Technical Valve guide question
Discussion in 'Traditional Hot Rods' started by Rockitdoc, Jun 19, 2026.
  1. Rockitdoc
    Rockitdoc
    Why does this valve guide have the groove and others do not?
  2. Grumpy ole A
    Grumpy ole A
    It may have been replaced at some point in the engine’s life.
  3. FrozenMerc
    FrozenMerc
    Grumpy is spot on. Over 75+ years of being used, worn out, rebuilt, and used again, you will find some unusual things in flatheads.
  4. Rockitdoc
    Rockitdoc
    Yep. But, why was the groove there? What’s the purpose?
  5. deucemac
    deucemac
    That's an exhaust guide and takes a square cut seal. It. Keeps oil from being ****ed out the exhaust.
    Toms Dogs likes this.
  6. Rockitdoc
    Rockitdoc
    Makes sense. But, it must not be needed. I only found two with this groove. The other six don't have it.
  7. ronzmtrwrx
    ronzmtrwrx
    The intake guides are the ones with the seals.
    Andy, warbird1 and sidevalve8ba like this.
  8. Flatheadjohn47
    Flatheadjohn47
    from Lewes, DE
    The groove that is cut on some guides are meant to be on the INTAKES. MAKE SURE U USE PLENTY OF OIL WHEN “sliding” them in place on the block.The exhaust side has no gap for the rubber seals.FLATHEADS FOREVER. IMG_2839.jpeg IMG_2200.jpeg
    warbird1, sidevalve8ba and ronzmtrwrx like this.
  9. leon bee
    leon bee
    Those seals get left out sometimes, they're hard to get in.
  10. banjorear
    banjorear
    For your rebuild, I would go will all exhaust (solid) ones for the guides. As long as your guide bores are good and not wallowed out, those seals aren't needed if you ensure proper valve stem/guide fitment.
    If you have access to a lathe, you can also bellflower the tops of the guides to reduce the amount the top protrudes into the ports for better flow.
