rebuilding after the crash
Discussion in 'Off Topic Hot Rods & Customs' started by racer-x, Sep 19, 2015.
  1. S/FC Racing Team
    S/FC Racing Team
    enloe, chryslerfan55, TFoch and 8 others like this.
  2. loudbang
    Found this 3 hour Drag Racing special and it has Brian's car. He appears at 56:19 1:16:40
    2:21:30 2:56:30 and 3:35:80.
    Found at
  3. 19Eddy30
    19Eddy30
    from VA
    Norwalk Qualifying,
    It looked, sounded that the converter,
    Slipping over 50%
    Brian I think he will let us know in detail
    chryslerfan55 and porkshop like this.
  4. When I put the new Bruno together a spiral snap ring broke. I called Bruno's to get another shipped. He said you don't need it put it together. As it turns out I do need it. Without it there is a huge reduction in pressure.
    Needless to say the car went no where. It's apart waiting for the snap ring. We might go to the Grove Sunday.
  5. 19Eddy30
    19Eddy30
    from VA
    Thats frustrating when you call the manufacturer and get the wrong information. its on of those $2 parts .
    Transmission related
    a local racer I am around Trans pressure set 10psi higher then recommended ,
    Pressure in pump pushed the T-Q out
    pushing against trust bearing pushing crank closing off oil feed by half taken out bottom end of 20k 5 p***es .
    Fix ,monitoring trans pressure & chamfer enlarging feed hole & setting up trust wear gauge ,
    4:50's drag radial 415 cid.
    Brain , About how long does it take to R&R yr trans ?
    chryslerfan55 and Deutscher like this.
  6. That video was from a few years ago. We still had the small tires on it. We were starting to really make power. Up until then the small tires were fine. By the end of the season we knew what we had to do.
  7. Running the car at Wisconsin international raceway for the Gost Rods event. A nostalgia event with the Brew City G***ers. Stop out and smell the nitro.
  9. Tim
    Tim
    from KCMO
  10. impala4speed
    impala4speed
    Best of luck to you Brian!
    porkshop, chryslerfan55 and racer-x like this.
  11. The event has been cancelled. Rainout. No reschedule date at this time.
    We will now be going to Union Grove for the swap meet in the county Fair Park. Nitro fire ups will happen.
  12. I experienced nitro in-person for the first time a couple of weeks ago. NHRA in Epping, NH. I was fortunate to have pit access with one of the top fuel teams. OMG!!! I have been to drag races before, but nothing like that. The sounds, the fumes, the fury, the feeling at the hit. Unreal.
  13. Fun isn't it. Nothing like it.
    Nitro Chaos mokan cancelled because of the weather.
    We will be at the swap meet in Union Grove at the Fair Park. We will fire up the car. The following weekend we will be attending the out of site drags at the Grove. Be there
  14. Absolutely nothing like it.
    porkshop, chryslerfan55 and TFoch like this.
  15. jimmy six
    jimmy six
    I hope you sells lot of shirts!
  16. I picked up this Grob band saw today. It was serviced by a very experienced machine repair man. It's like new. It has a blade welder on it. Runs on 220 with a one horsepower motor. It came with ten new high speed blades. It was lifted onto my open trailer with a fork truck. Getting it off we used my car lift. It's always a tense time lifting this heavy stuff. Going slow and careful prevents a mess or injury. My friend will come over and wire it up this week. This saw is heavy duty. PXL_20260621_222434481.MP.jpg PXL_20260621_222419040.jpg
  17. PXL_20260623_222709656.jpg I got this surface grinder a few weeks ago. The guy I bought it from bought it brand new. He said it has less than ten hours on it. The magnet is good. It came with several styles of magnetic parts holders and a stack of wheels. It was in his way so it was free. You don't need them often but when you do it's nice to have.
  18. The latest Drag Racing Illustrated magazine has the results from Texas. Screenshot_20260616-193128.png Screenshot_20260616-193912.png Screenshot_20260616-192402.png
  19. We will be at my home town track Union Grove for a booked in show. The Out of Site Drags out on by the Brew City G***ers is a great vintage show. Friday and Saturday there will be nitro in the air. We might do some quarter mile hits to try and get 200 mph.
    Sunday we will be at the show in Waupon wi for some paid fire ups. It's a busy summer.
  20. Calkins
    Calkins
  21. Fordors
    Fordors
    Brian’s hero card from the early days-
  22. I still have several hundred of those.
    Runnin shine, enloe, porkshop and 3 others like this.
  23. Everything cool? Hopefully so much racing that there’s no time to post updates.
    milwscruffy likes this.
  24. milwscruffy
    milwscruffy
    Pretty sure all good. I saw Brian in Byron and the blower on the car had an unusual blow up. More parts breakage and part of the game.
    porkshop likes this.
  25. Thanks for the update. I think of him and his team from time to time.
  26. kabinenroller
    kabinenroller
    I saw Brian Thursday evening, everything is fine. He is ready for Cordoba and the next round of Nitro Chaos.
  27. 19Eddy30
    19Eddy30
    from VA
    Unusual blower blow up?
    Hydraulic the blower ?
    Stuck intake vale ?
  28. PXL_20260629_003218339.MP.jpg PXL_20260627_003706976.jpg A cast blower rotor failed after ten years of running. The pieces flew up through the screen that separates the blower and injector into the injector hat. Nothing fell into the engine. This happened after a p*** as the engine shut down. Unbelievable that there was no other damage. No nitro driver I talked to has ever seen this. We pulled the heads at the track because you just have to check things out. I borrowed a blower from a friend and it was back together that night. When I got home the engine was torn down. I found back sided pistons. This scuffing happens when the oil gets polluted by nitro and alcohol. Fuel gets past the rings and goes into the oil pan. We do change the oil before each p***. The burnout and staging is where most of the fuel comes from. A high/ low side valve does help. While apart the cylinders were honed with a rigid hone finished with a rabbit turd hone. A bore gauge was used to keep them uniform while not putting too much clearance in the bore. New rings and pistons finished the short block off. The heads were taken apart. Springs were checked for pressure at 1.950 inches. The valves were check out then lapped in.
    This past weekend the Nitro Chaos race in Michigan was rained out. With four days off I got back on my 66 Chevelle. We are still in second place with one race remaining. Can we win the season championship? It pays ten grand. That would help repaint the car. View attachment 6782366 View attachment 6782366 View attachment 6782366 View attachment 6782367
    Runnin shine, TFoch, enloe and 10 others like this.
  29. 19Eddy30
    19Eddy30
    from VA
    Thats Unique the way rotor broke.
    Blower cheaper then under the blower.
    Unless the New tricked latest Technology are $$$ average 10 k seen some 18
    I switched to all billet big bore ,
    A few of my hand me down's date back to 1 early 70's fuel use & bigger one off Bunny's F/c 90
    RMcCulley likes this.
  30. I did upgrade to billet standard helix rotors. The case and end plates were undamaged.
    The blower should arrive tomorrow.
    The biggest issue with cast rotors is inconsistency with the casting. When the grooves are cut for the strips the thickness is reduced. Now if the grooves are in a thin area that's where the problems start. The most stressed area is the middle of the rotor. I sin the engine to 8000 rpm. Multiply that times 35 percent. That's a lot to ask out of a cast rotor. We keep fixing the weak link. This wasn't a cheap date
    TFoch, enloe, Deutscher and 9 others like this.
