157
    and this link shows the missing image from the above post
    http://www.jalopyjournal.com/forum/...-work-on-bangers.1010716/page-3#post-11427055
    The 4 Banger hot rod picture thread.
    http://www.jalopyjournal.com/forum/threads/the-4-banger-hot-rod-picture-thread.997051/
    Model B rod bearing insert numbers
    http://www.jalopyjournal.com/forum/showthread.php?p=6992484#post6992484
    Engine tuning with a Vacuum gauge
    http://web.archive.org/web/20120415...e.com/tuning-with-a-vacuum-gauge-spg-148.html
    Adjusting dual Strombergs:
    http://www.jalopyjournal.com/forum/showthread.php?p=6638461#post6638461
    Helpful Model A tools and tips:
    http://www.maurer-markus.ch/ford_a/tipps.index.en.html
    Gary in MN's late model Malory distributor conversion for A/B engine:
    http://www.jalopyjournal.com/forum/showpost.php?p=9147025&postcount=109
    Elrod's stuck head tech:
    http://www.jalopyjournal.com/forum/showthread.php?t=218487
    Model A generator to alternator conversion:
    http://ejwhitneyco.com/automotive.html
    Gear ratio / speed and RPM calculator:
    http://www.accuautoparts.com/calculator.php
    Model A master cylinder mounting bracket ideas:
    http://www.jalopyjournal.com/forum/s...73#post4953173
    Go here to read the 1931 edition of Harry Ricardo's book "The High Speed Internal Combustion Engine"
    http://www.scribd.com/full/40610101?access_key=key-w2bcjicdancrnxypd05
    Chevy Banger Stuff
    http://www.jalopyjournal.com/forum/s...d.php?t=463465
    Post 198 starts a great discussion of the shape of a flat head combustion chamber
    http://www.jalopyjournal.com/forum/showthread.php?t=470853&page=10
    T-5 5 speed in a Torque Tube:
    http://www.jalopyjournal.com/forum/showthread.php?t=256226
    Model A & B Style Cast Iron Cylinder Head Compression Ratios.
    http://www.fordgarage.com/pages/headcompressionratio.htm
    chryslerfan55 and PGA STUDIOS like this.
  2. 62pan
    62pan
    Checking in
  3. PGA STUDIOS
    PGA STUDIOS
    from Orlando
    Checking in, still hunting for a Model B DOHC
    chryslerfan55, jet996, Jiminy and 6 others like this.
  4. Airborne34
    Airborne34
    from Texas
    Checking in!
  5. So am I!!
    Looks like a HAL and block, no?
  6. Outback
    Outback
    from NE Vic, Oz
    yep I'm here,
    I posted this late on last month's, will throw it up here.
    "Interestingly I've had 2 conversation's which I didn't initiate about balancing Banger's, one is a B with welded C/weights that was balanced but has a vibration just below cruising speed, the other was about a stocker that buzzes.
    there was talk about 'floater' engine mounts causing issues, they both have them.
    what do you guys do with balancing these engines, do you prefer C/weighted cranks? harmonic balancers? I'd be interested to hear your thoughts."
    & the replies
  7. Stovebolt
    Stovebolt
    Checking in.
    I started to set up the Riley 2 carb setup I bought.
    Had both machined surfaces re-machined, as they were way off.
    Went to bolt the 81's on ...... ****** hell!! The guy who drilled and tapped the holes must have been drunk AND needed new gl***es.
    The holes were tapped at an angle and in the wrong places.
    Now to plug them, then re-drill and tap them in the correct position .
    Like we'll need the extra work when modifying these cars.
  8. Outback
    Outback
    from NE Vic, Oz
    Dang on the rework. lettuce know as it comes together
    chlsnk, chryslerfan55 and Deutscher like this.
  9. You will get many opinions on this subject, but, you can only balance an inline 4 to a point, not completely.
    There will always be some harmonics as the pistons accelerate at different rates from top or bottom of the bores.
    Production cars and trucks have attempted to lessen the felt imbalance by adding in counter shafts out of balance to counteract the rotating ***embly. Get one timed incorrectly and it is very bad.
    The absolute best you can do is have the crank/flywheel and if used balancer done to ISO standards.
    Then equalize the pistons, rods both top and bottom ends, that's it.
    There are many who run balancers on these motors, I do not. IMHO, the cranks are not stiff enough to employ one.
    I have removed a few and repaired the damaged crank and gear keys.
    As for cranks, you cannot put enough counterweight on the cranks. Look at the Offy and Millers.
    Best, John
  10. Outback
    Outback
    from NE Vic, Oz
    I understand the thing about opinions :D but yours is one of the ones I hoped to hear,
    I know there are some opposed aircraft engines which have a rpm range which is a no-go zone in terms of constant rpm, it stands to reason that there would always be a range which is not good. Another friend spoke of pushing the harmonics of an Aussie GM 6cyl - which had a habit of breaking cranks when pushed - beyond the operating range by removing materials on the C/weights, his engines tended to hold together.
    all of this made me wonder about our Bangers & good ways to reduce the buzz.... aside from driving slower that is :p
  11. Deutscher
    Deutscher
    from Germany
    I'm working on the coupe's electrics and have installed my relays and fuses in a cookie tin;
    now it's ready to go in the car. Regards, Harald
    chlsnk, chryslerfan55, jet996 and 5 others like this.
