Technical Front cover distributor
Discussion in 'Traditional Hot Rods' started by reffiesj, May 16, 2026.
  1. reffiesj
    reffiesj
    Is there a performance benefit from a front cover distributor drive? Simple question but can’t seem to find an answer anywhere.
  2. TCTND
    TCTND
  3. Jack E/NJ
    Jack E/NJ
    from NJ
    Yes. I seem to get distributor things done faster when it's in front except when it's a helmet or crab.
  4. yellow dog
    yellow dog
    from san diego
    If you have super high valve spring pressure and you don't have crank triggered ignition, you might be a better off
    with the ignition timing not effected by cam twist oscillations. You still have the problem with chain or gear slop though. So unless you intend on building thousands of horsepower the only advantage might be access
  5. jimmy six
    jimmy six
    You can tell all your friends it’s Ford…. “See the distributor is in the front”:rolleyes:
    I use that with my “wye” block… see the distributor is is in the back so it must be a Chevrolet! Right.
  6. 19Eddy30
    19Eddy30
    from VA
    There is multiple benefits besides room from rear to front even if each benefit is 1/16 hp it adds up .
    There more to a distributor if you examine the working , component timing more then most think out side rotor to pole , point cam ,pick up .
    & Quality , Precision matters
  7. Jack E/NJ
    Jack E/NJ
    from NJ
    No distributor maybe even better. But some said it won't work.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    It worked but had worse issues than cam twist.
  9. reffiesj
    reffiesj
    Thanks everyone - am going to take that as a no for a banger street / strip performance engine…
