Technical 57 Pontiac coil springs
Discussion in 'Traditional Hot Rods' started by Jon Potvin, Jun 7, 2026.
  1. Jon Potvin
    Jon Potvin
    I purchased a beautiful 57 Pontiac hardtop. The previous owner installed new front springs. They are way tooooo stiff. The car follows every wave in the pavement. Current suppliers all sell the same large wire diameter coil springs. No information is provided on spring rate.
    There are front coils on eBay but they are listed as 57-60 which is erroneous. Can anyone tell me the wire diameter of the original spring. Does anyone have an original set for sale.
    Tow Truck Tom likes this.
  2. petersyl
    petersyl
    67drake likes this.
  3. Scott Younker
    Scott Younker
    Look up (coil spring specialties) in Kansas, they can give you exact stock specs and make whatever you want.
    Outback, 69fury and Tow Truck Tom like this.
  4. Bird man
    Bird man
    from Milwaukee
    Outback likes this.
  5. Jon Potvin
    Jon Potvin
    Thanks for all the info. The 0.657” wire diameter is approximately what I’m measuring on mine so it’s something else. The old BFG radials could also be part of the problem as well as the shocks.
    I ***ume your springs are 1957 originals not replacements?
  6. stuart in mn
    stuart in mn
    Espo.com is another spring source.
    Edit: I haven't bought springs from them but CPR (California Pontiac Restoration) has always been a reliable parts source for me. Last time I looked they also have an inventory of NOS parts - you never know, maybe they have some original springs on hand.
    Outback and 67drake like this.
  7. bobss396
    bobss396
    Look up the Moog coil spring PDF file online. It lists them by coil size, rate and free length.
    Once you know what you need, go shopping!
    Outback likes this.
  8. petersyl
    petersyl
    I am pretty sure those front springs on mine are original. I am second owner, PO did not do much to the car.
    I am replacing the rear leaf springs but thats another story.
    If your springs have been cut to lower the front they are going to ride somewhat stiffer.
    Just Gary likes this.
  9. rockable
    rockable
    You may just need to get more caster in the front end. See my thread on the 56 wagon.
  10. Jon Potvin
    Jon Potvin
    Car has dropped spindles so coil cutting would not seem to be necessary but who knows.
    This Pontiac is an older restoration maybe 20+ years ago.
    Definitely p***ing on the Cleavage thing
  11. Scott Younker
    Scott Younker
    Jon, where did you find drop spindles for your 57’s
    King pin set up, or did you switch to Chevy Tri five ball joint system?
  12. Jon Potvin
    Jon Potvin
    Dropped spindles were offered by Fatman Fabrication. Southern Rods and Parts acquired Fatman Fab ***ets This system has the kingpins like the original.
    Outback likes this.
  13. 19Eddy30
    19Eddy30
    from VA
    Would Hollander book help ?
    Its been since 70's to know remember whats shown .
  14. Moriarity
    Moriarity
    SUPER MODERATOR
    Hollander lists number 76 for a 57 Pontiac. Does not call out wire diameter IMG_8380.jpeg IMG_8381.jpeg
  15. Jon Potvin
    Jon Potvin
    How do I find your thread on the 56 wagon? I cranked the adjusters all the way until they bottomed pushing that upper mount as far to the rear as it would go and the lower mount to the front. All I was able to accomplish was zero degrees caster and a little negative camber.
    Outback likes this.
  16. rockable
    rockable
  17. petersyl
    petersyl
    The 57 Pontiac still had kingpins, which has limitations in setting caster angles (need to check for bind...).
    See below for front spring numbers from Pontiac Master Parts Catalog, which differ by style, transmission, etc.
    My car is a convertible (2867) with the Hydramatic, which probably has heavier springs due to the heavier/boxed frame.
    Aftermarket wheels could also potentially effect things, as originals had close to neutral (0.75" positive) offset.
    rockable and Bird man like this.
  18. Bird man
    Bird man
    from Milwaukee
    Yes, difficult to get any Caster with Kingpins. one advantage of Ball joints.
    Can the control arms be shimmed?
  19. Jon Potvin
    Jon Potvin
    Caster situation gets worse. Best I can get on the driver side is 1 1/4 degrees negative caster. The upright actually leans towards the rear at the top as would be expected in a suspension set for positive caster; however, my Longacre alignment tool reads negative caster on the 40 degree swing. A close visual inspection shows the kingpin is not parallel to the upright(front or side view) so poor workmanship on the dropped spindle could explain the discrepancy.
    I’ve done steering geometry modifications on ball joints cars even going so far as to move ball joints to achieve 6-7 degrees positive caster but this thing is going to require some as yet undetermined modification to achieve ZERO caster.
  20. petersyl
    petersyl
    I'm just thinking out loud here, but if you were to shim the front of the upper control arms and shim the rear of the lower control arms you might be able to increase caster while keeping the the pivot pin geometry parallel. The shim thickness would need to differ top/bottom due to the different mounting bolt spacing on the control arm shafts.
    EDIT: This might also add a bit of "anti-dive" geometry to the front end.
    Again, need to test without the springs/shocks to make sure there is no binding. Let us know what you find.
    Below is an example of what we are dealing with (55 Pontiac).
  21. Jon Potvin
    Jon Potvin
    You guys were correct about shimming the control arms.
    Decided to reverse the adjuster in the lower control arm in an attempt to get more forward movement of the spindle. Loosening the upper control arm bolts revealed that cranking the upper and lower adjusters to their maximum positions had put a lot of twist on the control arms. I put a 0.110” shim under the front of the UCA. Haven’t gotten to the LCA yet but when re installing the lower spindle bolt it was obvious that the bolt holes in the LCA weren’t parallel with the spindle bolt.
    Good news. A quick check showed + 1 degree caster and negative 1/2 degree camber.
    Started out looking for a softer ride and ended up improving the caster. Maybe get a little anti dive action here.
  22. Jon Potvin
    Jon Potvin
    Re your photo: I hope this is just a parts car.
  23. BJR
    BJR
    You do know that you adjust caster and camber with the upper trunnion right? By turning it, it threads the top of the spindle forward and backward, while moving the spindle in and out as you turn it.
    Wobbly and SS327 like this.
  24. petersyl
    petersyl
    In measuring the control arm mounting bolts, it looks like my UCA is 3.75" OC, LCA is 8.5" OC.
    (I think control arm bolt spacing may differ across years/models)
    Did a little trig and for each 1* in caster change you need 0.065" shim (about 1/16") up in upper front, 0.148" (just over 1/8") down in lower rear.
    Should make sure there is enough bolt length for full engagement...
  25. Moriarity
    Moriarity
    SUPER MODERATOR
    If you’re shimming bolts on a king pin car you need to remove the spring so you can make sure there’s no binding through the suspension travel. These are not like ball joint cars that allow that kind of movement. You will quickly wear pins and bushings out if you try to twist them
  26. BJR
    BJR
  27. Jon Potvin
    Jon Potvin
    After placing shims under the front of the upper control arm mounts and under the rear of the lower control arm mounts and cranking in the maximum spindle adjustments, the caster is +2 1/2 degrees. The camber is -3/4 degrees. The eccentric is in the least negative position so -3/4 is the best camber achievable.
    The upper and lower control arms were shimmed to match the angle of the spindle bolts and relieve the twist on the control arms. Before shimming the control arms, I measured +1 1/2/ degrees of caster. After adding the shims and relieving the stress on the control arms, I measured 2 1/2 degrees.
    Now back to the original problem of the stiff ride. Thanks for all the help.
