Rollable engine storage?
Discussion in 'Off Topic Hot Rods & Customs' started by CG, Jun 9, 2026.
  1. CG
    CG
    I have four engines Im not ready to get rid of yet and Im looking for a rollable cradle of sorts that I can set them on and easily move them around if needed. I dont want to make one I just want to ***emble something that has decent castors. Engines are a 283 ... 327 ... 350 and a Cadillac 425. Thanks for pointing me in the right direction!
    tractorguy and dogwalkin like this.
  2. evintho
    evintho
    tractorguy likes this.
  3. CG
    CG
    Thanks for these, any one currently using these types of stands? Curious how they hold up.
  4. FrozenMerc
    FrozenMerc
    The bigger the caster wheel, the easier it will roll. That cheap junk from Harbor Fright with tiny 2 inch wheels will get jambed on every little pebble or crack in your floor.
    I build my own. My local Wheeler Metals sells these large urethane casters for $15 ea. They are the same as what is used on Sam's Club's flat bed carts. Couple chunks of square or rectangular tubing, a few minutes in front of the chop saw and welder, and bam! 1 Engine cart. I think I have 5 or 6 of these running around the shop with everything from a 351W to a 1,800 lb IH DT466 sitting on them.
  5. squirrel
    I have a couple of the dollies that Summit sold a few years ago, with big blocks on them, they work.
    If you are cheap and want to make something yourself, a 2x8 cut into pieces, two to fit under the oil pan rails, and one at each end, then put casters under it, will work. you'll need to be patient to cut and fit the parts to the engine and each other. Kind of mimic the crate that crate engines come in.
    not this fancy, of course
  6. iwanaflattie
    iwanaflattie
    Ive used car wheel dollies in a pinch....steel casters and ive got 4 of them for 50.00 bux on fb marketplace...they save my **** when one of the engines was leaking,it contained the oil.
  7. Dick Stevens
    Dick Stevens
  8. TripowerPontiac likes this.
  9. kabinenroller
    kabinenroller
    Find an old steel grocery cart and remove the basket. I used these for years. They will handle the weight of a basic small block with no issues.
    big john d, bobss396 and scotty t like this.
  10. Bandit Billy
    Bandit Billy
    I am not a carpenter, but this was not difficult to make.
  11. MAD MIKE
    MAD MIKE
    Gotta love HD pics with left/right sides on right/left:confused:
    For bare blocks I use HF 12"x18" furniture dollies. Fits under work table fine. Don't think I could purchase casters alone for cheaper.
    Used a HD solid deck under a 235/Glide combo 'temporarily'. Held up for a few years until it didnt :p Pretty sure it inspired the 'Stanced/Hella Flush' trend.
  12. I have a lane behind my house where they kindly keep dumping a never-ending supply of engine trolleys in the form of steel shopping trolleys.(grocery carts).
    firstinsteele likes this.
  13. Scott Danforth
    Scott Danforth
    I buy used engine stands off of Facebook marketplace for $25-$40 and mount the engine on that
  14. Dave G in Gansevoort
    from Upstate NY
    Simple t-shape with a Chevy engine bolt pattern and some inexpensive casters, 2 swivel and 2 fixed. Like others have said, use bigger casters, iron. Roughly 6 to 7 feet of 2x2 tube, 2 pieces of 1/4 inch plate to make the engine block plates
    6sally6 likes this.
  15. Damon777
    Damon777
    I have a couple of the cheapies pictured above. One currently has a Buick 455 installed, and the other was home to a Pontiac 400 for a while. For the little I move them around, they work just fine.
    Don't overthink it. The lumber solutions above work as well. How often are you going to actually be moving them around?
    '51 Norm likes this.
  16. finn
    finn
    I have four of those short bolt, tubular on roller stands. One for a 350 Chevy and two for 302 Fords, plus a flathead on them. Mine are from swap meet vendors and were $20-25 at the time of purchase. They’re okay, but larger casters would be nice if you move them frequently. I pushed a fully dressed 350 across a 16’ wide concrete floor in my enclosed lean-to /storage area yesterday, and it took a lot of effort from this old guy.
    One flathead , one 460, and a Ford 2300 are on regular engine stands, but they’re sort of tippy and, being tall, take up a lot of space.
    Edit: After typing this, I remembered that I also have a spare 351M somewhere, but damn if I know where I put it.
  17. 210superair
    210superair
    from Michigan
    I've got one just cribbed onto an old shop roller cart. Hasn't let me down yet.
  18. CG
    CG
    Im going to start with getting one, the one scotty t and others have posted up. Looks like I can get the same one on Amazon for less. I believe Ill get the one with the steel wheels. Wont be moved much but I have a small shop so I need to be able to move them around once in awhile. If it seems solid enough Ill get a couple more. Right now the Cadillac engine is on a engine stand, talk about precarious when trying to move! I think Ill concentrate on getting rid of that one instead of keeping it for another ten years at which point I wont be able to move because Ill be too feeble haha.
    Thanks for everyone's insights, much appreciated.
    finn and scotty t like this.
  19. 6sally6
    6sally6
    Southern Speak !
    6sally6
    kabinenroller and scotty t like this.
  20. finn
    finn
    It’s amazing how much heavier a SBC seems when you’re almost 75 compared to when you were a scrawny 19 year old in 1970.
  21. 31Apickup
    31Apickup
    The stand pictured works pretty good if it has the cast iron wheels. I’ve had to use a drift punch to align the bolt holes. Let me know when you want to part with one of those SBC’s.
  22. twenty8
    twenty8
    With all the "study" I have been putting in to that year by year, I am convinced that gravity is increasing over time.:(
    scotty t, X-cpe, finn and 1 other person like this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    If you have a set of HF tire dolly's why not use them as engine haulers, just a few simple modifications and make them a lot more useful to move engines around. than cars.HRP
    210superair likes this.
  24. bobss396
    bobss396
    Weld an old bumper jack upright across the open end for stability. The old basket swinging doors made great barbecue grills too :cool::cool::cool:
  25. mr.chevrolet
    mr.chevrolet
    another vote for shopping cart, i've got 5 engines rollin around on them right now.
    bobss396 likes this.
  26. 210superair
    210superair
    from Michigan
    I've used these on so much stuff it's unreal. Boats especially. Used to lift my Chris Craft off the trailer and onto giant foam blocks with these underneath, roll it wherever I wanted.
  27. bigdog
    bigdog
    Ha! I have a 350 block that I carried up the steps to the attic of my shop about 35 years ago. Only way it's coming down now is if I just give it a push. Doing **** like that might also explain why my back hurts.
  28. Beanscoot
    Beanscoot
    I got a kick out of the example of how the "Chevrolet" engine is mounted to the stand, typical ebay Far Eastern idiocy:
    X-cpe, SS327 and chevy57dude like this.
  29. chevy57dude
    chevy57dude
    These worked for me, I drilled & tapped holes in them to store the bolts when not in use.
    SS327 likes this.
