Rare small block chevy intakes
Discussion in 'The Hokey Ass Message Board' started by Ol' Drippy, Jan 26, 2007.
  1. Fordors
    Fordors
    Zora Arkus-Duntov’s CERV I, the Chevrolet Experimental Research Vehicle .
    When first built in the early ‘60’s it had a well built 283, but later the 377 engine was fitted and other components were changed also.
    Tickety Boo, SPEC and saltflats like this.
  2. DDDenny
    CERV II I believe, one of Duntovs' "skunkworks" projects.
    Edit^^^^^^what Fordors said^^^^^^
    Tickety Boo likes this.
  3. saltflats
    saltflats
    from Missouri
    Did it run?
  4. Fordors
    Fordors
    Absolutely, there was an extensive magazine article written at the time, it might have been in Hot Rod, Sports Car Graphic or Motor Trend. Duntov drove it in testing and I think it was entered in a race and driven by someone else.
    Edit- It was never raced, it only made exhibition laps at some races.
    tractorguy, Tickety Boo and saltflats like this.
  5. Fordors
    Fordors
    Early lakes racer and engine builder Bob Joehnck knew Vic Edelbrock Sr. and Vic Jr. In 1965 Joehnck convinced Vic Jr. that there was a market for a SBC aluminum four barrel intake. Here’s a Joehnck MK-1, Vic Jr. cast those for Bob to sell at his shop, and that was the genesis of the C-4B.
    rod1, tractorguy, Tickety Boo and 2 others like this.
  6. DDDenny
    A little sidetrack.............Been looking at some history on Duntovs' "lightweight" engine program, seems this was untilled ground, new technology to cast aluminum heads and blocks, I sure wish I had a half dozen of those engines from Zoras' various programs.
    Apparently to save weight they tried running without cylinder bore liners, valve guides and seats.
    Spotted an oddity (for 1962/63) on this aluminum head, anyone else notice it.
    Hint, it's not the guideplates/studs.
    From
    Here:
    https://www.corvetteforum.com/forums/c1-and-c2-corvettes/4760754-63-gran-sport-aluminum-heads.html
    tractorguy, Tickety Boo, rod1 and 2 others like this.
  7. 1biggun
    1biggun
    Exhaust ports stud location is at a angle on the end ports.
    tractorguy and Tickety Boo like this.
  8. patsurf
    patsurf
    thanks!
  9. 19Eddy30
    19Eddy30
    from VA
    Floor inside of head has been cast in way just for intake ports / runners & coolant p***age.
    Skeleton cast .
    Weight saving & need for push rod guide plate .
    I think for the angle outer mount
    was done for strength & porting enlargement
    rod1 and Tickety Boo like this.
  10. Pav8427
    Pav8427
    I see posituve valve seals.
    Wonder how early those came out.
    Thought thise would be wuite a bit later.