  12. Mainedrifter2
    Mainedrifter2
    IMG_1355.jpeg Hello Brothers of the Banger, it’s finally roadster weather here in Maine.
  13. fur biscuit
    fur biscuit
    Happy May! Spotted this interesting model T head, from what I understand “Giant Speed Equip.” was an effort of both Joe Gemsa and Jerry Sherman. This head is neat in that, it appears to have Mr. Gemsa “initials”, Is made out of aluminum and has the V8 60 combustion chamber. The patent reference number is also not accurate, it should send you to the “Haibe” model T head patent number. Fun bit of kit.
    chlsnk, chryslerfan55, jet996 and 4 others like this.
  14. A friend of mine has a DOHC on a Hal Block, might still be for sale?
  15. Saw your email! Ironically, it's got the same patent number as the Simmons Super Power head. The weird thing is, I've also seen a Giant Super Power head. Timeline wise I think Green heads came out in 1918, Waukesha-Ricardo in 1923, with Giant/Haibe/Super Power being released in 1925. I'll have to do more research!
  16. 29Sleeper
    29Sleeper
    from SoCal
    It was 100% Jerry Sherman. Giant Equipment Manufacturing. His son Jerry is still racing the family Ts and one he's built. He was the T winner at last weekends Antique Nationals.
    BTW: Jerry would like to buy the head if you could share the who/where.
  17. For those that havent seen it yet, Time Trials are coming back to Santa Margarita Ranch! Hoping to have the 'ol Slant Window there racing inbetween shooting video! 684391894_1486015569986391_1812194334133593617_n.jpg
  18. 29Sleeper
    29Sleeper
    from SoCal
    Our new to us 26T with Riley 4 Port will be returning this year.
  19. fur biscuit
    fur biscuit
    The patent is pretty cool, and that is one thing that made that particular head extra fun, it has the v8-60 combustion chamber (which i forgot to take a picture of).
    here is the Haibe patent:
    https://ppubs.uspto.gov/api/pdf/dow...jLTQzNzMtOWMyMS05ZjQ4ZDJjZmQyMGEiLCJleHAiOjB9
  20. Outback
    Outback
    from NE Vic, Oz
    All the iterations of performance heads for these old things are fascinating. Is the v860 combustion chamber considered a good one?
  21. fur biscuit
    fur biscuit
    The v8 60 is a compact cc that makes good compression, it was very popular for a long time. How ever it lacks in flow opportunities and it is easy to shroud valves due to the compact nature. Camshaft lobe design needs to be carefully considered to accommodate the limited space to create power without making it very “sensitive” (prone to knocking?). There are better cc’s out there if significant power is to be attained. That said it was a very popular choice for many years.
  22. 282doorUK
    282doorUK
  23. Outback
    Outback
    from NE Vic, Oz
    Thanks, that makes sense.
    After heading down a rabbit hole I came across this May banger monthly meet from 2010 some great conversations re combustion chamber design a****st other things, worth a flick through, some of you were even there!
    https://www.jalopyjournal.com/forum/threads/may-bang-er-thread.470853/
    chryslerfan55 and jet996 like this.
  24. Outback
    Outback
    from NE Vic, Oz
  25. wheeltramp brian
    wheeltramp brian
    Back in a banger! Just scored this today,last ran in 97. 20260506_174105.jpg 20260506_174111.jpg 20260506_174118.jpg 20260506_174130.jpg 20260506_174133.jpg 20260506_174152.jpg 20260506_174212.jpg
  26. Outback
    Outback
    from NE Vic, Oz
    Woohoo, lovely ole tudor!
  27. Fabber McGee
    Fabber McGee
    Good score Mr. Wheeltramp. Must have been a northern car. What did they put in it for a heater?
  28. wheeltramp brian
    wheeltramp brian
    20260508_115719.jpg 20260508_115719.jpg It's got this aftermarket Montgomery Ward heater. It came from Gr*** Valley California then to Palmdale now sitting in my shop in lancaster. Motor is stuck but it's full of the trans fluid and acetone so that's worked for me before
  29. 29Sleeper
    29Sleeper
    from SoCal
    Looks like it had one of the manifold heaters but those were very inefficient in areas with real winter so they updated it with a Monkey Ward water one with a fan.
    chryslerfan55 and Outback like this.
  30. Fabber McGee
    Fabber McGee
    My dad's Tudor had a manifold heater and plenty of holes in the firewall where hot water heaters had been mounted over the years. People looking at the engine would see that heater (his had the cast iron air duct) and ask what it was. When they asked if it worked, he'd say, "Hell yes, that thing gets so hot it'll run you right out of there... in July. By September you'll be wishing it had something a lot better." Haha,
