History Vintage anti-theft steering wheel.
Discussion in 'The Hokey Ass Message Board' started by wvenfield, Jun 2, 2026.
  1. wvenfield
    wvenfield
    My buddy came across this . I thought it pretty cool. It free spins until you put the key in it.
    Made in Elyria Ohio. I couldn't find much on the manufacturer.
    I'm not expert but I've never seen one before and it's in great shape for likely being a century old.
    PXL_20260602_151720495.jpg PXL_20260602_151724525.jpg PXL_20260602_151744873.jpg PXL_20260602_151730893.jpg PXL_20260602_151735389.jpg
  2. 19Eddy30
    19Eddy30
    from VA
  3. lothiandon1940
    lothiandon1940
    Never seen one. Very cool.
    Sharpone likes this.
  4. BJR
    BJR
    So when locked it just spins without turning the wheels? Unlock and you can drive the car? Is that how it works?
  5. 19Eddy30
    19Eddy30
    from VA
    The Key when turned slides the pin into to lock the steering wheel , in pic looks in free wheel position
  6. Jack E/NJ
    Jack E/NJ
    from NJ
    What happens if the pin shears while making a hard turn at high speed?
    Sharpone and Squablow like this.
  7. oldolds
    oldolds
    The ride of your life! The car it was meant for probably had a 45 m.p.h. top speed, but also had mechanical brakes. It might have only had rear brakes as well.
  8. 19Eddy30
    19Eddy30
    from VA
    That pin looks close to 3/4
  9. wvenfield
    wvenfield
    Good eye and yes it is currently in free spin position. Might see about getting a key made to see if it works. Not complicated so it should.
  10. TCTND
    TCTND
    What happens when the steering lock pin in your new car falls into the slot while making a high speed turn?
    Driver50x likes this.
  11. Jack E/NJ
    Jack E/NJ
    from NJ
    Circles? I always wondered if that could happen in my '38 Ford. :eek:
  12. blue 49
    blue 49
    from Iowa
    I wonder if this is the same Superior that made my 4 hole per spoke, metalflake wheel.
    Gary
    Sharpone and SS327 like this.
  13. RodStRace
    RodStRace
  14. 1971BB427
    1971BB427
    from Oregon
    What happens if the keyway strips out on any old steering wheel that uses a keyway?
  15. Squablow
    Squablow
    The taper holds the wheel in place, the key is really just a guide. As long as it's properly seated/torqued, you could drive around a car with a tapered shaft column/wheel with no key in it at all. Same with a rear axle. I wouldn't want to, but theoretically, it'll work.
    This is a neat wheel, but I don't know how much I'd trust its design in actual use. I'd certainly be way less worried about any car getting stolen that could run that wheel.
    210superair likes this.
  16. Mr48chev
    I wouldn't be worried about that bar that locks it shearing off. Plus in either direction you turn the key and remove it as it hangs on your regular key chain.
    That is a pretty novel Idea for cars in a time when you could all too easily hot wire them or a worn key would start a lot of them.
    SS327 and MAD MIKE like this.
  17. MAD MIKE
    MAD MIKE
    Considering the age, style, and probability of failure, a 'high speed' turn would be ~25MPH.
    If the pin failed during such an event, you already have other problems going on, no steering control is going to be low on the priority list.
    lothiandon1940 and SS327 like this.
  18. Bandit Billy
    Bandit Billy
    Evidently car thieves have existed since the first one was built.
    Jeb: Hey, what's that there you reckon?
    Joe: That's one of them newfangled horseless carriages
    Jeb: I think I'll steal that later, p*** the shine.
    lothiandon1940 and Ned Ludd like this.
  19. DDDenny
    Yeah, it sure would be handy if todays' car thieves were dealt with like they did with horse thieves!
  20. DDDenny
    Gotta say "we've come a long way"!
    Another early innovation.
    Okie Pete, SPEC and Bandit Billy like this.
  21. alchemy
    alchemy
    A fat man wheel.
    SS327 likes this.
  22. deathrowdave
    deathrowdave
    from NKy
    Car smells bad for a least a couple of days. I think the shaft is tapered and that is what keeps you safe the key is for alignment , but I’m not 100% sure . Don’t need to find out . Mainshaft on a Harley is keyed the same way , shear the key and it will still kick start but not move under its own power . Has to be loose to shear the key . Early Ford axles are the same , tapered with a key , key is only for alignment but we all know where you shear the key off at while driving .
    SS327 likes this.
  23. Ned Ludd
    Ned Ludd
    Cool — especially as something described as Vintage actually appears to date from the Vintage era.
    Obliquely related, something I read about once and haven't been able to find since: one of the American quality marques (iirc) of about that time offered two concentric steering wheels, the outer geared relatively quick for general driving, and the inner geared far slower, for low-speed manoeuvring. Does that ring any bells for anyone? It might have been elsewhere in the world, or I could have hallucinated the whole thing.
  24. Driver50x
    Driver50x
    I saw that recently, in Lanes museum in Nashville. It was a European car, if I remember correctly.
  25. 41 GMC K-18
    41 GMC K-18
    As indicated,
    “ Foolproof is no obstacle to a talented fool “
  26. 210superair
    210superair
    from Michigan
    Yes, criminals don't give up. They adapt.
