Projects My New New Ride
Discussion in 'The Hokey Ass Message Board' started by grdra1, Sep 24, 2022.
  1. grdra1
    grdra1
    I forgot to mention that I am also getting the short block ready, I plan to measure block (std bore) today to determine if I can use these DSS forged inverted dome pistons. If everything measures ok I will have rotating ***embly balanced, if not I will need to have the block bored and purchase new pistons to suit. Glen 20260222_155520.jpg
  2. RMcCulley
    RMcCulley
    Making some good headway, looking forward to seeing it running
  3. grdra1
    grdra1
    I spent the last 2 days finishing up my head lights, I needed to modify head light mounts about 1 inch lower to achieve the right look, happy with how they have turned out, a few pics Glen 20260321_142123.jpg 20260321_142758.jpg 20260321_142800.jpg 20260321_142809.jpg 20260321_142812.jpg 20260321_142815.jpg 20260321_142932.jpg 20260321_143040.jpg 20260321_143044.jpg 20260327_183844.jpg 20260327_183848.jpg 20260327_183853.jpg
    RodStRace likes this.
  4. grdra1
    grdra1
    Progress slow at present, working a lot with less garage time, I have purchased a radiator (currently being made), and over the last few weeks I have been working on templates for the windows. They are nearly finished and I should be able to drop them of at local auto gl*** shop later this week - another piece of the puzzle to add to the hundreds of other pieces that make up this hotrod. A few pics, Glen 20260413_163112.jpg 20260413_163117.jpg 20260413_163125.jpg
    Papas32 and 5w Jen like this.
  5. grdra1
    grdra1
    A few pics of recent progress, My radiator has arrived ( will be painted black soon ), purchased some Firestone slicks from a local rodder and started mounted wipers. Also gl*** is being cut as I'm posting this thread. Glen 20260430_161201.jpg 20260430_161212.jpg a3ae6a66-e94b-4955-8ffa-d2636d3df859.jpg 5ef9846e-3ff8-4732-939b-58cd9b26b610.jpg 20260421_133814.jpg 20260421_133826.jpg
  6. clem
    clem
    Nice progress !
    Going to be a beautiful car when done !
    Are the brackets with long connect
  7. grdra1
    grdra1
    Long connect ?, this is a pic of the type of wiper kit I used if that's what you mean, its a SPW kit. Glen wiper-motor-kit.jpg
  8. clem
    clem
    yes, that was what I was asking about.
    Don’t know what happened to the rest of my question, was supposed to read :
    “ are the brackets with the long connecting rods for sun visors or something else ? “
    Thanks - I was way off with sun visors ……..
  9. grdra1
    grdra1
    Gl*** all done now, happy with outcome, made exact to my templates, been working on electric window controller, brought a small unit that uses an original winder handle, took a bit of work but going to be ok, a few pics. Glen 20260508_144518.jpg 20260508_144521.jpg 20260506_103833.jpg 20260507_140228.jpg 20260507_140237.jpg ARCEWS-3-1.png
    duecesteve, VI Lonewolf and 5w Jen like this.
