rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. Talking to Bruno the fluid was rerouted. The pressure built up in the converter. It got supper heated unable to return to the pan. The seal got pushed out. Leaking fluid caught on fire exploding the pan. The gears broke after that. The new Bruno arrives tomorrow. New tires today. It might run at the Grove next weekend for testing
    chryslerfan55, Tim, porkshop and 11 others like this.
  2. 19Eddy30
    19Eddy30
    from VA
    I am sure your crew seen & you by video ,looks right after Pre stage bulb on
    Big puff on P.S. Then almost instantly Stage bub On , tree fell .
    When you say Rerouted ,
    Now or then ?
    Fix a bigger return port ,line to pan
    Or maybe bigger vent
  3. No. Connect the two cooler fittings together with a line. Done.
    chryslerfan55, TFoch and RMcCulley like this.
  4. 19Eddy30
    19Eddy30
    from VA
    Cooler will be byp***ed ,
    If So cooler too big
    Or to small.
    Looks over winter cooler was removed from in front of tank , Looked to been a B&M , was that cooler moved to your
    Recirculation cool down tool /Dolly .
    If so was another add to car in different location ,
    If so same model or another brand & if so a different GPM ,
    I have seen some cooler have a
    # 8 or 10 fitting then on inside
    Neck down some 1/4 , 5/16 or 3/8 port
    Same with steel hyd fitting's
    Not smooth & free flowing causing cavitation creating air pockets .
    I seen racer that I was around 20 yrs ago where using Bruno in 1,500 -2,000 hp
    Tq 1,000 to 1,500 ish , then wants up into 2,300 plus switched to autos & lock up , on average 25k trans & converter.
    Now there are many going back to
    B&J , Lenco ext & if not using a clutch they have sorta big stock of parts for @ race serviceable converter ,
    Some of these racer's I can not rap my head in how they are funding
  5. RMcCulley
    RMcCulley
    Could you run a kevlar diaper around the transmission to help contain things?
    chryslerfan55 and porkshop like this.
  6. tomcat11
    tomcat11
    Trying to make sense of this. Deliberately rerouted (via fluid cooler) or by malfunction. The picture above with the gear and the cracked housing is the Bruno converter drive Pump is it not?
  7. Calkins
    Calkins
    Last season, Brian had a car mounted transmission cooler that was not up to the task with the increase in performance that the car would be seeing this season. He built a remote mounted transmission cooler cart that was quick coupled to the transmission between rounds. To correctly make this swap, Bruno did not tell Brian that he needed to add a hose between to two cooler ports on the transmission for it to function without the transmission cooler cart attached. That caused the pump pressure to dead head in the converter and multiple problems compounded until the weakest link exposed itself at the worst possible time.
  8. 19Eddy30
    19Eddy30
    from VA
    That explains big puff of smoke
    Like a Alky engine coming up on
    8k rpm's , Pan split . Nitro leave with
    2,000 -2,400 idle .
    Surprised made it threw start up's .
    My self threw a thrash in dark one time put disc pad in backwards , ruined a hat
    Lucky dual handbrakes 4 calipers on the rear & laundry bag
  9. mohr hp
    mohr hp
    from Georgia
    Thanks!
  10. They don't make a diaper for a Bruno.
    wicarnut and chryslerfan55 like this.
  11. 19Eddy30
    19Eddy30
    from VA
    There are few company's that will make to order , Flame retarded should be around
    500 Ish, Kevlar 1k
    One company stalled me for 2 months so I made my own , & lined with exorbitant pads
    chryslerfan55 and jimmy six like this.
  12. Light the fuse and move back. The entire drive train is back in. Jerry Kaye has the body looking good. The floor is ready to go back in. I have a few small items to finish. The drivers side window and windshield need to go back in. It's almost ready to fire and track test. Thanks to my great crew on knocking it out . We never quit. PXL_20260425_205501776.jpg PXL_20260425_210340030.jpg PXL_20260426_035748400.jpg PXL_20260426_035821083.jpg PXL_20260426_035840024.jpg
  13. Happy 426 day hemis and wedges.
  14. RMcCulley
    RMcCulley
    Pretty awesome turnaround
  15. Tim
    Tim
    from KCMO
    Man, I know you’re a race it, brake it, fix it and make it faster wash and repeat kinda guy but even I was a little surprised at the quick turn around from the carnage I missed in the last few pages!
    stop getting post notifications and Brian has exploded the car and put it back together two times since the last time I checked in lol. Talk about go big or go home! Love watching this thread man. Glad you are safe.
  16. mohr hp
    mohr hp
    from Georgia
    No doubt! Brian is not going to his grave with a bunch of "Shouldda Wouldda Couldda". He's grabbing life by the horns.
  17. 5w Jen
    5w Jen
    from Sweden
  18. If you ever wonder why I work so hard it's because of my experiences in health care. So many times patients have said if I had only known I was going to get sick I would have lived life differently. They say I would have sky dived; taken that trip to Europe etc. So do it while you can. I know someday I won't be able to do what I do now. Go live life.
  19. FinnishFireball
    FinnishFireball
    Well put Brian! I once had a sticker on my dragster, "Life is short, live fast"
  20. DDDenny
    My wife says "eat dessert first..........life's too short"!
  21. My mom always said that.
  22. Watch for the drag illustrated magazine next issue. They are doing a recap on the race. They are doing something on me with the final round.
  23. We have these cool 2 inch diameter stickers available now for 2.00 I can send them in a envelope. Just send me a pm.
  24. S/FC Racing Team
    S/FC Racing Team
    For an in-depth look on what went wrong and what went into rebuilding the Street Fuel Coupe, checkout the links below! A lot of hard work went into getting it track ready again and pretty soon some testing will take place. Stay tuned and stay cool!
  25. The metal work is done. Moving on to putting the interior back together. Seat; dash; floor; tach; belts; radio; fresh air; Bruno bottle; wiring etc. PXL_20260506_005944361.MP.jpg
  26. It's ready. Testing Saturday at the Grove. New gloves from Simpson arrive tomorrow.
  27. mad mikey
    mad mikey
    Looking good Brian and crew. Have a great test day.
  28. TFoch
    TFoch
    Awesome turn around by your team! Hope testing goes great!
  29. kabinenroller
    kabinenroller
