Technical FROG MOUTHS, OPINION NEEDED
Discussion in 'The Hokey Ass Message Board' started by Bandit Billy, May 22, 2026.
  1. Bandit Billy
    Bandit Billy
    That last pic didn't appear full size, here it is. It shows the carbs match the motor (obviously) but the hood is running downhill a bit.
    Stogy, chryslerfan55, 69fury and 3 others like this.
  2. Bandit Billy
    Bandit Billy
    So here is how it played out. I decided to leave the elevation alone for the moment. I could add carb spacers but then I would complicate the linkage and have to change the hard fuel line form the distribution block. I opted to give this a try. I re-drilled/tapped/threaded the scoops and moved the thumb crews to the left (so there are two sets of threads now). Plenty of room on this side for the thumb screws and the scoops had an additional boss on this side so there was plenty of material to drill and tap.
    The side view is good. Yes, the carbs "dig into" the hood line, but the rearmost scoop is still well over the hood line and shouldn't interfere. The engine will rock side to side a bit, but I have 1/2" clearance at the bottom of that last scoop. I think it should be fine. We will find out soon enough.
    I like them pointed backward. I can also change them in minutes if I so please. I really love the plating and powder coating. It hasn't been out of the garage since September. I plan to change that this weekend.
    The Olds gets jealous quite quickly so I need to get it out of the garage as well. She is trying her best in these pics to show some grace but I know her all too well. She needs some "rocket time".
    bchctybob, Stogy, oldsjoe and 9 others like this.
  3. 29Sleeper
    29Sleeper
    from SoCal
    If it doesn't work go straight up
    Stogy, Just Gary, LCGarage and 6 others like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Looks good anyway you run them , my personal opinion right or wrong I prefer facing forward, just looks racy! HRP
    Stogy, chryslerfan55, nochop and 2 others like this.
  5. Let us know what kind of major performance change turning them around makes, be it for the better or worse.
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    Wow. Only $85. Already chromed for Billy too. And adorned with authentic-looking frog eyes
    Stogy, GuyW, Just Gary and 5 others like this.
  7. Bandit Billy
    Bandit Billy
    Those are cool stacks.
    I think so too. They are growing on my being flipped around back***ward. There will be less glare form that chrome for sure backward.
    I hope to drive it this weekend a bit. I haven't had it out of the garage since I cam back form Rod Run last September. Avoiding driving a stick with this dizzy **** going on but I think a little drive is in order.
    That scoop reminds me of a frog my father always had on his dresser that he put his change and pocket treasures in every night. I own it now and look at it every morning getting preened and pretty. His old Timex resides in it's mouth.
      624.4 KB
    bchctybob, Stogy, dwollam and 8 others like this.
  8. Blue Moon Garage
    Blue Moon Garage
    Stogy, chryslerfan55 and Sharpone like this.
  9. 49ratfink
    49ratfink
    I tried "Frog Sphincter" air cleaners once... they would not let any air through at all.:confused:
    Stogy, Toms Dogs, Just Gary and 2 others like this.
  10. Bandit Billy
    Bandit Billy
    Too tight!
    Got the roadster out of the garage for a short hop about town yesterday. Staring down the throats of these.
    bchctybob, Stogy, dwollam and 11 others like this.
  11. J. A. Miller
    J. A. Miller
    from Central NY
    Needs more tongue.
    Stogy, Just Gary, CSPIDY and 7 others like this.
  12. RICH B
    RICH B
    Scoops looking good facing the rear with the tops remaining square with motor (most important detail).;)
  13. SDS
    SDS
    facing back is best IMHO. I vote for lower vs higher - tighten them up to the hood, keep them from becoming the focal point.
    Anything you can do to lower them and/or modify to get clearance for the hood to open?
  14. Bandit Billy
    Bandit Billy
    Not with the frog mouth scoops, the hood would require a much larger hole and look a bit odd in my opinion. And I had some extraordinary pinstriping done on the hood by a master that has since retired. I can run the OER small stacks, and the hood opens and closes. I just like the look of the frogs.