  10. grdra1
    grdra1
    Mounted tail lights and indicators today, still need to drill holes for wires etc, but happy with how they look, next job waiting is to sort out bonnet sides and top - figure out how Im going to mount / hinge whole ***embly, a few pics, Glen 20260512_152210.jpg 20260512_153928.jpg 20260512_153936.jpg 20260512_172130.jpg 20260512_172137.jpg 20260512_172144.jpg 49a51124-9a85-4025-92b1-ff30a128c090.jpg
  11. grdra1
    grdra1
    Trial mounted radiator recently to determine clearance for blower pulleys etc, because I modified front crossmember at the start of this build I needed to section crossmember for bottom hose clearance - see pics. I now have the grille where it needs to be in relation to bonnet and side panels. I will have to cut holes in bonnet for air cleaner clearance, I was going to buy a new bonnet as the holes required will cut into some louvers but have decided to cut the one I have and make a louvered bulge to weld in. - at least that what Im currently thinking. I am also trying to figure out how to hinge bonnet and mount side panels, a few pics. Glen 20260514_135026.jpg 20260514_135035.jpg 20260514_143249.jpg 5b72b616-359d-4cff-9bee-943cc8f53c0c.jpg b91d6fc3-4b75-413f-9c7f-06c49aa7818e.jpg 20260515_161518.jpg 20260515_161522.jpg 20260515_161533.jpg 20260515_161452.jpg
  12. grdra1
    grdra1
    I recently cut holes in the bonnet for the air cleaners and I'm liking how it looks. I have made a louvered bulge to cover the air cleaners but I'm not that happy with it ( if I did go with the bulge it would be around 1 1/2 inch lower than in pictures - and I would need to make another one), I have also purchased some black hi flow air cleaners to use, so that you do not notice them as much, as the car will be painted satin black as in the last picture - at least that's the color I'm leaning to lately. Glen 20260522_162649.jpg 20260522_162714.jpg 20260522_162719.jpg 20260522_162823.jpg 20260517_153420.jpg 20260520_171429.jpg 20260520_171434.jpg 20260520_171440.jpg F3D7A089-.png
    duecesteve, Deutscher, 5w Jen and 2 others like this.
  13. ne'erdowell
    ne'erdowell
    This car is so nice! If you are interested in opinions that don't count for much, the exposed black air cleaners are the choice over the bulge. Thanks for sharing the awesome build.
    duecesteve, Robdski and 05snopro440 like this.
  14. grdra1
    grdra1
    Thanks, I am interested in others' advice / opinions - I may not always agree but most (not all) people on this site are like minded. My initial plan for this build was to keep engine under the bonnet but that is not possible, so the louvered bulge was an option, but since cutting holes for air cleaners I like the look and with black filters and a satin black paint they won't be as noticeable. In order to determine if the bulge was feasible would requiring cutting the bonnet to suit the bulge. I feel that if I get the filters low enough and make a bulge about 1 1/2 inches lower it might work - but as previously mentioned I would have to cut bonnet which I do not think I will do at present, I may in the future if I can find another bonnet cheap enough - because I feel I can get the bulge to work. The bulge was going to come up from underneath and be solid riveted in. Anyway, thanks again for kind comments and feel free to share your opinions. Glen
  15. panhead_pete
    panhead_pete
    Is there a certain size these days for the turn signals? I run really small LED ones on my cars and bikes.
    For me that hood scoop is too busy. Maybe something like the original super duty scoops would be more pleasing to the eye. Will you get rego with anything above the hood top?
    duecesteve and Deutscher like this.
  16. grdra1
    grdra1
    Not really a certain size for indicators but they have to be visible, a certain distance apart and a certain distance from the ground up. Im happy with the shape of the indicators and have the same for the front as well - they are similar in shape to headlights and taillights. Rego really depends on visibility looking forward but about 3 inch's out of the bonnet is usually ok - my engineer is ok with about 3 inches' but mine will end up about 2 inches for the front one and just poking out for the rear one. My idea with the bulge was that it was not to be noticed as I did not want any indication of a tuff engine (more of a sleeper look) that's why I decided to follow the bonnet louvers and as mentioned if bulge was a little lower and painted the same you might have to look twice, any type of scoop was always out of the question. Any way having the air cleaners out the bonnet or maybe a small bulge is not a bad problem to have. Glen
    Deutscher and panhead_pete like this.
