Projects 37 Tudor family hauler/push car
Discussion in 'Traditional Customs' started by youngrodder1929, Jul 1, 2024.
  1. youngrodder1929
    youngrodder1929
    PXL_20251228_235409271.RAW-01.MP.COVER.jpg Its been to long since I've had time to work on the sedan. I got heads back from the polisher. I spent a few hours sorting bolts to get enough nice timing cover, water pump and intake bolts for plating. After much thought the engine is going to to be a 293ci (4.250 stroke ) should move this car along better than the 3.750 I was planning on. Also mocked up a fuel line just need to pick up a 1/4" sweat copper tee from the refrigeration supplier to finish it up
  2. youngrodder1929
    youngrodder1929
    The elusive 1/4 copper tee PXL_20251230_185335051.RAW-01.MP.COVER.jpg
    rod1, bobss396, Paul B and 7 others like this.
  3. Outback
    Outback
    from NE Vic, Oz
    I really enjoy working in copper, looking good :cool:
    Okie Pete and youngrodder1929 like this.
  4. 52lomofo
    52lomofo
    is that a chevy licence plate guard?
  5. nochop
    nochop
    from norcal
    F-ing sinister
  6. youngrodder1929
    youngrodder1929
    Yup !
  7. youngrodder1929
    youngrodder1929
    Thanks!
    nochop likes this.
  8. youngrodder1929
    youngrodder1929
    I had bolts for these heads from when these heads were on the dragster I couldn't get black in a hurry so I used a sharpie anyway spot faced with the lathe and into the plating pile. PXL_20260103_032932714.RAW-01.MP.COVER.jpg PXL_20260103_042729491.RAW-01.MP.COVER.jpg
  9. nochop
    nochop
    from norcal
    It’s all in the details
    Outback and youngrodder1929 like this.
  10. youngrodder1929
    youngrodder1929
    Been distracted with other projects and life finally have it back where I can work on it again. 1st up is to get the body back off the frame. Then the exhaust next. It needed to go under the rear axle for space constraints and easy to remove for maintenance ect. I haven't made up my mind on the headers or mufflers I can deal with that down the road after I get some miles on it and see how it sounds with the new engine. I also pulled the original brake cable pivot to modify for park brakes, Yuck what a scungy pos right to the hottank lol PXL_20260526_235927196.RAW-01.MP.jpg PXL_20260526_235949961.RAW-01.MP.jpg PXL_20260527_032620053.RAW-01.MP.jpg
    rod1, Okie Pete, guthriesmith and 5 others like this.
  11. Outback
    Outback
    from NE Vic, Oz
    Nice work. Far easier to work on without a body!
  12. 39custom
    39custom
    Where did you get the new gl*** from. I'm in Ontario but need the same.
    rod1 and Outback like this.
  13. BJR
    BJR
    Have you thought about taking the hump out of the trunk, to make the profile flow better?
  14. youngrodder1929
    youngrodder1929
    Toms auto gl*** in Chilliwack bc. cut from my temples was super cheep and quick
    39custom and Outback like this.
  15. youngrodder1929
    youngrodder1929
    Screenshot_20240725-215213.png Screenshot_20231017-214758.png Maybe I'm just trying to get out of hard work but I don't mind a the mind the hump
    rod1, Surfcityrocker, Outback and 3 others like this.
  16. anothercarguy
    anothercarguy
    Great to see the update on your project!
    youngrodder1929 and 1low52 like this.
  17. Gahrajmahal
    Gahrajmahal
    That’s a great looking chop and engine.
    youngrodder1929 likes this.
  18. str8 6 str8 edge
    str8 6 str8 edge
    from Tampa
  19. youngrodder1929
    youngrodder1929
    I appreciate that. I feel very strongly about the importance of the hamb and everything it's done for me as well as the community.
  20. youngrodder1929
    youngrodder1929
    A bit more progress. I decided to backtrack a bit and add a notch for the rear spring and add boxing plates for support while I wait on some missing hardware. I was originally going to put longer shackles and a couple leafs so the spring didn't hit the frame but I think this will better all around outcome. I think it will still need 41-42 shackles but that's life lol PXL_20260608_192618637.RAW-01.MP.jpg PXL_20260608_224007790.RAW-01.MP.jpg
  21. Outback
    Outback
    from NE Vic, Oz
    Looking good
  22. Voh
    Voh
    Out of curiosity, why did you place the tool in the lath chuck and the bolts in the tail stock? I don't imagine it matters, but it caught my eye.
    Love the project, and enjoy the updates.
    -VOH
  23. youngrodder1929
    youngrodder1929
    Thanks!
    The end mill shank is bigger then the drill chuck will fit if I remember correctly
    Davis
    Voh and Outback like this.
  24. Tim
    Tim
    from KCMO
    Good stuff. Enjoying this build.
  25. youngrodder1929
    youngrodder1929
    Welding and park brake guide tubes. Hard to explain but the cable s need to drop down and under to match the jog in the wishbone PXL_20260609_235053956.RAW-01.MP.jpg PXL_20260610_050659255.RAW-01.MP.jpg
    guthriesmith, Outback and Okie Pete like this.
  26. mrquickwhip
    mrquickwhip
    Excellent build and coverage great welding and all round thought process. Can you or maybe someone else on here Photoshop your car with the front grille tilted back a little like a Lincoln Zephyr
    I know doing it would be a lot of work shortening the hood and adding a wedge shape at the top of the grille reshaping the hood sides etc but man I think your car might just look great and I know you have the skills to ace it.
    Okie Pete likes this.
  27. youngrodder1929
    youngrodder1929
    The thought of changing all angles of the grill bars gives me anxiety I do love the look of a zephyr hahahaha
    rod1, Okie Pete and Outback like this.
  28. thegreek
    thegreek
    from San Diego
    Absolutely love this one.
    rod1 likes this.
  29. youngrodder1929
    youngrodder1929
    Got everything tightened down ready to bead the brakes. Got word that the engine is getting bored started to get somewhere... PXL_20260629_013409796.RAW-01.MP.jpg Screenshot_20260627-090050.png
    guthriesmith, brad2v and Okie Pete like this.
  30. youngrodder1929
    youngrodder1929
