Projects Roscoe: 1939 Ford Panel Muttmobile
Discussion in 'The Hokey Ass Message Board' started by 120mm, May 30, 2026.
  1. 120mm
    120mm
    from Tennessee
    Now that my lovely bride and I have retired, we've been rescuing dogs full time for Mikaela's Mutt Motel in Clarksville Tennessee for a few years.
    I have been using a 1969 Toyota FJ40 Landcruiser to do rescue and transport, but it is a bit rough on the dogs.
    I stumbled upon a 1990s era hot rodded 1939 Ford panel truck 10 miles from my house, and made it mine. It had a bad transmission, but is a 350 SBC/TH 350 combo with 12 bolt rear and Mustang II front end. Already has AC, power steering, disc brakes all around. Really straightforward stuff.
    We are currently replacing the transmission and undoing PO chicanery with the goal of making it a driveable dog transporter.
  2. Grumpy ole A
    Grumpy ole A
    That will be a nice transport.
  3. shorrock
    shorrock
    from Germany
    Kudos to you for doing this rescue work. My wife and me sponsored a local dog shelter, helping whereever possible and taking home the big old dogs, the great Danes. Those and the Pitbulls usually never get another chance. Our dogs had to travel in my old MB Sprinter but if such a nice panel truck became available here in Germany, I would add it to my fleet. Keep up the good work!
  4. 120mm
    120mm
    from Tennessee
    Thanks for the kind words.
    I've spent the last month derodding it to a certain extent.
    The builder used stovebolts to hold on the side panels and then glued them in with bondo. The wiring is garbage, and they glued in the original non safety gl*** windshield with sealant.
    Also, the welded in these hideous benches in the back which serve no purpose than to destroy cargo room.
    I'm afraid I'm going to have to destroy the windshield frame to make it right
    Also, none of the raw steel they welded in had any kind of paint or preservative.
    Okie Pete, SPEC, flatheadpete and 3 others like this.
  5. proartguy
    proartguy
    from Sparks, NV
    My experience with dogs and deliveries is they want to sit up front to look out the window.
    SS327, bchctybob, 120mm and 1 other person like this.
  6. 120mm
    120mm
    from Tennessee
    Yup.
    Civilized dogs always get to sit up front.
    Lots of dogs aren't though and they get to be in back in a kennel.
    Started tearing out the space wasting benches in back today
    I really wish they weren't welded in.
    catdad49, SS327 and bchctybob like this.
  7. panhead_pete
    panhead_pete
    Kudos!!!!!!
    120mm likes this.
  8. 120mm
    120mm
    from Tennessee
    Believe me, it's a self rewarding task.
    I work for hugs and puppy kisses
    SS327 likes this.
  9. In case it matters, the outside looks pretty good. You will conquer the rest. Why is it rodders generally choose metal instead of wood. That would have been so much easier to fix.
    120mm likes this.
  10. Michael Ottavi
    Michael Ottavi
    Very cool, good on you and your wife! I'm sure your p***engers tails will be wagging while enjoying the ride.
    120mm likes this.
  11. 120mm
    120mm
    from Tennessee
    Yep. And wood is quieter.
    You might also notice they tubbed the wheel wells, which is retarded because the frame doesn't allow bigger wheels and tires than are on there
    bchctybob likes this.
  12. 120mm
    120mm
    from Tennessee
    Got the first bench removed.
    Was not the most enjoyable job I've done.
  13. 120mm
    120mm
    from Tennessee
    Finished pulling the p***enger side bench. Decided to leave the battery box in.
    Noticed you can see daylight right down to where the tailpipes exit. That's no bueno, for CO.
    Okie Pete, Stooge and SPEC like this.
  14. patsurf
    patsurf
    or H2 o for that matter!
    120mm likes this.
  15. Grumpy ole A
    Grumpy ole A
    You may need to get the tail pipes extended a little bit to clear the back of the truck.
    120mm likes this.
  16. 120mm
    120mm
    from Tennessee
    Started pulling some interior tin off.