  17. grdra1
    grdra1
    Mounted handbrake recently, happy with how lever turned out. Glen 20260525_180004.jpg 20260525_180014.jpg 20260610_152913.jpg 20260610_152919.jpg 20260610_152923.jpg 20260610_152927.jpg 20260610_152937.jpg
  18. grdra1
    grdra1
    I spent the past week working out how I was going to mount front grille, sheet metal and bonnet etc. I have fabbed up the sub structure pictured which mounts the lower part of grille shell, locates transmission oil cooler and gives support for fiber gl*** inner fenders. I have purchased a set of Sachse Rod shop bonnet hinges and will hinge bonnet to firewall and lift from front of car. I plan to have bonnet sides lift of at this stage - the support structure for inner fenders will locate the bottom of the bonnet sides and I will fab another support bar to mount the top of the bonnet sides as well as the bonnet / Hood latches on either side towards the front of the car near the radiator ( if you understand what I mean - more pics to follow as work progresses ). Glen 20260617_123619.jpg 20260617_123623.jpg 20260617_125751.jpg 20260617_125759.jpg 20260617_125804.jpg 20260617_163745.jpg 20260617_180710.jpg 20260617_181737.jpg 20260617_181742.jpg 20260617_181748.jpg
  19. grdra1
    grdra1
    My bonnet / Hood hinges arrived today, the first step was to work out where to cut the body for the recessed mounting points I need to fabricate. The Structure I made for the steering column and under dash brake booster ***embly will need a little modification and will be perfectly suited for my new bonnet hinge mounts. I started modifying it this afternoon but ran out of time, I'm back to work tomorrow for the next few days so I will have to wait till next week to get back to work on this project, a few pics, Glen 295a08f8-0960-4522-995d-f88c29e328db.jpg b3490550-d017-4a51-8e5e-bc7c0f2986e5.jpg f16cb248-1ca6-4f69-bfee-4b026762e533.jpg 8ce07ebf-c99e-4be4-bb6d-88c7a1e845a4.jpg c5509a9d-7b76-41e3-aa33-1c8b3de1d459.jpg
  20. grdra1
    grdra1
    Hinges tacked in and bonnet mounted finally, what a **** load of work it took, and a **** load more to go. A few pics of progress, more pics to follow. Glen 20260704_144441.jpg 20260704_152632.jpg 20260704_152639.jpg
  21. Robdski
    Robdski
    Everything is looking good.
    Thanks for continuing to post your progress.
  22. grdra1
    grdra1
    Thankyou and its my pleasure to keep posting, here are a few pics of todays progress, I have posted a pic of finished under dash frame and the engine bay bars. These bars support the grille and I intend to hang / mount the bonnet sides onto as well as the bonnet latches as per pics - that's the plan anyway. Glen 20260706_155200.jpg 20260706_155211.jpg 20260706_160017.jpg 20260706_162749.jpg 7c100ede-3cb3-4d57-a54c-d8d342298cce.jpg 20260706_163640.jpg 20260706_163653.jpg 20260706_163938.jpg 20260706_163944.jpg 20260706_163952.jpg 20260706_163959.jpg
    Robdski and Mart like this.
  23. grdra1
    grdra1
    Mounted bonnet sides today, still a lot of work to do but happy with progress so far. Glen 20260711_164520.jpg 20260711_164643.jpg 20260711_172432.jpg 20260711_172510.jpg
    jaracer and Robdski like this.
  24. grdra1
    grdra1
    A few pics of recent progress, mounting bonnet, sides, grille etc. and getting all gappes ok is proving difficult due to gl*** body, repro bonnet, repro grille and gl*** inner guards. Im happy with how its all going so far, I will get more detailed during final ***embly.. I am so happy to see this hotrod as it will look when finished. I plan to paint car in a distressed look as per original front side panels. Glen 20260823_163054.jpg 20260823_163059.jpg 20260823_163108.jpg 20260823_163147.jpg 20260823_163153.jpg 20260823_163202.jpg 20260823_163227.jpg 20260823_163230.jpg 20260823_163305.jpg 20260823_170210.jpg 20260823_170217.jpg
  25. catdad49
    catdad49
    Already has "The Look"! Love the hood, too.
  26. MMM1693
    MMM1693
    Fit, finish and workmanship is second to none!
  27. T. Turtle
    T. Turtle
    X2. Everything is right on this build.
  28. grdra1
    grdra1
    Thanks for the kind comments guys. Most of the inspiration for this build and knowledge I have acquired has come from this website. I am so proud to be part of it. Glen
    duecesteve likes this.
  29. duecesteve
    duecesteve
    I had a scoop from an F-600 oil truck on my ‘98 f-150 I made it function with 3” tubing it was awesome! They mounted on the p***enger side of the big fords
    panhead_pete likes this.
  30. duecesteve
    duecesteve
    this is the scoop, I had it facing forward
