Projects SweeTy
Discussion in 'Traditional Hot Rods' started by Hopeless_hotrodder, Oct 17, 2023.
  1. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    She got torn down, epoxied, and tossed back together and now she’s off to hibernate for the winter. BA0F3379-5624-456E-BC25-6D409DEC4CB0.jpeg IMG_1702.jpeg F3517323-98E2-4C2D-AF30-2C8002A5806A.jpeg
  2. RodStRace
    RodStRace
    Great job! Only those who have done a full strip and prime will know the amount of work between those pics.
  3. Good stuff,looks great,congrats!!
  4. willymakeit
    willymakeit
    What pedals are you using?
    I just started on at coupe
    chryslerfan55 and Sharpone like this.
  5. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
  6. willymakeit
    willymakeit
  7. oil burner
    oil burner
    Just saw this today, love your build! Excellent job
  8. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    I’ve been busting but on customer cars and this weekend decided to tinker on my own stuff for a bit so I drug the Y block out of the corner and stated to put together a list of everything I need to make it run. I also saw something I wanted to try on my manifolds with graphite but I also decided to take it one step further and smooth them while I was at it.
  9. Tim
    Tim
    from KCMO
  10. MMM1693
    MMM1693
    Great workmanship and execution!
  11. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    A got some time on the engine lately and got the other manifold finished along with hours of sanding and polishing bringing these valve covers back to life. I also got a package from Nystrom Performance with my fuel fittings to get the carbs linked together.
  12. willymakeit
    willymakeit
    I see where you have a 8'' chop
    How tall are you? Im 6'4'' so Im thinking 5'' on mine without a seat lowering. TIA
  13. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Im 5'11" and I have a caravan seat. The seat frame sits about 4" off the floor. I have plenty of room to be comfortable. I'm not sure what the distance is from the floor to the top of the seat and I will say I'm slouched back a good bit the way I have it set up.
  14. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Sweety is still in hibernation for the winter but I have been building up my stock pile of parts and getting some other projects finished for her. First up I got a set of 9” headlights rebuilt and retrofitted so it has h4 bulbs and 1157 marker/turn signals. I also got my clutch and throw out bearing installed so the trans is now married to my engine and I’m super stoked about this today my walker radiator showed up that I scored out of the cl***ifieds on here. Can’t wait for her to come home so I can get to work!
  15. AHotRod
    AHotRod
    Good for you, I'm looking forward to seeing it all come together soon
  16. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    SweeTy is officially back in the shop and getting worked on again. So far I’ve just been getting parts I’ve been collecting set in place. I need to actually sit back and stare at her for a minute and get a game plan together and priority list. Right now theirs just so much to do that I’m having troubles processing it so at the moment I have have the mind set of “do SOMETHING” anything done is progress made
  17. AHotRod
    AHotRod
    Make a list, prioritize and categorize, hang it up on a clip board, read step 1, and start.
    This is how I stayed on target and always progressing, especially because I traveled the USA for work all the time then.
    Deutscher, chryslerfan55 and Outback like this.
  18. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    My brain is starting to comprehend what needs to be done in what order so I feel like I’m making good progress in the right direction and I got a job done I’ve been putting off for to long which is finally getting the body actually mounted to the ch***is. Now I started to lay out how I wanted to make the rear look.
  19. junkman8888
    junkman8888
    The green car is a 1919-25 Model T, which is metal panels over a wood frame.
  20. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Not a lot to update on this week but I did manage to get my rear bumper finished and mounted.
  21. Tim
    Tim
    from KCMO
    Looks great! Can we de how the bumper and the plate itself mount?
    Sharpone and chryslerfan55 like this.
  22. willymakeit
    willymakeit
    What diameter tubing did you use? TIA
  23. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    1.75 for the bumper 1.5 for the mounts
  24. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    This 3 day job was the longest 3 weeks ever.
  25. Tim
    Tim
    from KCMO
    Well worth the effort! Looks spot on
  26. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Sweetys body is off to the wood shop. A close friend of mine is making the roof structure for me. It’s weird to see her sitting in the middle of a wood shop. Now this week I’m going to get to work on finalizing the ch***is. IMG_3404.jpeg IMG_3405.jpeg
    Deutscher, Sharpone, Outback and 5 others like this.
  27. Tim
    Tim
    from KCMO
  28. Outback
    Outback
    from NE Vic, Oz
    Looking good, how's progress?
    Sharpone likes this.
  29. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Not a ton to update on I’ve just been working on my frame getting things final welded and dolling it up a bit. I’ve also been working on getting some of the front end components ready to prime. No update on my roof yet but don’t feel the need to pester him because I’m not ready for the body to come back anyways. Just chugging along IMG_3425.jpeg IMG_3435.jpeg
    Outback and Sharpone like this.
  30. Outback
    Outback
    from NE Vic, Oz
