32 ford hemi low boy
Discussion in 'Off Topic Hot Rods & Customs' started by ALLDONE, May 10, 2026.
  1. ALLDONE
    ALLDONE
  2. ALLDONE
    ALLDONE
    anyone know this car??? or any history??
  3. ALLDONE
    ALLDONE
    I put it here to not get deleted... has radial front tires..
  4. 19Eddy30
    19Eddy30
    from VA
    No help ,
    & I am sure U R being sarcastic "tire's"
  5. SS327
    SS327
    Are you going to paint that sharp looking car flat black too?
  6. douglasb
    douglasb
    Damn Steve that ones sweet. Steel body?
  7. ALLDONE
    ALLDONE
    like the 55 IMG_20260504_154050.JPG IMG_20260504_154105.JPG IMG_20260504_154117.JPG IMG_20260504_154129.JPG ???
  8. ALLDONE
    ALLDONE
    or the 58??? IMG_6095.jpg IMG_6096.jpg IMG_6097.jpg IMG_6098.jpg IMG_6099.jpg IMG_6100.jpg
  9. ALLDONE
    ALLDONE
    I think the paint on the 32 is fine..... wheels and tries another story..
  10. hotrodjack33
    hotrodjack33
    Holy **** Steve!!! How many cool cars does this one make?
  11. ALLDONE
    ALLDONE
    so guys... what to do about the wheels and tires??
  12. ALLDONE
    ALLDONE
    over 30...
    clem, chryslerfan55 and hotrodjack33 like this.
  13. ALLDONE
    ALLDONE
  14. ALLDONE
    ALLDONE
    I think I could do with out the white walls,.. and for sure the 10'' wide rims in back... not sure about the astro's but I could move the fronts to the rear??? and get a set of 5's for the front...??? I think the black wall tires would tone down the chrome a little???
  15. ALLDONE
    ALLDONE
    heres an old pic with hub caps..
  16. ALLDONE
    ALLDONE
  17. 19Eddy30
    19Eddy30
    from VA
    I personally think
    Wrong tire's
    With Hub cap's .
    & wrong tire's tread & style
    On F rim's offset with 5 spoke
  18. ALLDONE
    ALLDONE
    there's sum ting wong.... the 10'' reverse rims to start for me... can't put a finger on it yet .....maybe just pull rims and tires of the other 32's i got ... the rear shot is horrible... not knocking others cars... but that look is just not for me... I like the cheater slick look... but it looks like socks on a rooster on this car...hope'n to get the members to help here with differant idea's...
  19. ALLDONE
    ALLDONE
  20. 19Eddy30
    19Eddy30
    from VA
    I am particular on tread design & how much over on side wall .
    I think yr 32 5w front tire tread would look nicer on roadster front on the 5 spoke that are on roadster ..
    The roadster with hub caps same tread pattern that the 5 w front tire's on all four , then that depends on rim width.
    I have ground & buff tires .
    AI program would help but I do not
    Know how to use or know of a Good one .
    I have used a free one "paint" just for a color change that was easy but it only allowed one use then wanted $30 month , I was just curious what one of my cars would look like in a different color
  21. ALLDONE
    ALLDONE
    both my 36 ford have white walls...but not the 37 chevy IMG_0629.jpeg IMG_5809.jpg IMG_5812.jpg IMG_6133.jpg
  22. ALLDONE
    ALLDONE
    I don't know how I get in to these deals... the car bolt paten is chevy front... ford rear.... my coupe haes ford rear... with 820 15 firestones... so i could just pull a rear wheel off it... ,put it on the roadster and see if it fits and how it looks??? but... cost factor..( I'm cheep) gets in the way when you have so many cars.. and a yard full of tires and wheels... theres a fat stack of money invested in the tires and wheels on the car.. but the 10'' reverse wheels won't work on nothing I own.... putting the 6'' astros on the rear>>> they are reverse also.... putting the slicks (10.00/15) on the 6'' rim...???? might work...???? then paint, dye the whiite wall??? then buy 2 15x5 astro for the front and some 5.50 bias tires??? just the front set up would be north of 1000 bucks...probley need to put it on jack stands and start over...???? putting $3k in tires and wheels would be hard to do...
  23. Gahrajmahal
    Gahrajmahal
    Alldone, for my money it’s perfect as is
    chryslerfan55 and ALLDONE like this.
  24. ALLDONE
    ALLDONE
    I was thinking goning to a 7 or 8 on the rear??? the 10 sticks the tire way out there..
  25. ALLDONE
    ALLDONE
    I think this is the same tire on a 7'' wheel.... maybe an 8 but need to check...
  26. ALLDONE
    ALLDONE
  27. ALLDONE
    ALLDONE
  28. ALLDONE
    ALLDONE
    al righty then...
  29. ALLDONE
    ALLDONE
    well''' i WAS WAY OFF.. ORDERED 4.5 BOLT WHEELS... WRONG... so oredered 4.75 bolt wrong.... they are buick 5 on 5 in front... so couldn't find fronts 5'' wide with the 5 on 5... so went with steel wheels for now... IMG_1071.jpeg IMG_1072.jpg IMG_1073.jpeg IMG_1074.jpeg IMG_1075.jpeg IMG_1076.jpeg IMG_1077.jpeg IMG_1078.jpeg IMG_1079.jpeg IMG_1080.jpeg IMG_1071.jpeg IMG_1072.jpg IMG_1073.jpeg IMG_1074.jpeg IMG_1075.jpeg IMG_1076.jpeg IMG_1077.jpeg IMG_1078.jpeg IMG_1079.jpeg IMG_1080.jpeg
  30. ALLDONE
    ALLDONE
    so here's with the hub caps on, keep in mind,.. ford caps won't fit the boyd steel wheels... got mine at so cal in vegas.. IMG_1082.jpg IMG_1083.jpeg IMG_1084.jpeg IMG_1085.jpeg
    Okie Pete, clem, Baumi and 2 others like this.
