Hot Rods F-1 Brakes on 40 spindles
Discussion in 'The Hokey Ass Message Board' started by F-head, May 25, 2026.
  1. F-head
    F-head
    Anybody have the part number for the bearings, and seal. I believe you just have to radius the inboard inner race to seat properly on the round spindle if you have the correct bearing.
    The regular 37/48 outer bearing still works ? Or do I use the F-1 outer bearing ?
    Thanks in advance
  2. RICH B
    RICH B
  3. RICH B
    RICH B
    Need to trim the top rear edge of the spindles to clear the wheel cylinder.
  4. RICH B
    RICH B
    Radius ground on the inner edge of the bearing to match spindle.
  5. F-head
    F-head
    I’ve fit these up before so I knew about the spindle I just needed the part numbers
    I really appreciate you taking the time to post this up
    Thanks a bunch
  6. F-head
    F-head
    Hamb strikes again. Thanks again RichB for the great information
  7. ramblin dan
    ramblin dan
  8. Mr48chev
    In past things I have read about the swap they say to put tape over the rollers of the bearing to keep the grit out. Not a bad idea. I've found that the "chain saw sharpening stones" that they sell for Dremel tools at ACE and other hardware stores do a nice job of cutting metal like this if you are gentle and don't apply a lot of pressure.
    RICH B and panhead_pete like this.
  9. RICH B
    RICH B
    Bearings protected like @Mr48chev describes:
    chlsnk and panhead_pete like this.
