Projects A New England Drag Coupe
Discussion in 'Traditional Hot Rods' started by 51box, Apr 22, 2025.
  1. 51box
    51box
    from MA
    Thank you @Adriatic Machine that worked
    Going back quite a ways but I had an idea for a neat set of headers with belled tips in a grouping I hadn’t seen before. IMG_2430.png
    A shot of the headers ,also showing the shell support rods
    Making this decklid was one of the more challenging projects on the car. While it’s far from perfect I learned a lot on it and am happy with the result.
    Put a cool diamond shape pattern on it for my buddy Mike to punch the louvers. It hinges like factory and uses a Dzus in the center as the “latch”
    Rolled outside to see how everything is looking
    Next up was repairing all the rot on the back of the car and building some aluminum wheel wells with some nice louvers, again punched by Mike IMG_2435.png IMG_2436.png IMG_2438.png
    A couple shots while I was finish welding the ch***is.
    The car is all apart now and I’m gearing up the start on the bodywork/paint. Thanks for the support guys, I’ll keep things updated as I make progress with the paint.
    Stogy, lurker mick, AHotRod and 15 others like this.
  2. Royalshifter
    Royalshifter
    Moderator
    Killer.
    Stogy and porkshop like this.
  3. Dave G in Gansevoort
    from Upstate NY
    Will the roll bar meet NHRA requirements, in case you want to run it on a sanctioned track?
  4. 51box
    51box
    from MA
    Definitely not NHRA compliant, I have a few outlaw tracks in my region I can run at and check out Northeast Vintage drags for early style drag racing events. They do a race in NY at the Seneca army depot on the old airstrip.
    Stogy, AHotRod, rod1 and 9 others like this.
  5. Outback
    Outback
    from NE Vic, Oz
    What a cool coupe, it'll be killer seeing it run down the track! Thanks for updating the thread, I missed it first time round, will sub & follow along.
    Stogy likes this.
  6. Clydesdale
    Clydesdale
    This thing just looks cooler with each update, keep going sir!!
    Stogy likes this.
  7. Outback
    Outback
    from NE Vic, Oz
    Stogy and -Brent- like this.
  8. swade41
    swade41
    from Buffalo,NY
    A lot of nice work, how much compression are you planning for the 283
    Stogy, Outback and porkshop like this.
  9. 51box
    51box
    from MA
    The engine plans changed quite a bit since I started this project. The engine is all done now and dyno showed 470hp 415tq it’s a 350 block running dome pistons 12.6 compression , TF aluminum double hump 175cc heads, .600 lift solid roller, six 97’s with a magneto. It should be a pretty wild ride in the little coupe!
    Stogy, Dedsoto, AHotRod and 6 others like this.
  10. wheeldog57
    wheeldog57
    You bringing it up to Oxford Joe?
    porkshop likes this.
  11. NealinCA
    NealinCA
    Nice workmanship and I love where this project is headed. Looking forward to more progress.
    Stogy, Deutscher, 51box and 2 others like this.
  12. 51box
    51box
    from MA
    Hey Ron i still have a ways to go before the coupe is done, I’ll have the roadster up in Oxford. See you there
  13. 51box
    51box
    from MA
    This is the paint I bought for the coupe, it’s a 1957 Coral Red. IMG_1502.jpeg
    Stogy, AHotRod, Deutscher and 5 others like this.
  14. Awesome project! So you like the aluminum camel hump heads?
    Stogy, Deutscher and Outback like this.
  15. 51box
    51box
    from MA
    Thank you, I originally bought these smaller runner heads when the plan was a 4” bore 283 but then I ended up doing 360ci. The heads I have are 175cc 2.02 1.60 but they also sell a 200cc runner version. I believe it would have easily made over 500hp if I had the bigger heads.
    Stogy, porkshop, Richard D and 3 others like this.
  16. AHotRod
    AHotRod
    After all these years here, I have finally found someone who loves the same old 2 drag Coupes I have..
    Your build is excellent ... and it's gonna-be-a-ripper !
    Love the color choice too !
    Deutscher, Stogy, porkshop and 3 others like this.
  17. Partypants
    Partypants
    Mate, you got this. Love this thing.
    Marty
  18. Stogy
    Stogy
    @51box, you never disappoint...nice Hotrod...;)
    51box, Outback and Deutscher like this.
  19. TheGame
    TheGame
    from Sweden
    Any updates on the coupe?
    AHotRod and porkshop like this.
