Projects SweeTy
Discussion in 'Traditional Hot Rods' started by Hopeless_hotrodder, Oct 17, 2023.
  1. panhead_pete
    panhead_pete
    I know at times Im not all that smart, just wondering how that rear spring hanger works, ***uming its adjustible for height? Thanks Pete.
  2. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    Little more of an update still just chipping away on the frame. I started from the back and just continuing my way to the front. I’m almost don’t with metal work before I get to skim some poly filler on it. att.ZkuGbrFs8icgwn-7dERQ3wUuVCZNjVXcgzP7zZ2i3kg.jpeg att.-VMwwXYenhRAoMBs9waG0MjfXEE-DoEfhHbVbK5ezDc.jpeg att.MGNjtDBlve32Le3-d_NloiLKkZwNPqJqFmxnq-WsPMI.jpeg
  3. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    yes its a bracket that sandwiches the spring and then bolts to the plate you see welded on the crossmember. if you look at older posts you can see it better
    panhead_pete likes this.
  4. panhead_pete
    panhead_pete
    Thanks!
    Hopeless_hotrodder and Outback like this.
  5. Tim
    Tim
    from KCMO
    I believe Bob bleeds “ace hole” frames have a similar great set up if you want to see more examples Pete.
  6. panhead_pete
    panhead_pete
    Thanks @Tim will go check that out.
    Tim likes this.
  7. Hopeless_hotrodder
    Hopeless_hotrodder
    from Sparta WI
    when i traced back the history a bit on this car i believe bob was hired by the previous owner to do a lot of the work. then i cut it all out and redid it but i was happy with the ch***is for the most part
    Tim and Outback like this.
