Shortest short bus ever? It’s got to be close
Discussion in 'Off Topic Hot Rods & Customs' started by anthony myrick, Apr 10, 2026.
  1. Picked up a gm trans. A np440. Or the gm version of the mopar 3 speed OD.
    I have a mild 350 and a stock 292 Chevy.
    The bus has a hydro clutch so keeping it manual is EZ and sounds fun.
    But, that’s a bit down the road.
    The bus body will get bolted to the ch***is, door bottoms cut and steering hooked up.
    And that’s it for a while
    Okie Pete, X-cpe, RodStRace and 3 others like this.
  2. C60 fender trimmed to fit the bus cowl
    Wheel just sitting there. Lugs too short.
    This wheel is busted.
    Fixes the drop issue.
    Might go this route.
    I have 2 c60 running board extensions that will cure the rear of the fender height issue.
    Okie Pete, Nostrebor, RMR&C and 4 others like this.
  3. RMR&C
    RMR&C
    from NW Montana
    Wow, that looks way better to me! Not that I have a vote......
    Nice work, keep it coming!
    Okie Pete and anthony myrick like this.
  4. Good luck on the short bus.
    Had a good friend that bought a short bus from the local school system. Said he bought it to haul all the fat boy friends to the swap meets. Unfortunately he p***ed too soon. As pallbearers, we rode on the short bus behind the he**** to the cemetery. RIP Holmes.
  5. Nostrebor
    Nostrebor
    Darn tootin!
    Your current combination of C60 fenders and lowness is full of win. Keep swinging for the fences!
  6. My other bus has the large truck fenders. I’ve always wondered what it would look like with the regular fenders.
    im glad I put both style fenders on this one.
  7. Friend built this one a few years ago
    the wheels are 8 lug that hid under a chrome cap with faux big truck lugs
    Hmmmm
    Okie Pete, RMR&C and porkshop like this.
  8. Greg Rogers
    Greg Rogers
    Wow, I just looked at this thread- pretty damn cool!!
    porkshop and anthony myrick like this.
  9. Hauled of the leftovers from the bus and the “new” ch***is
    rear section of frame s****ped for $200
    This pile was almost $300
    Cost of bus plus “new” frame = $700.
    Subtract $480 for s****
    Total cost of bus at this point, $220
  10. oldiron 440
    oldiron 440
    You’ve seen it done on pickups when they mount the body and box backwards on the frame so it looks like the truck is going down the road backwards, now do that with a bus and you’ve got something…:)
    Or build a bus with two fronts on it, one at each end, you could build a trailer using the back half’s….:)
    porkshop likes this.
  11. No
    badshifter, porkshop and Uncle Ronn like this.
  12. oldiron 440
    oldiron 440
    Ah you seem like the perfect guy to do it…o_O
  13. hotrodjack33
    hotrodjack33
    Uh oh!
    Although it's is non-functional...
  14. Okie Pete
    Okie Pete
    I vote for the big truck fenders also . I like how the fender flare goes out to the side of the bus .
  15. DDDenny
    Cool telephone booth, remember those!
    Okie Pete, porkshop and hotrodjack33 like this.
  16. hotrodjack33
    hotrodjack33
    Yep. Every time I walked past one, I'd check the coin-return for a forgotten dime...once in a while I'd get lucky.
  17. Okie Pete
    Okie Pete
    Anthony what do you use to drill out the rivets on the body panels ? Could you post a picture of the tool ?
    anthony myrick likes this.
  18. Hmmmmm
    We carefully ground some the heads off on my other bus with a cut off wheel
    But that can often scar up panels were trying to keep clean.
    so for saving those panels we ground a flat spot on the rivet and drilled off the head
    Okie Pete and 41 GMC K-18 like this.
  19. Okie Pete
    Okie Pete
    There’s never an easy way to do things right is there .
  20. RodStRace
    RodStRace
    Pay a pro, it's easy!
    Better hope you earn enough to pay him and all your other bills too!
    Okie Pete likes this.
