Projects Rear/Mid Engine 1927 T Roadster
Discussion in 'The Hokey Ass Message Board' started by Noah*, Oct 4, 2024.
  1. 19Eddy30
    19Eddy30
    from VA
    @Tim
    I talked to builder some time ago
    I am sure he said the hood is Plex
    & he has made the hood several times
    Because of cracking .
    Drilling, cutting & vibrations from driving .
    I talked to him for awhile I think he used a wooden buck to form .
    @Noah*
    Me thinking you could use Vacuum forming using a metal skin in oven .
    Cut out tricky ?
    Outback and Stogy like this.
  2. Noah*
    Noah*
    You have to take the plastic or paper off. Usually I will put it on t shirt material to keep it from taking impressions, but I didn't this time I made sure the template was clean. I did cover the secondary piece I made from plywood to press with with t shirt material to keep from leaving impressions in the hot acrylic. I usually heat 1/8" plastic at 350 degrees for 10 minutes.
    Outback, Stogy, rod1 and 1 other person like this.
  3. Noah*
    Noah*
    I did think of vacuum forming. I make signs for a living and have had vacuum formed sign faces made in the past. I found out the company that used to do that around here went out of business, so I just used the oven
  4. 19Eddy30
    19Eddy30
    from VA
    @Noah*
    I would have to look for Owner / builder name ,
    I think I ask why not made out of
    Lexanne I think it was because not able @ time to get other then clear ,
    Your build is neat ,
    My intentions for questions Are at times to see how others do / make especially at home and a small shop ,
    Stogy likes this.
  5. Noah*
    Noah*
    made these inserts for the controls going in the roadster today at work. These will be the shifter and the switches for the ignition and lights. They are made from 1956 Mercury heater controls.
    Outback, Stogy and Just Gary like this.
  6. Noah*
    Noah*
  7. Tim
    Tim
    from KCMO
    Endless cool details! Curious to see how you make that work :)
    Stogy and lurker mick like this.
  8. 1971BB427
    1971BB427
    from Oregon
    That's Cedric Meeks car. Son of Russ Meeks.
  9. Tim
    Tim
    from KCMO
    yup. Mentioned it the first time I mentioned the car. Cool stuff always comes from those two.
  10. Robdski
    Robdski
    My opinion doesn’t mean anything, but to me your creativity is mind bending. I really appreciate you sharing the progress.
  11. Noah*
    Noah*
    finished the brakes
    Tim, Ziggster, Outback and 5 others like this.
  12. Noah*
    Noah*
    worked on the dash today. Combination of 1960 Desoto gauges, 1954 Ford Speedometer and 1956 Mercury heater controls. 20260621_160121.jpg 20260621_160152.jpg
    1971BB427, James D, Just Gary and 9 others like this.
  13. panhead_pete
    panhead_pete
    More excellent work. Will you be using the dash shifter controls?
  14. Noah*
    Noah*
    Yes I will use the shifter on the dash
    Ziggster, Outback, Stogy and 2 others like this.
  15. Noah*
    Noah*
  16. rod1
    rod1
    Cherry ! Nice Job. A lot going on there.
    Ziggster, porkshop and Outback like this.
  17. Outback
    Outback
    from NE Vic, Oz
    So cool. Love your creativity
    Ziggster and porkshop like this.
  18. CSPIDY
    CSPIDY
    Looking forward to seeing all these kool parts ***embled
  19. nrgwizard
    nrgwizard
    from Minn. uSA
    Did you do how the lexan-louvers were done? I like the effect of both the lexan-inserts, & the louvers in the lexan. :) .
    TIA.
    Oh, interesting gauge cluster. :) .
    Marcus...
  20. Noah*
    Noah*
    It is 1/8" acrylic (plexigl***), not lexan (polycarbonate). I stamped louvers in aluminum and used that as a form with a secondary piece on top to press the acrylic into the louvers. Heat at 350 degrees for 10 minutes
    1971BB427, Just Gary, Outback and 4 others like this.
  21. nrgwizard
    nrgwizard
    from Minn. uSA
    Thanks for the info. Not to be an ***, but what about the easy(?) scratching effect(s), iirc. Anything to offset that? In the past, I've not been successful in stopping that effect after a bit of time & use. I never did try coating w/clearcoat paint, much less hardened, nor the "ceramic" clears(not available then), or the now-available Cerakoat clear(if that'd even work). Very curious.
    TIA.
    Marcus...
  22. Noah*
    Noah*
    I clean plastic with a microfiber towel and Novus Polish #1. I bent plastic for the corner windows in my truck years ago and they still look new.
    porkshop, Just Gary and rod1 like this.
  23. CSPIDY
    CSPIDY
    Plexigl*** is obviously not scratch resistant but can be easily polished out.
    Coating it with any clear would only dull the view through the gl*** eventually.
    Just Gary and porkshop like this.
  24. nrgwizard
    nrgwizard
    from Minn. uSA
    Have tried the Novus(iirc, #1 & #2) yrs ago, but didn't help much. Must've done it wrong.
    Thanks for the comments n info.
    Marcus...
    porkshop likes this.
  25. CSPIDY
    CSPIDY
    For heavier scratches you can get “Micro-Mesh” repair kit
  26. Noah*
    Noah*
  27. Ziggster
    Ziggster
    That’s going to be one hell of a tach!
  28. Tim
    Tim
    from KCMO
    This is the kind of stuff I feel like you’d come up with if you had like an entire 1958 and older junkyard that you worked at.
    you keep seeing little bits and pieces and all of a sudden it strikes you “hey what if I took this and that and…..”
    Love it
  29. patsurf
    patsurf
    yeah-makes it all the more amazing that it's being done w/ none of that old stuff even around!
    Outback and Just Gary like this.
  30. Noah*
    Noah*
    Added some aluminum trim around the louvers in the decklid