    The failure of the PO to seal the car from exhaust gases and other intrusion is the worst thing I've found so far. PXL_20260609_194230758.jpg PXL_20260609_194405145.jpg
    But dread naught, I have the tools and knowledge to fix this. PXL_20260609_194414260.MP.jpg
  17. 120mm
    120mm
    from Tennessee
    It has basically an open exhaust right now, so I need to get the local shop to weld in some actual mufflers anyway. While they are doing that I'll have them put some tips on it
    Okie Pete likes this.
  18. flatheadpete
    flatheadpete
    from Burton, MI
    Very cool. As this is for a good cause...are you accepting donations for parts? I'm sure I have something it needs in my stash.
    panhead_pete, 120mm and shorrock like this.
  19. 120mm
    120mm
    from Tennessee
    Well, sure!
    A windshield frame would be my top ask.
    Let me think about what I could use.
  20. 120mm
    120mm
    from Tennessee
    I did some soul searching and decided this is going to be a "good enough" fix it job for now. So I am making simple floor panel extensions to close off the rear quarters and panel bond them just for the time being.
    Okie Pete, 49ratfink and panhead_pete like this.
  21. 120mm
    120mm
    from Tennessee
    Starting the fabrication process.
    Okie Pete and fordor like this.
  22. ol'skool
    ol'skool
    from Colorado
    Kudos to your efforts! Just had a thought, in order to refresh the interior air and remedy the possibility of stray CO and interior odors, you might look into RV Fantastic fans. They are designed for ceiling vents, which may not be cosmetically pleasing but perhaps a reverse scoop arrangement since you have the metal working gear at your disposal.
    120mm likes this.
  23. hotrodjack33
    hotrodjack33
    TIP.
    Your new exhaust? Have your exhaust exit the side of the Delivery behind the rear wheels.
    What I have learn building several Deliveries is that the flat shape rear of the body causes a vacuum/vortex that keeps, and circulates exhaust fumes behind the vehicle that will ALWAYS seep in the rear doors...no matter how well sealed.
    Exiting out the side will eliminate that build-up of exhaust fumes behind the Delivery.
    All 3 of these required modifying the exhaust to "side exit"...which really helped.
    Okie Pete, RAK and 120mm like this.
  24. HOTRODPRIMER
    HOTRODPRIMER
    Thats a cool ride, I'm sure you and the dogs will enjoy the ride in a hot rod, and look cool doing it! HRP
    120mm likes this.
  25. 120mm
    120mm
    from Tennessee
    You know, that might be a good idea. I'll definitely look into it
    Great suggestion. I had a 1970 Chrysler station wagon and a 1996 Toyota Land Cruiser that accomplished that with a reverse spoiler/wing to accomplish the same thing. Am going to dump exhaust out the side now.
    Edited to add, my 1969 Toyota FJ40 Landcruiser does that exact thing.
    34 5W Paul and hotrodjack33 like this.
  26. 120mm
    120mm
    from Tennessee
    It's been a minute since I've metalshaped, but thought this panel turned out ok.
    Okie Pete and SS327 like this.
  27. 120mm
    120mm
    from Tennessee
    Pulled off the driver's side panel. I can save it easy, but need to seal it off.
    At this point I'm not going to even attempt to get it back to stock. Just get it driveable and have fun with it
  28. 120mm
    120mm
    from Tennessee
    Didn't do***ent the process, but found a quick and dirty way to fit a patch. PXL_20260617_194955296.jpg
    Okie Pete and Stooge like this.
  29. 120mm
    120mm
    from Tennessee
    Since this is going to be a running restoration, I chose 1/4 rubber mats to make up for the lack of proper flooring
    Found this at the local Home Depot.
    Huh
  30. 29Sleeper
    29Sleeper
    from SoCal
    Henry used laminated safety gl*** in all his windshields since 1927 He had an engineer severely cut up when he crashed testing a prototype Model A. The Rouge had it's own gl*** plant and they developed what they called Triplex - 2 thin sheets of gl*** with cellulose plastic in between.
    120mm and Okie Pete like this.
