Technical Carter WCFB tech
Discussion in 'Traditional Hot Rods' started by carbking, Dec 15, 2013.
  1. carbking
    carbking
    I didn't even look at the picture, as this is a WCFB thread.
    Some of the marine 4-Jets are 700 CFM; makes a wonderful "street sleeper". "See, I still have the original little Rochester on this engine, how do you think it would run if I put on a Carter or a Holley carb?"!
    Jon
  2. GlassThamesDoug
    GlassThamesDoug
    Correct... my bad, was working on 4 jets too.
    Sharpone and enloe like this.
  3. GlassThamesDoug
    GlassThamesDoug
    These marine 4jets look like no real estate left for throttle blades.
  4. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They are quite similar to the 4GC that came on a 340 HP 409.
    Sharpone and GlassThamesDoug like this.
  5. GlassThamesDoug
    GlassThamesDoug
    WCFB - Leather accelerator pumps. Where can I get them. Accel pump seals in rebuild kits seem easily damaged by alcohol blended fuels.
  6. carbking
    carbking
    There are a few on Ebay if you know exactly what you are looking for, and the Ebay vendor has exactly what you want. There were quite a few different accelerator pumps used in the various WCFB carbs.
    Otherwise, the leather pumps are included in the better rebuilding kits.
    Jon
  7. GlassThamesDoug
    GlassThamesDoug
    Thanks, I can measure bore dia, and plunger length.
  8. carbking
    carbking
    Would be nice if it were that simple.
    Some are vented, others are not.
    Some are articulated, others are not.
    Some attach with a slot and round hole at the top, most with a round hole only.
    If you have an identification tag number, I can look up the part number of the pump.
    Jon
    stillrunners and warbird1 like this.
  9. jimmy six
    jimmy six
    not just Chevrolet. I advise you to get extended idle adjustment screws for the rear carb.. a 1/4” open end ignition wrench will come in handy. IMG_4007.jpeg
  10. GlassThamesDoug
    GlassThamesDoug
    jimmy six likes this.
  11. warbird1
    warbird1
    What he said ^^ I had the same issue with the WCFB's on my Edmonds Cad manifold. Those adjustment screws make all the difference in the world.
  12. GlassThamesDoug
    GlassThamesDoug
    7015090 on 4jet carbs.
  13. carbking
    carbking
    Accelerator pump part number 7013472.
    If you are unable to find the pumps alone, rebuilding kits containing leather pumps are available.
    Jon
  14. jimmy six
    jimmy six
    Yep. 1953 Olds WCFB’s same #’s. Been on 8 years. Trouble free so far!
    GlassThamesDoug and stillrunners like this.