    I need to stop opening the hood at shows anyway. It makes it hard to appreciate all of the work it took to make that car fit together this tight when the hood is gaping open. Some may miss the blower but that is that. I really don't like the car sans hood. I ran it that way a couple of times and it doesn't look complete. Fine on some cars but I prefer hoods.
    bchctybob, Stogy, dwollam and 4 others like this.
  15. Bandit Billy
    Bandit Billy
    I agree. I came close to changing the elevation of the carbs so the hood lines matched the scoops but then it doesnt match the engine and without hood sides, it doesn't work for me. If I was running hood sides, yeah no one would know.
  16. 05snopro440
    05snopro440
    The look from the driver's seat with them turned around and on the same elevation is perfect to me.
  17. rob-redm
    rob-redm
    not a huge fan of those... but if you like them...
    Stogy, chryslerfan55 and Bandit Billy like this.
  18. 40FORDPU
    40FORDPU
    Good choice @Bandit Billy...I bet it's nice to be driving it again.
  19. Bandit Billy
    Bandit Billy
    It's not as much fun as it should be :cool:. The things we take for granted.
  20. Bandit Billy
    Bandit Billy
    Well...that's why they aren't on there :cool:
    Stogy, Toms Dogs and chryslerfan55 like this.
  21. BigJoeArt
    BigJoeArt
    I like this idea the best, cutting the fronts down to match the rear, so they are tucked tight to the hoodline.
    I like frog mouths more the less they break the lines.
    On that note, if you could mill the scoops down, so the base was at an angle, could you rotate the scoops forward and get the rear one to clear the hoodwork?
    Bandit Billy and chryslerfan55 like this.
  22. Bandit Billy
    Bandit Billy
    I thought about that (you know what they say about "great minds"). They have plenty of material to work with being aluminum. Problem being is I chromed and powder coated them a bit too early. If I did this, I would wait until winter, buy three others and start over. These are easy to sell, and I only paid $100 for the chrome and powder coating. Big issue is down time and summer is here.
  23. ne'erdowell
    ne'erdowell
    For aesthetics, I think that where you are now works. Possibly cut down and re-tap the front and middle to follow the hood line. Somewhere back there I read that forward facing scoops can experience some air turbulence and cause fuel to get splattered out the carb top. I can’t speak to this from personal experience, but you would be pretty upset if your nice paint got all sprinkled.
    Stogy and Bandit Billy like this.
  24. Bandit Billy
    Bandit Billy
    That would not please me. I have been at freeway speeds many times with them forward facing and never noticed that but then again, I run them progressive, so the center carb is the only one running most of the time. It is always protected by the first scoop. I have heard that though.
    Stogy and Toms Dogs like this.
  25. Toms Dogs
    Toms Dogs
    from NJ
  26. chicken
    chicken
    from Kansas
    Although I think the front facing scoops looked good, what you've done now also looks very nice. The view down the scoops from the ****pit is cool. As for turbulence from forward facing, with the screens you're running I doubt it's an issue.
  27. Bandit Billy
    Bandit Billy
    Southbound and down!
    I figure the blower makes any difference between forward and rearward facing scoops a moot point. I do like the look of the scoops while driving it. Thanks for the compliment.
    bchctybob, Stogy and Toms Dogs like this.
  28. 34 5W Paul
    34 5W Paul
    from Fresno CA
    I read the whole schmear and think your instincts are great; dig the rearward facing as well. I love the look from the ****pit and whether they stay in line with the engine or the hood, both have solid rationales. Tinkerers are going to tinker, so I expect you will at some point have fabbed up some slim spacers to let them stay as low as possible while following the hood line. She's a work of art, this detail isn't a make or break deal. Spectacular roadster.
  29. Bandit Billy
    Bandit Billy
    Much appreciated!
    Stogy and 34 5W Paul like this.
  30. Forward ****s too much fuel out of the idle circuit, so facing backwards is the ticket.
    CSPIDY and Stogy like this.
