Projects 1955 Gasser Build
Discussion in 'The Hokey Ass Message Board' started by jsxtreme, Apr 11, 2025.
  1. Greg Rogers
    Greg Rogers
    Love that plate! Clever!!
  2. 427 sleeper
    427 sleeper
    It'd be alot cooler if you took the plastic insert out of the bezel... ;):cool:
    jsxtreme likes this.
  3. jsxtreme
    jsxtreme
    from Michigan
    Yeah, I know! I'm not sold on it so I left it as is.
    I found an original for $20 last night and it matches the rest of my trim, solid score.
    chryslerfan55 and 427 sleeper like this.
  4. jsxtreme
    jsxtreme
    from Michigan
    My oldest daughter spent all weekend with me in the garage. It was awesome. We got the quarter trim on together.
    I discovered I should have welded in the trunk latch bracket before I painted... oooppps. I will have to figure out a solution for that. Then I can align the trunk, put the weather stripping on and repair the paint that got damaged in transport.
  5. jsxtreme
    jsxtreme
    from Michigan
    So, I forgot to weld these parts in prior to paint... it gets welded to the floor and to the tail pan. My concern is screwing up the paint on the tail pan.
    https://www.realdealsteel.com/1955-57-chevy-trunk-floor-lower-striker-bracket/
    I know the wet rag trick, but does anyone else have a suggestion thats not welded? I feel like JB weld or something like that would not be a good long term solution. Though, not like I will be in and out of the trunk a lot.
  6. 427 sleeper
    427 sleeper
    Panel bonding adhesive just might do the trick.
  7. DDDenny
    chryslerfan55, jsxtreme and SS327 like this.
  8. jsxtreme
    jsxtreme
    from Michigan
    "Don't get it perfect, just get it running"
  9. Fitnessguy
    Fitnessguy
    Cool build brother
    jsxtreme and chryslerfan55 like this.
  10. Roothawg
    Roothawg
    I don't know how I missed this. The 55 Chevy has always been a favorite of mine. Great car. You're doing a great job. Keep us posted.
  11. SS327
    SS327
    I want to know how you got the engine and stand to hover in the air like that?
  12. If you look closely you’ll see that a lifting strap is p***ed through the tunnel ram and is being held up by a chain.
  13. SS327
    SS327
    Oh, trickery eigh? :confused::oops:
  14. Or maybe you just need gl***es. Hehe
    swade41 likes this.
  15. SS327
    SS327
    Well I do need new ones.
  16. jsxtreme
    jsxtreme
    from Michigan
    LOL Crane. I moved it to my buddies shop to build it. He's got a crane and a lift.
    I'm lucky that I have skilled friends who like building cool stuff that let me use their shops. :)
  17. jsxtreme
    jsxtreme
    from Michigan
    Well, here is what's done since I moved it:
    Engine
    Trans
    Gas tank and fuel system
    Front shocks
    Drivers side trim
    Fitting and adapting the steering column is next. Also getting the master cylinder in and routing the brake lines around the headers. Need to order some parts.
    Updated pic of how she sits with the engine and trans in. And an artsy fartsy one because while laying on my back putting the trim on I thought it looked cool.
    chryslerfan55, swade41, rod1 and 7 others like this.
  18. jsxtreme
    jsxtreme
    from Michigan
    Someone, at some point, painted the headers with plain old spray paint. Looked nice until we broke the motor in.
    So had them sandblasted, and I painted them with VHT high temp ceramic.
  19. Is there a collector muffler welded onto those headers?
    chryslerfan55 and lothiandon1940 like this.
  20. jsxtreme
    jsxtreme
    from Michigan
  21. They look like they belong. Ive seen some that look too obvious
  22. jsxtreme
    jsxtreme
    from Michigan
    They do a fair job taming the open headers from the hour or so I've heard it. I have video of what it sounds like, but its cell phone audio.
  23. 05snopro440
    05snopro440
    Not sure if you solved the trunk latch issue, but I'd get some automotive panel bond. If it can hold doors on modern cars, it can hold on your trunk latch.
    Love the white, the car looks great! Cool build.
  24. jsxtreme
    jsxtreme
    from Michigan
    Thanks. I'm going to weld it around the floor and then panel bond to the tail panel if needed.
    05snopro440 likes this.
  25. jsxtreme
    jsxtreme
    from Michigan
  26. jsxtreme
    jsxtreme
    from Michigan
    I think for this year/2027 I'm going to run the rallys I have out back with the hoosiers, and then get some torque thrusts for the front and cerekote them magnesium like Kleet did with his '55 to get me rolling. We'll upgrade down the road.
    427 sleeper, SS327 and greasemonkey54 like this.
